5394|15
CDMA ppp 接入UDP传输为什么不行 [复制链接]
各位大虾我现在有一个问题,我采用同样的PPP协议栈,使用GPRS上网TCP UDP都可正常传输,但是采用有线modem及CDMA modem就发现TCP可以,余名解析也可以,但在应用程序发送UDP包时,服务器没有反应(设备和服务器都是同样的程序),是不是lcp协商的问题导致的,以下是我的CDMA连接过程
*** AT Stage: PPP
*** PPP Stage: None
*** PPP Stage: Starting
*** AT Stage: Disc 1
*** PPP Stage: LCP Options
TX: Protocol: PPP_LCP [c021]    Code:CREQ [1]  ID:1   Len:14
    type:1     len:41500
    type:2     len:6  ACCM: 00000000000000000000101000000000
3006-0-0
Reset GPS Task
    type:1     len:41500
7011-0-0
RX: Protocol: PPP_LCP [c021]    Code:CREQ [1]  ID:1   Len:29
    type:1     len:41500
    type:2     len:6  ACCM: 00000000000000000000000000000000
    type:3     len:5    AP: C223
    type:5     len:6    MN: 1552180886
    type:7     len:2  PFC
    type:8     len:2  ACFC
     we n-rejected auth-prot:C223 .. asking for PAP instead
TX: Protocol: PPP_LCP [c021]    Code:CNAK [3]  ID:1   Len:8
    type:3     len:4    AP: C023
RX: Protocol: PPP_LCP [c021]    Code:CACK [2]  ID:1   Len:14
    type:1     len:41500
Initialize GPS OK
    type:1     len:41500
RX: Protocol: PPP_LCP [c021]    Code:CREQ [1]  ID:2   Len:28
    type:1     len:41500
    type:7     len:2  PFC
    type:8     len:2  ACFC
    rejected:7
    rejected:8
TX: Protocol: PPP_LCP [c021]    Code:CREJ [4]  ID:2   Len:8
    type:7     len:2  PFC
    type:8     len:2  ACFC
RX: Protocol: PPP_LCP [c021]    Code:CREQ [1]  ID:3   Len:24
    type:1     len:41500
    accepted:1
    accepted:2
    accepted:3
    accepted:5
TX: Protocol: PPP_LCP [c021]    Code:CACK [2]  ID:3   Len:24
    type:1     len:41500
LCP Success
*** PPP Stage: Auth'ing
TX: Protocol: PPP_PAP [c023]    Code:CREQ [1]  ID:1   Len:14
4005-0-0
RX: Protocol: PPP_PAP [c023]    Code:CACK [2]  ID:1   Len:5
  They accepted our Auth'
*** PPP Stage: Sorting IP's
PAP Success
TX: Protocol: PPP_IPCP [8021]    Code:CREQ [1]  ID:1   Len:22
    type:3     len:6   ip: 0.0.0.0
    type:129     len:6   ip: 0.0.0.0
    type:131     len:6   ip: 0.0.0.0
RX: Protocol: PPP_IPCP [8021]    Code:CREQ [1]  ID:4   Len:16
    type:2     len:6   comp-prot: 002D
    type:3     len:6   ip: 220.192.168.3
    rejected:2
TX: Protocol: PPP_IPCP [8021]    Code:CREJ [4]  ID:4   Len:10
RX: Protocol: PPP_IPCP [8021]    Code:CNAK [3]  ID:1   Len:22
    type:3     len:6   ip: 220.207.169.79
    type:129     len:6   ip: 220.192.32.103
    type:131     len:6   ip: 220.192.0.130
TX: Protocol: PPP_IPCP [8021]    Code:CREQ [1]  ID:2   Len:22
RX: Protocol: PPP_IPCP [8021]    Code:CREQ [1]  ID:5   Len:10
    accepted:3
TX: Protocol: PPP_IPCP [8021]    Code:CACK [2]  ID:5   Len:10
RX: Protocol: PPP_IPCP [8021]    Code:CACK [2]  ID:2   Len:22
  Tx Magic Num: 0
  Rx Magic Num: 1552180886
       Tx ACCM: 00000000000000000000101000000000
       Rx ACCM: 00000000000000000000000000000000
        Tx MRU: 1500
        Rx MRU: 1500
n
  Our IP: 220.207.169.79
Their IP: 220.192.168.3
DNS-1 IP: 220.192.32.103
DNS-2 IP: 220.192.0.130
学习一下   ppp验证成功后能否用CSocket直接向网络发东西  详情 回复 发表于 2009-10-22 18:48
经测试可以在ntp服务器,dns服务器之间进行udp传输,但我自己的服务器在铁通,同时电信ADSL拨号上网的临时全局IP测试不能通过,郁闷中。。。
NAT问题
75
能具体一点吗,是联通不提供不知名端口,这个问题怎么解决,已测试知名端口可以使用
55
请问楼主:
gprs中有apn设置,cdma需要设置apn或类似的参数吗?
cdma不需要设置apn,但是需要用户名和密码,匹配就可以了。。。正常访问公网的都是card。
84
就是说在建立ppp连接的时候,把用户名和密码设置成card,其余的和gprs差不多?
65
那么他所获得的本地ip是内部ip吗?gprs一般是10开头的内部ip
如果您需要查看本帖隐藏内容,请登录或者注册
81
62
63
64
85
相关帖子
站长推荐上一条 1/5 下一条
