# Small ftp server for ESP8266 ans ESP32 Micropython
# Based on the work of chrisgp - Christopher Popp and pfalcon - Paul Sokolovsky
# The server accepts passive mode only.
# It runs in foreground and quits, when it receives a quit command
# Start the server with:
# import ftp
# Copyright (c) 2016 Christopher Popp (initial ftp server framework)
# Copyright (c) 2016 Robert Hammelrath (putting the pieces together
# and a few extensions)
# Distributed under MIT License
import socket
import network
import uos
import gc
#from usocket import socket
from machine import Pin,SPI,UART,PWM
import time, network,framebuf
''' static netinfo
ip = '192.168.1.20'
sn = '255.255.255.0'
gw = '192.168.1.1'
dns= '8.8.8.8'
BL = 13
DC = 8
RST = 12
MOSI = 11
SCK = 10
CS = 9
netinfo=(ip, sn, gw, dns)
localip = ''
localport = 8000
listen_info = (localip, localport)
conn_flag = False
def w5x00_init():
global localip
spi=SPI(0,2_000_000, mosi=Pin(19),miso=Pin(16),sck=Pin(18))
nic = network.WIZNET5K(spi,Pin(17),Pin(20))
nic.active(True)
# use dhcp, if fail use static netinfo
#try:
# nic.ifconfig('dhcp')
#except:
nic.ifconfig(netinfo)
localip = nic.ifconfig()[0]
print('ip :', nic.ifconfig()[0])
print('sn :', nic.ifconfig()[1])
print('gw :', nic.ifconfig()[2])
print('dns:', nic.ifconfig()[3])
while not nic.isconnected():
time.sleep(1)
# print(nic.regs())
print('no link')
return nic
def send_list_data(path, dataclient, full):
try: # whether path is a directory name
for fname in sorted(uos.listdir(path), key=str.lower):
dataclient.sendall(make_description(path, fname, full))
except: # path may be a file name or pattern
pattern = path.split("/")[-1]
path = path[:-(len(pattern) + 1)]
if path == "":
path = "/"
if fncmp(fname, pattern):
def make_description(path, fname, full):
if full:
stat = uos.stat(get_absolute_path(path, fname))
file_permissions = ("drwxr-xr-x"
if (stat[0] & 0o170000 == 0o040000)
else "-rw-r--r--")
file_size = stat[6]
description = "{} 1 owner group {:>10} Jan 1 2000 {}\r\n".format(
file_permissions, file_size, fname)
else:
description = fname + "\r\n"
return description
def send_file_data(path, dataclient):
with open(path, "rb") as file:
chunk = file.read(512)
while len(chunk) > 0:
dataclient.sendall(chunk)
def save_file_data(path, dataclient):
with open(path, "wb") as file:
chunk = dataclient.recv(512)
file.write(chunk)
def get_absolute_path(cwd, payload):
# Just a few special cases "..", "." and ""
# If payload start's with /, set cwd to /
# and consider the remainder a relative path
if payload.startswith('/'):
cwd = "/"
for token in payload.split("/"):
if token == '..':
if cwd != '/':
cwd = '/'.join(cwd.split('/')[:-1])
if cwd == '':
cwd = '/'
elif token != '.' and token != '':
if cwd == '/':
cwd += token
else:
cwd = cwd + '/' + token
return cwd
# compare fname against pattern. Pattern may contain
# wildcards ? and *.
def fncmp(fname, pattern):
pi = 0
si = 0
while pi < len(pattern) and si < len(fname):
if (fname[si] == pattern[pi]) or (pattern[pi] == '?'):
si += 1
pi += 1
else:
if pattern[pi] == '*': # recurse
if (pi + 1) == len(pattern):
return True
while si < len(fname):
if fncmp(fname[si:], pattern[pi+1:]):
return True
else:
si += 1
return False
else:
return False
if pi == len(pattern.rstrip("*")) and si == len(fname):
return True
else:
return False
def ftpserver(net, port=21, timeout=None):
DATA_PORT = 13333
ftpsocket = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
datasocket = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
ftpsocket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
datasocket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
ftpsocket.bind(socket.getaddrinfo("0.0.0.0", port)[0][4])
datasocket.bind(socket.getaddrinfo("0.0.0.0", DATA_PORT)[0][4])
ftpsocket.listen(1)
ftpsocket.settimeout(timeout)
datasocket.listen(1)
datasocket.settimeout(None)
msg_250_OK = '250 OK\r\n'
msg_550_fail = '550 Failed\r\n'
addr = net.ifconfig()[0]
print("FTP Server started on ", addr)
try:
dataclient = None
fromname = None
do_run = True
while do_run:
cl, remote_addr = ftpsocket.accept()
cl.settimeout(300)
cwd = '/'
try:
# print("FTP connection from:", remote_addr)
cl.sendall("220 Hello, this is Micropython.\r\n")
while True:
gc.collect()
data = cl.readline().decode("utf-8").rstrip("\r\n")
if len(data) <= 0:
print("Client disappeared")
do_run = False
break
command = data.split(" ")[0].upper()
payload = data[len(command):].lstrip()
path = get_absolute_path(cwd, payload)
print("Command={}, Payload={}".format(command, payload))
if command == "USER":
cl.sendall("230 Logged in.\r\n")
elif command == "SYST":
cl.sendall("215 UNIX Type: L8\r\n")
elif command == "NOOP":
cl.sendall("200 OK\r\n")
elif command == "FEAT":
cl.sendall("211 no-features\r\n")
elif command == "PWD" or command == "XPWD":
cl.sendall('257 "{}"\r\n'.format(cwd))
elif command == "CWD" or command == "XCWD":
try:
files = uos.listdir(path)
cwd = path
cl.sendall(msg_250_OK)
except:
cl.sendall(msg_550_fail)
elif command == "CDUP":
cwd = get_absolute_path(cwd, "..")
