always @(posedge clk or negedge rst) begin if(!rst) current_st<=st0; else current_st<=next_st; end
always @(current_st or bale or iow) begin case (current_st) st0: begin if(bale) next_st=st1; else next_st=st0; end st1: begin if(!iow) next_st=st2; else next_st=st0; end st2: begin next_st=st3; end st3: begin next_st=st0; end default: begin next_st=st0; end endcase end
always @(current_st or la or ld) begin case (current_st) st0:begin dout<=0; ad<=0; end st1:begin dout<=0; ad<=0; end st2:begin case (la) 4'b000: begin dout<=ld;
end 4'b001: begin ad<=ld;
end default:begin dout<=ld; end endcase end st3:begin dout<=dout; ad<=ad; end endcase end
endmodule
在quartus中编译出现这样的警告: Warning (10240): Verilog HDL Always Construct warning at state.v(61): inferring latch(es) for variable "dout", which holds its previous value in one or more paths through the always construct Warning (10240): Verilog HDL Always Construct warning at state.v(61): inferring latch(es) for variable "ad", which holds its previous value in one or more paths through the always construct Warning: Latch ad[0]$latch has unsafe behavior Warning: Ports D and ENA on the latch are fed by the same signal la[1] Warning: Latch ad[1]$latch has unsafe behavior Warning: Ports D and ENA on the latch are fed by the same signal la[1] Warning: Latch ad[2]$latch has unsafe behavior Warning: Ports D and ENA on the latch are fed by the same signal la[1] Warning: Latch ad[3]$latch has unsafe behavior Warning: Ports D and ENA on the latch are fed by the same signal la[1] Warning: Latch ad[4]$latch has unsafe behavior Warning: Ports D and ENA on the latch are fed by the same signal la[1] Warning: Latch ad[5]$latch has unsafe behavior Warning: Ports D and ENA on the latch are fed by the same signal la[1] Warning: Latch ad[6]$latch has unsafe behavior Warning: Ports D and ENA on the latch are fed by the same signal la[1] Warning: Latch ad[7]$latch has unsafe behavior Warning: Ports D and ENA on the latch are fed by the same signal la[1] 怎么解决啊?
