社区导航
搜索
查看: 3053|回复: 13
WINCE操作系统定制
115
TA的帖子
Rank: 1
发表于 2009-10-28 14:12 | 显示全部楼层 |阅读模式
我想学习一下WINCE操作系统的定制,安装了PB5.0,硬件设备也有,2440跑WINCE5.0的板子。我想学习一下,自己定制一个系统,下进去跑跑。如何使用PB生成系统映像的大体流程我已经清楚了。现在想系统的学习一下,比如那些特性我该怎么去选择等等。我现在想看一下PB软件帮助手册,通过这个手册来学习。不知道这样怎么样?大家学习WINCE操作系统定制的时候,都是怎么一个流程?看了那本书,或者那些资料?等等。是如何学习的。谢谢大侠们。
此帖出自WindowsCE论坛
97
TA的帖子
Rank: 1
发表于 2009-10-28 14:14 | 显示全部楼层
你觉得需要什么组件就加到工程里边就行了,没有什么特别之处
使用道具 举报
102
TA的帖子
Rank: 1
发表于 2009-10-28 14:16 | 显示全部楼层
下面是PB的帮助文档目录,我先把这个看完,大家觉得怎么样?
Developing an Operating System > How to Create a Windows CE OS Design
OS design integration is the process of combining all Windows CE–based components and applications for your target device and adding them into the run-time image for your device.
OEMs and original device manufacturers (ODMs), system integrators (SIs), and device integrators (DIs) perform OS design integration.
To integrate a Windows CE-based OS design
From the Platform Builder New Platform Wizard, create an OS design.
For more information, see Creating an OS Design with the New Platform Wizard.
From the Catalog, add components to or remove components from your OS design.
For more information, see Adding to an OS Design and Removing a Catalog Item from an OS Design.
Configure the components.
Import components and applications to your OS design.
You can use the following Platform Builder tools to create and import new .cec files:
CEC Editor
Export Wizard
Catalog importer
For more information about these tools, see CEC Editor, Export Wizard Overview, and Manage Catalog Items Dialog Box.
Build your run-time image using either the command line or the IDE.
For information about how to build your run-time image using the command line, see Build Tool.
For information about how to build your run-time image using the IDE, see Building a Run-Time Image.
Roll an SDK using either the command line or the Export SDK Wizard.
For information about how to configure and build an SDK using the command line, see Building an SDK from the Command Line.
For information about how to configure and build an SDK using the Export SDK Wizard, see Configuring an SDK.
Debug, test, and diagnose your OS design.
For more information, see Tools for Debugging and Testing.
If you have not completed adding components to or removing components from your OS design, repeat steps 2 through 7.
使用道具 举报
81
TA的帖子
Rank: 1
发表于 2009-10-28 14:20 | 显示全部楼层
貌似没有啥教程,看代码,弄多了,多来论坛,
找个好开发板,好手册,自然就会了。
朱工你这么厉害了,不用学习这个了吧。
使用道具 举报
99
TA的帖子
Rank: 1
发表于 2009-10-28 14:31 | 显示全部楼层
朱工你这么厉害了,不用学习这个了
使用道具 举报
101
TA的帖子
Rank: 1
发表于 2009-10-28 14:49 | 显示全部楼层
多看书吧。很详细的功能表格我没找到。谁有贡献一下。
使用道具 举报
94
TA的帖子
Rank: 1
发表于 2009-10-28 15:21 | 显示全部楼层
引用 3 楼 gooogleman 的回复:
找个好开发板,好手册,自然就会了。
朱工你这么厉害了,不用学习这个了吧。
gooogleman老兄。我编写点应用程序还行,驱动BSP,系统定制什么的,还得抓紧学啊。
反正是非常有兴趣!不知道现在搞WINCE的公司多不多?招聘的多不?
我毕业的时候可能不留在现在这家公司。
使用道具 举报
101
TA的帖子
Rank: 1
发表于 2009-10-28 15:22 | 显示全部楼层
不过,这段时间来到了eeworld,看了很多的帖子还有大侠们的博客,各个方面有了挺大的进步。
使用道具 举报
98
TA的帖子
Rank: 1
发表于 2009-10-28 15:46 | 显示全部楼层
5.0方面的书还是比较多的,张冬泉的就有实例,可以参考,还有周立功的,都挺详细的。否则,手头上有个板子,按照手册跑几次也就熟悉了!
使用道具 举报
110
TA的帖子
Rank: 1
发表于 2009-10-29 11:17 | 显示全部楼层
看帮助文件是最好的入门方法。
我当初入门的时候,看了差不多一半。
使用道具 举报
105
TA的帖子
Rank: 1
发表于 2009-10-29 11:22 | 显示全部楼层
引用 9 楼 yashi 的回复:
看帮助文件是最好的入门方法。
我当初入门的时候,看了差不多一半。
同感 ,而且还提高了英语,不然怎么过六级呀
使用道具 举报
106
TA的帖子
Rank: 1
发表于 2009-10-29 12:34 | 显示全部楼层
朱工你这么厉害了,不用学习这个了
偶像级别的哇? 我现在也慢慢看Pb的帮助文档!一起 学习 一起学习。
使用道具 举报
108
TA的帖子
Rank: 1
发表于 2009-10-29 12:35 | 显示全部楼层
引用 10 楼 programmerno1 的回复:
引用 9 楼 yashi 的回复:
看帮助文件是最好的入门方法。
我当初入门的时候,看了差不多一半。
泪奔,六级报了两次。。都没去考! 我太失败了。。。我要起自杀。。。
使用道具 举报
104
TA的帖子
Rank: 1
发表于 2009-10-29 13:51 | 显示全部楼层
自杀干什么,,现在博士论文都有假的,
使用道具 举报
站长推荐上一条 /7 下一条
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2020-2-27 22:45 , Processed in 0.408488 second(s), 18 queries , Gzip On, MemCache On.
