把一个二进制转成BCD码,使用逻辑分析仪抓的数据,输入的数据最大为189975,加个60000后最大249975,平时这个数据是不断变化的,最大会有正负1000左右的跳动。现在的问题是:假如输入为100000,那么正确的输出应该是1、6、0,让我想不明白的是,最终输出的三个数据很不固定,会来回变。另外,程序中明明将count5限制到最大是9,怎么跑出来个13呀?还有count6,有时候居然会冒出个15,求大牛们给看下,这程序的问题在哪? 附上这一块的程序: architecture behave of D_BCD is signal count1,count2,count3,count4,count5,count6: integer range 0 to 9:=0; signal cnt:integer range 0 to 3500000:=0; begin process(datain,clk) -- variable cnt:integer range 0 to 350000; begin if clk'event and clk='1' then
if cnt<=conv_integer(datain)+60000 then cnt<=cnt+1; if count1=9 then count1<=0; if count2=9 then count2<=0; if count3=9 then count3<=0; if count4=9 then count4<=0; if count5=9 then count5<=0; count6<=count6+1; else count5<=count5+1; end if; else count4<=count4+1; end if; else count3<=count3+1; end if; else count2<=count2+1; end if; else count1<=count1+1; end if; else dataout3<=conv_std_logic_vector(count6,4); dataout2<=conv_std_logic_vector(count5,4); dataout1<=conv_std_logic_vector(count4,4); cnt<=0; count1<=0; count2<=0; count3<=0; count4<=0; count5<=0; count6<=0; end if; end if; end process;
