//----------------------------------------------------- 2 // Design Name : syn_fifo 3 // File Name : syn_fifo.v 4 // Function : Synchronous (single clock) FIFO 5 // Coder : Deepak Kumar Tala 6 //----------------------------------------------------- 7 module syn_fifo ( 8 clk , // Clock input 9 rst , // Active high reset 10 wr_cs , // Write chip select 11 rd_cs , // Read chipe select 12 data_in , // Data input 13 rd_en , // Read enable 14 wr_en , // Write Enable 15 data_out , // Data Output 16 empty , // FIFO empty 17 full // FIFO full 18 ); 19 20 // FIFO constants 21 parameter DATA_WIDTH = 8; 22 parameter ADDR_WIDTH = 8; 23 parameter RAM_DEPTH = (1 << ADDR_WIDTH); 24 // Port Declarations 25 input clk ; 26 input rst ; 27 input wr_cs ; 28 input rd_cs ; 29 input rd_en ; 30 input wr_en ; 31 input [DATA_WIDTH-1:0] data_in ; 32 output full ; 33 output empty ; 34 output [DATA_WIDTH-1:0] data_out ; 35 36 //-----------Internal variables------------------- 37 reg [ADDR_WIDTH-1:0] wr_pointer; 38 reg [ADDR_WIDTH-1:0] rd_pointer; 39 reg [ADDR_WIDTH :0] status_cnt; 40 reg [DATA_WIDTH-1:0] data_out ; 41 wire [DATA_WIDTH-1:0] data_ram ; 42 43 //-----------Variable assignments--------------- 44 assign full = (status_cnt == (RAM_DEPTH-1)); 45 assign empty = (status_cnt == 0); 46 47 //-----------Code Start--------------------------- 48 always @ (posedge clk or posedge rst) 49 begin : WRITE_POINTER 50 if (rst) begin 51 wr_pointer <= 0; 52 end else if (wr_cs && wr_en ) begin 53 wr_pointer <= wr_pointer + 1; 54 end 55 end 56 57 always @ (posedge clk or posedge rst) 58 begin : READ_POINTER 59 if (rst) begin 60 rd_pointer <= 0; 61 end else if (rd_cs && rd_en ) begin 62 rd_pointer <= rd_pointer + 1; 63 end 64 end 65 66 always @ (posedge clk or posedge rst) 67 begin : READ_DATA 68 if (rst) begin 69 data_out <= 0; 70 end else if (rd_cs && rd_en ) begin 71 data_out <= data_ram; 72 end 73 end 74 75 always @ (posedge clk or posedge rst) 76 begin : STATUS_COUNTER 77 if (rst) begin 78 status_cnt <= 0; 79 // Read but no write. 80 end else if ((rd_cs && rd_en) && ! (wr_cs && wr_en) 81 && (status_cnt ! = 0)) begin 82 status_cnt <= status_cnt - 1; 83 // Write but no read. 84 end else if ((wr_cs && wr_en) && ! (rd_cs && rd_en) 85 && (status_cnt ! = RAM_DEPTH)) begin 86 status_cnt <= status_cnt + 1; 87 end 88 end 89 90 ram_dp_ar_aw #(DATA_WIDTH,ADDR_WIDTH)DP_RAM ( 91 .address_0 (wr_pointer) , // address_0 input 92 .data_0 (data_in) , // data_0 bi-directional 93 .cs_0 (wr_cs) , // chip select 94 .we_0 (wr_en) , // write enable 95 .oe_0 (1'b0) , // output enable 96 .address_1 (rd_pointer) , // address_q input 97 .data_1 (data_ram) , // data_1 bi-directional 98 .cs_1 (rd_cs) , // chip select 99 .we_1 (1'b0) , // Read enable 100 .oe_1 (rd_en) // output enable 101 ); 102 103 endmodule
