6534|1
83
verilog case语句嵌套 [复制链接]
always@(posedge iCLK or negedge iRST)
if(!iRST)
                max         <= 200;
else
   begin//1
                case(Distance_range)
                         3:begin
                             case(Dist_thresh)
                                 3:max<=max_thresh*3>>3;        // 6/16
                             0:max<=(max_thresh*5)>>4;                 // 5/16
                             1:max<=max_thresh>>2;                    // 4/16
                             2:max<=(max_thresh*3)>>4;                 // 3/16
                             4:max<=max_thresh>>3;                         // 2/16
                                 default:max<=diffaim_S;
                                 endcase
                                   end
                        0:  begin
                             case(Dist_thresh)
                                 3:max<=(max_thresh*7)>>4;                 //  7/16
                             0:max<=(max_thresh*3)>>3;
107336722 16:22:02
//  6/16
                             1:max<=(max_thresh*5)>>4;                //  5/16
                                 2:max<=max_thresh>>2;                        //  4/16
                                 4:max<=(max_thresh*3)>>4;                 //  3/16
                                 endcase
                                   end
[size=11px]上述代码中case语句中变量Distance_range和Dist_thresh都是3位的,现在不想使用case语句嵌套,想把两个变量放在一条case语句里,应该怎么改写呢?希望各位大侠给予指点!
Distance_range 这个变量可以不用CASE,IF /ELSE不就能搞定了 ,把两个变量放在一条case语句里更乱又麻烦
