559|0
504
【得捷电子Follow me第4期】基础任务二-TCP服务 [复制链接]
ff825077221a0da0d143752c69c6469e
w5x00_loopback.uf2 (89 KB, 下载次数: 0)
  • 基础任务二:主控板建立TCPIP或UDP服务器,局域网PC使用TCPIP或UDP客户端进行连接并发送数据,主控板接收到数据后,送液晶屏显示(没有则通过串口打印显示);通过抓包软件抓取交互报文,展示并分析。(TCP和UDP二选一,或者全都操作)
5.1 准备
结合前面的入门任务和基础任务一。
添加代码
修改CMakeLists.txt为如下
set(TARGET_NAME w5x00_loopback)
aux_source_directory(ZLG_GUI ZLG_GUI_SOURCES)
include_directories(../../libraries/ioLibrary_Driver/Internet/TFTP ZLG_GUI/include .)
add_executable(${TARGET_NAME}
        ${TARGET_NAME}.c
        ls013.c
        ls013_lcd.c
        ${ZLG_GUI_SOURCES}
target_link_libraries(${TARGET_NAME} PRIVATE
        pico_stdlib
        hardware_spi
        hardware_dma
        ETHERNET_FILES
        IOLIBRARY_FILES
        LOOPBACK_FILES
pico_enable_stdio_usb(${TARGET_NAME} 1)
pico_enable_stdio_uart(${TARGET_NAME} 0)
pico_add_extra_outputs(${TARGET_NAME})
5.2 代码
w5x00_loopback.c
 * Copyright (c) 2021 WIZnet Co.,Ltd
 * SPDX-License-Identifier: BSD-3-Clause
 * Includes
#include <stdio.h>
#include "port_common.h"
#include "wizchip_conf.h"
#include "w5x00_spi.h"
#include "loopback.h"
#include "ping.h"
#include "ls013_lcd.h"
#include "config.h"
 * Macros
/* Clock */
#define PLL_SYS_KHZ (133 * 1000)
/* Buffer */
#define ETHERNET_BUF_MAX_SIZE (1024 * 2)
/* Socket */
#define SOCKET_LOOPBACK 0
/* Port */
#define PORT_LOOPBACK 5000
 * Variables
/* Network */
static wiz_NetInfo g_net_info =
        .mac = {0x00, 0x08, 0xDC, 0x12, 0x34, 0x56}, // MAC address
        .ip = {192, 168, 31, 111},                     // IP address
        .sn = {255, 255, 255, 0},                    // Subnet Mask
        .gw = {192, 168, 31, 1},                     // Gateway
        .dns = {8, 8, 8, 8},                         // DNS server
        .dhcp = NETINFO_STATIC                       // DHCP enable/disable
/* Loopback */
static uint8_t g_loopback_buf[ETHERNET_BUF_MAX_SIZE] = {
    0,
 * Functions
/* Clock */
static void set_clock_khz(void);
 * Main
uint8_t pDestaddr[4] = {120,232,145,144};
int main()
    uint8_t tmp=0;
    /* Initialize */
    int retval = 0;
    set_clock_khz();
    stdio_init_all();
    wizchip_spi_initialize();
    wizchip_cris_initialize();
    wizchip_reset();
    wizchip_initialize();
    wizchip_check();
    network_initialize(g_net_info);
    /* Get network information */
    print_network_information(g_net_info);
    GUI_Initialize();
    GUI_SetColor(1,0);
    GUI_PutString8_8(10,10,"tcp echo test");
    /* Infinite loop */
    while (1)
        #if 0
        tmp = ping_auto(0,pDestaddr);
        if(tmp == SUCCESS)
            printf("-----------PING TEST OK----------\r\n");
        else
            printf("----------ERROR  = %d----------\r\n",tmp);
        sleep_ms(50);
        #endif
        #if 1
        /* TCP server loopback test */
        if ((retval = loopback_tcps(SOCKET_LOOPBACK, g_loopback_buf, PORT_LOOPBACK)) < 0)
            printf(" Loopback error : %d\n", retval);
            GUI_PutString8_8(10,20,"Loopback error");
        else
            GUI_PutString8_8(10,20,"Loopback ok");
            GUI_PutString8_8(10,30,g_loopback_buf);
        #endif
        GUI_Exec();
 * Functions
/* Clock */
    // set a system clock frequency in khz
    set_sys_clock_khz(PLL_SYS_KHZ, true);
    // configure the specified clock
    clock_configure(
        clk_peri,
        0,                                                // No glitchless mux
        CLOCKS_CLK_PERI_CTRL_AUXSRC_VALUE_CLKSRC_PLL_SYS, // System PLL on AUX mux
        PLL_SYS_KHZ * 1000,                               // Input frequency
        PLL_SYS_KHZ * 1000                                // Output (must be same as no divider)
5.3 测试
试用网络调试助手,连接开发板TCP端口5000,发送数据开发板原样返回,屏幕显示结果和收到的数据。
5.4 抓包分析
抓包TCP交互过程和内容如下
