【得捷电子Follow me第4期】进阶任务:从NTP服务器同步时间
本身我们的arduino上面就有NTP服务器获取时间的例程,所以我在基础上稍微修改了下,显示了日期和时间。
Udp NTP Client
Get the time from a Network Time Protocol (NTP) time server
Demonstrates use of UDP sendPacket and ReceivePacket
For more on NTP time servers and the messages needed to communicate with them,
see http://en.wikipedia.org/wiki/Network_Time_Protocol
created 4 Sep 2010
by Michael Margolis
modified 9 Apr 2012
by Tom Igoe
modified 02 Sept 2015
by Arturo Guadalupi
This code is in the public domain.
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
unsigned int localPort = 8888; // local port to listen for UDP packets
const char timeServer[] = "ntp1.aliyun.com"; // time.nist.gov NTP server
const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
byte packetBuffer[NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
// A UDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
void setup() {
// You can use Ethernet.init(pin) to configure the CS pin
//Ethernet.init(10); // Most Arduino shields
//Ethernet.init(5); // MKR ETH shield
//Ethernet.init(0); // Teensy 2.0
//Ethernet.init(20); // Teensy++ 2.0
//Ethernet.init(15); // ESP8266 with Adafruit Featherwing Ethernet
//Ethernet.init(33); // ESP32 with Adafruit Featherwing Ethernet
Ethernet.init(17); // WIZnet W5100S-EVB-Pico W5500-EVB-Pico W6100-EVB-Pico
// Open serial communications and wait for port to open:
Serial.begin(9600);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// start Ethernet and UDP
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// Check for Ethernet hardware present
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
Serial.println("Ethernet shield was not found. Sorry, can't run without hardware. :(");
} else if (Ethernet.linkStatus() == LinkOFF) {
Serial.println("Ethernet cable is not connected.");
// no point in carrying on, so do nothing forevermore:
while (true) {
delay(1);
Udp.begin(localPort);
void loop() {
sendNTPpacket(timeServer); // send an NTP packet to a time server
// wait to see if a reply is available
delay(1000);
if (Udp.parsePacket()) {
// We've received a packet, read the data from it
Udp.read(packetBuffer, NTP_PACKET_SIZE); // read the packet into the buffer
// the timestamp starts at byte 40 of the received packet and is four bytes,
// or two words, long. First, extract the two words:
unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
// combine the four bytes (two words) into a long integer
// this is NTP time (seconds since Jan 1 1900):
unsigned long secsSince1900 = highWord << 16 | lowWord;
unsigned long n=0,d=0,total_d=0,rz=0;
uint32_t p_year_total_sec;
uint32_t r_year_total_sec;
uint16_t y=0,r=0,yr=0;
uint8_t yf=0;
signed long long yd=0;
Serial.print("Seconds since Jan 1 1900 = ");
Serial.println(secsSince1900);
// now convert NTP time into everyday time:
Serial.print("Unix time = ");
// Unix time starts on Jan 1 1970. In seconds, that's 2208988800:
const unsigned long seventyYears = 2208988800UL;
// subtract seventy years:
unsigned long epoch = secsSince1900 - seventyYears;
// print Unix time:
Serial.println(epoch);
// print the hour, minute and second:
Serial.print("The UTC time is "); // UTC is the time at Greenwich Meridian (GMT)
n = epoch;
total_d = epoch/(86400);
d=0;
p_year_total_sec=86400*365;
r_year_total_sec=86400*366;
while(n>=p_year_total_sec)
if((1970+r)%400==0 || ((1970+r)%100!=0 && (1970+r)%4==0))
n = n -(r_year_total_sec);
d = d + 366;
else
n = n - (p_year_total_sec);
d = d + 365;
r+=1;
y+=1;
y += 1970;
Serial.print(y); // print the year (86400 equals secs per day)
Serial.print('/');
yd=0;
yd = total_d - d;
yf=1;
while(yd>=28)
if(yf==1 || yf==3 || yf==5 || yf==7 || yf==8 || yf==10 || yf==12)
yd -= 31;
if(yd<0)break;
rz += 31;
if (yf==2)
if (y%400==0 || (y%100!=0 && y%4==0))
yd -= 29;
if(yd<0)break;
rz += 29;
else
yd -= 28;
if(yd<0)break;
rz += 28;
if(yf==4 || yf==6 || yf==9 || yf==11 )
yd -= 30;
if(yd<0)break;
rz += 30;
yf += 1;
Serial.print(yf);
Serial.print('/');
yr = total_d-d-rz;
yr += 1;
Serial.print(yr); // print the day (86400 equals secs per day)
Serial.print(' ');
Serial.print((epoch % 86400L) / 3600+8); // print the hour (86400 equals secs per day)
Serial.print(':');
if (((epoch % 3600) / 60) < 10) {
// In the first 10 minutes of each hour, we'll want a leading '0'
Serial.print('0');
Serial.print((epoch % 3600) / 60); // print the minute (3600 equals secs per minute)
Serial.print(':');
if ((epoch % 60) < 10) {
// In the first 10 seconds of each minute, we'll want a leading '0'
Serial.print('0');
Serial.println(epoch % 60); // print the second
// wait ten seconds before asking for the time again
delay(1000);
Ethernet.maintain();
// send an NTP request to the time server at the given address
void sendNTPpacket(const char * address) {
// set all bytes in the buffer to 0
memset(packetBuffer, 0, NTP_PACKET_SIZE);
// Initialize values needed to form NTP request
// (see URL above for details on the packets)
packetBuffer[0] = 0b11100011; // LI, Version, Mode
packetBuffer[1] = 0; // Stratum, or type of clock
packetBuffer[2] = 6; // Polling Interval
packetBuffer[3] = 0xEC; // Peer Clock Precision
// 8 bytes of zero for Root Delay & Root Dispersion
packetBuffer[12] = 49;
packetBuffer[13] = 0x4E;
packetBuffer[14] = 49;
packetBuffer[15] = 52;
// all NTP fields have been given values, now
// you can send a packet requesting a timestamp:
Udp.beginPacket(address, 123); // NTP requests are to port 123
Udp.write(packetBuffer, NTP_PACKET_SIZE);
Udp.endPacket();
最常用的国内NTP服务器
ntp1.aliyun.com
ntp.tencent.com
edu.ntp.org.cn
不修改服务器也是可以的。
其可以直接获取到时间
https://www.beijing-time.org/shijianchuo/
可以通过上面的时间戳通过网站验证我们转换是否正确。
北京时间加8小时既可。
