/******************** (C) COPYRIGHT 2007 STMicroelectronics ******************** * File Name : main.c * Author : MCD Application Team * Date First Issued : 05/21/2007 * Description : Main program body ******************************************************************************** * History: * 05/21/2007: V0.3 ******************************************************************************** * THE PRESENT SOFTWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME. * AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT, * INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE * CONTENT OF SUCH SOFTWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING * INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS. *******************************************************************************/
/* Includes ------------------------------------------------------------------*/ #include "stm32f10x_lib.h"
Reading the temperature To use the sensor: 1. Select the ADCx_IN16 input channel. 2. Select a sample time greater than 2.2 μs 3. Set the TSVREFE bit in the ADC control register 2 (ADC_CR2) to wake up the temperature sensor from power down mode. 4. Start the ADC conversion by setting the ADON bit (or by external trigger). 5. Read the resulting VSENSE data in the ADC data register 6. Obtain the temperature using the following formula: Temperature (in °C) = {(V25 - VSENSE) / Avg_Slope} + 25. Where, V25 = VSENSE value for 25° C and Avg_Slope = Average Slope for curve between Temperature vs. VSENSE (given in mV/° C or μV/ °C). Refer to the Electrical characteristics section for the actual values of V25 and Avg_Slope.
Note: The sensor has a startup time after waking from power down mode before it can output VSENSE at the correct level. The ADC also has a startup time after power-on, so to minimize the delay, the ADON and TSVREFE bits should be set at the same time.
