部分内容如下
#include /*标准输入输出定义*/
#include /*标准函数库定义*/
#include /*Unix 标准函数定义*/
// File Name : 2410IIC.c
// Function : S3C2410 IIC-bus Master Tx/Rx mode Test Program
// (Interrupt / Non Interrupt (Polling))
// Program : Shin, On Pil (SOP)
// Date : May 21, 2002
// Version : 0.0
// History
// 0.0 : Programming start (March 11, 2002) -> SOP
#define U32 unsigned int
#define U16 unsigned short
#define S32 int
#define S16 short int
#define U8 unsigned char
#define S8 char
#define TRUE 1
#define FALSE 0
#define WRDATA (1)
#define POLLACK (2)
#define RDDATA (3)
#define SETRDADDR (4)
#define IICBUFSIZE 0x20
#define FCLK 202800000
#define HCLK (202800000/2)
#define PCLK (202800000/4)
#define UCLK PCLK
// IIC
#define rIICCON (*(volatile unsigned *)0x54000000) //IIC control
#define rIICSTAT (*(volatile unsigned *)0x54000004) //IIC status
#define rIICADD (*(volatile unsigned *)0x54000008) //IIC address
#define rIICDS (*(volatile unsigned *)0x5400000c) //IIC data shift
#define rGPECON (*(volatile unsigned *)0x56000040) //Port E control
#define rGPEDAT (*(volatile unsigned *)0x56000044) //Port E data
#define rGPEUP (*(volatile unsigned *)0x56000048) //Pull-up control E
// WATCH DOG TIMER
#define rWTCON (*(volatile unsigned *)0x53000000) //Watch-dog timer mode
#define rWTDAT (*(volatile unsigned *)0x53000004) //Watch-dog timer data
#define rWTCNT (*(volatile unsigned *)0x53000008) //Eatch-dog timer count
void Delay(int time);
void Test_Iic2(void);
void _Wr24C080(U32 slvAddr,U32 addr,U8 data);
void _Rd24C080(U32 slvAddr,U32 addr,U8 *data);
void IicPoll(void);
void Run_IicPoll(void);
static U8 _iicData[IICBUFSIZE];
static volatile int _iicDataCount;
static volatile int _iicStatus;
static volatile int _iicMode;
static int _iicPt;
static int delayLoopCount = FCLK/10000/10;
// SMDK2410 IIC configuration
// GPE15=IICSDA, GPE14=IICSCL
// "Non-Interrupt" mode for IIC block
//*********************[ Test_Iic2 ]*********************************
unsigned int i,j,save_E,save_PE;
static U8 data[256];
printf("[ IIC Test(Polling) using KS24C080 ]\n");
save_E = rGPECON;
save_PE = rGPEUP;
rGPEUP |= 0xc000; //Pull-up disable
rGPECON |= 0xa00000; //GPE15:IICSDA , GPE14:IICSCL
//Enable ACK, Prescaler IICCLK=PCLK/16, Enable interrupt, Transmit clock value Tx clock=IICCLK/16
rIICCON = (1<<7) | (0<<6) | (1<<5) | (0xf);
// rIICADD = 0x10; //2410 slave address = [7:1]
rIICSTAT = 0x10; //IIC bus data output enable(Rx/Tx)
printf("Write test data into KS24C080\n");
for(i=0;i<256;i++)
_Wr24C080(0xa0,(U8)i,255-i);
for(i=0;i<256;i++)
data = 0;
printf("Read test data from KS24C080\n");
for(i=0;i<256;i++)
_Rd24C080(0xa0,(U8)i,&(data));
for(i=0;i<16;i++)
for(j=0;j<16;j++)
printf("%2x ",data[i*16+j]);
printf("\n");
rGPEUP = save_PE;
rGPECON = save_E;
救救我吧
