社区导航
快捷导航
  • 首页
  • 论坛
  • 查看新帖
  • 最新回复
  • 社区活动
  • 联系管理员
  • 消灭零回复
  • E金币兑换
  • 干货
搜索
查看: 3178|回复: 0
[求助] 请教at24c08读写的问题
TA的帖子
Rank: 1
发表于 2011-2-14 15:02:42 | 显示全部楼层 |阅读模式
最近在弄51读写24c系列,按照数据手册写出了程序,但是奇怪的是可以读出数据却没法写入数据
还请大家赐教
硬件环境是at89s52,at24c08a,12mhz晶振
;定义区
EEPROM_WP BIT P2.6
EEPROM_SCL BIT P2.5
EEPROM_SDA BIT P2.4
;代码区
org 0000h
jmp main
org 0080h
;r/w 24c08
main:mov sp,#60h
     call init_eeprom
    call delay_10ms
     jmp test_eeprom
test_eeprom: clr p0.1
            mov 0x49,#30h
            mov 0x4a,#31h
           mov r2,#1
            mov 0x30,#81h
        mov 0x31,#20h
          call write_eeprom
            mov 0x49,#31h
            mov 0x4a,#32h
        mov r2,#1
        call read_eeprom
        mov p1,0x32
        jmp test_eeprom
init_eeprom:
            mov 0x47,#0a0h
        mov 0x48,#0a1h
        ;clr p2.0
        ;clr p2.1
        ;clr p2.2
        ;clr p2.3
        setb p2.7
        ;clr EEPROM_WP
        ret
read_eeprom:
             call start_eeprom
         mov a,0x47
        call send_eeprom_byte
        jc read_eeprom
        mov r0,0x49
             mov a,@r0
        jc read_eeprom
        call start_eeprom
        mov a,0x48
               jc read_eeprom
        mov r0,0x4a
read_eeprom_loop:call read_eeprom_byte
                mov @r0,a
                inc r0
                djnz r2,read_eeprom_loop
                                call stop_eeprom
                jmp delay_10ms
write_eeprom: clr EEPROM_WP
             call start_eeprom
             mov a,0x47
              jc write_eeprom
         mov r0,0x4a
         mov a,@r0
             jc write_eeprom
        mov r0,0x49
write_eeprom_loop:
             mov a,@r0
             jc write_eeprom
         inc r0
             djnz r2,write_eeprom_loop
         call stop_eeprom
         setb EEPROM_WP
        jmp delay_10ms
read_eeprom_byte: mov r4,#8
                  clr EEPROM_SCL
                  setb EEPROM_SDA
read_eeprom_byte_loop:setb EEPROM_SCL
                  mov c,EEPROM_SDA
                  rlc a
        clr EEPROM_SCL
                  djnz r4,read_eeprom_byte_loop
        clr EEPROM_SDA
        ret
send_eeprom_byte:
                 mov r4,#8
send_eeprom_byte_loop:rlc a
           clr EEPROM_SCL
           mov EEPROM_SDA,c
           setb EEPROM_SCL
           djnz r4,send_eeprom_byte_loop
         jmp waitAck
waitAck:
           clr EEPROM_SCL
           nop
          setb EEPROM_SDA
        setb EEPROM_SCL
        mov c,EEPROM_SDA
           jc waitAck
          clr EEPROM_SDA
        clr EEPROM_SCL
        ret
start_eeprom:
        setb EEPROM_SDA
         setb EEPROM_SCL
         clr EEPROM_SDA
         clr EEPROM_SCL
         ret
stop_eeprom:
        clr EEPROM_SDA
         setb EEPROM_SCL
        setb EEPROM_SDA
         ret
delay:
       nop
                 nop
                 nop
                 nop
                 nop
                 ret
delay_10ms:
           mov r4,#50
delay_10ms_loop: mov r5,#200
                 djnz r5,$
                 djnz r4,delay_10ms_loop
                 ret
此帖出自51单片机论坛
本版积分规则
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
小黑屋|手机版|Archiver|电子工程世界 ( 京ICP证 060456
GMT+8, 2018-7-16 08:39 , Processed in 0.078399 second(s), 18 queries , Gzip On, Redis On.