elif command == "TYPE":
# probably should switch between binary and not
cl.sendall('200 Transfer mode set\r\n')
elif command == "SIZE":
try:
size = uos.stat(path)[6]
cl.sendall('213 {}\r\n'.format(size))
except:
elif command == "QUIT":
cl.sendall('221 Bye.\r\n')
do_run = False
break
elif command == "PASV":
cl.sendall('227 Entering Passive Mode ({},{},{}).\r\n'.
format(addr.replace('.', ','), DATA_PORT >> 8,
DATA_PORT % 256))
dataclient, data_addr = datasocket.accept()
print("FTP Data connection from:", data_addr)
DATA_PORT = 13333
active = False
elif command == "PORT":
items = payload.split(",")
if len(items) >= 6:
data_addr = '.'.join(items[:4])
# replace by command session addr
if data_addr == "127.0.1.1":
data_addr = remote_addr
DATA_PORT = int(items[4]) * 256 + int(items[5])
dataclient = socket.socket(socket.AF_INET,
socket.SOCK_STREAM)
dataclient.settimeout(10)
dataclient.connect((data_addr, DATA_PORT))
print("FTP Data connection with:", data_addr)
cl.sendall('200 OK\r\n')
active = True
else:
cl.sendall('504 Fail\r\n')
elif command == "LIST" or command == "NLST":
if not payload.startswith("-"):
place = path
else:
place = cwd
try:
cl.sendall("150 Here comes the directory listing.\r\n")
send_list_data(place, dataclient,
command == "LIST" or payload == "-l")
cl.sendall("226 Listed.\r\n")
except:
if dataclient is not None:
dataclient.close()
dataclient = None
elif command == "RETR":
try:
cl.sendall("150 Opening data connection.\r\n")
cl.sendall("226 Transfer complete.\r\n")
except:
dataclient.close()
dataclient = None
elif command == "STOR":
try:
cl.sendall("150 Ok to send data.\r\n")
except:
dataclient.close()
dataclient = None
elif command == "DELE":
try:
uos.remove(path)
except:
elif command == "RMD" or command == "XRMD":
try:
uos.rmdir(path)
except:
elif command == "MKD" or command == "XMKD":
try:
uos.mkdir(path)
except:
elif command == "RNFR":
fromname = path
cl.sendall("350 Rename from\r\n")
elif command == "RNTO":
if fromname is not None:
try:
uos.rename(fromname, path)
except:
else:
fromname = None
elif command == "MDTM":
try:
tm=localtime(uos.stat(path)[8])
cl.sendall('213 {:04d}{:02d}{:02d}{:02d}{:02d}{:02d}\r\n'.format(*tm[0:6]))
except:
cl.sendall('550 Fail\r\n')
elif command == "STAT":
if payload == "":
cl.sendall("211-Connected to ({})\r\n"
" Data address ({})\r\n"
"211 TYPE: Binary STRU: File MODE:"
" Stream\r\n".format(
remote_addr[0], addr))
else:
cl.sendall("213-Directory listing:\r\n")
send_list_data(path, cl, True)
cl.sendall("213 Done.\r\n")
else:
cl.sendall("502 Unsupported command.\r\n")
print("Unsupported command {} with payload {}".format(
command, payload))
except Exception as err:
print(err)
finally:
cl.close()
cl = None
except Exception as e:
print(e)
finally:
datasocket.close()
ftpsocket.close()
dataclient.close()
if __name__ == "__main__":
nic = w5x00_init()
ftpserver(nic)
启动后,先与w5500建立网络连接,然后在设置ftp
在window的文件夹内搜索ftp服务器
