638|2
441
【ACM32G103RCT6开发板测评】+ 移植FreeRTOS系统 [复制链接]
学习下在ACM32G103RCT6开发板上移植FreeRTOS系统。
一、下载源码
下载地址:https://www.freertos.org/zh-cn-cmn-s/a00104.html
二、项目中添加文件
2.1、复制源码
将系统的源码复制到工程目录下,我复制到这里
2.2、工程项目中添加源文件
2.3、添加路径
2.4、FreeRTOSConfig.h
 * FreeRTOS V202212.01
 * Copyright (C) 2020 Amazon.com, Inc. or its affiliates.  All Rights Reserved.
 * Permission is hereby granted, free of charge, to any person obtaining a copy of
 * this software and associated documentation files (the "Software"), to deal in
 * the Software without restriction, including without limitation the rights to
 * use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of
 * the Software, and to permit persons to whom the Software is furnished to do so,
 * subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in all
 * copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
 * FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
 * COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
 * IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
 * CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
 * https://www.FreeRTOS.org
 * https://github.com/FreeRTOS
#ifndef FREERTOS_CONFIG_H
#define FREERTOS_CONFIG_H
 * Application specific definitions.
 * These definitions should be adjusted for your particular hardware and
 * application requirements.
 * THESE PARAMETERS ARE DESCRIBED WITHIN THE 'CONFIGURATION' SECTION OF THE
 * FreeRTOS API DOCUMENTATION AVAILABLE ON THE FreeRTOS.org WEB SITE.
 * See http://www.freertos.org/a00110.html.
/* Ensure definitions are only used by the compiler, and not by the assembler. */
#if defined(__ICCARM__) || defined(__CC_ARM) || defined(__GNUC__)
  #include <stdint.h>
  extern uint32_t SystemCoreClock;
#endif
#define configUSE_PREEMPTION					1
#define configSUPPORT_STATIC_ALLOCATION			0//1
#define configSUPPORT_DYNAMIC_ALLOCATION		1
#define configUSE_IDLE_HOOK						0
#define configUSE_TICK_HOOK						0
#define configCPU_CLOCK_HZ						120000000//( SystemCoreClock )
#define configTICK_RATE_HZ						( ( TickType_t ) 1000 )
#define configMAX_PRIORITIES					( 56 )
#define configMINIMAL_STACK_SIZE				( ( uint16_t ) 512 )
#define configTOTAL_HEAP_SIZE					( ( size_t ) 15 * 1024 )
#define configMAX_TASK_NAME_LEN					( 16 )
#define configUSE_TRACE_FACILITY				1
#define configUSE_16_BIT_TICKS					0
#define configUSE_MUTEXES						1
#define configQUEUE_REGISTRY_SIZE				8
#define configUSE_RECURSIVE_MUTEXES				1
#define configUSE_COUNTING_SEMAPHORES			1
#define configUSE_PORT_OPTIMISED_TASK_SELECTION	0
#define configUSE_MALLOC_FAILED_HOOK			0//1
#define configCHECK_FOR_STACK_OVERFLOW			0//2
/* Defaults to size_t for backward compatibility, but can be changed
 * if lengths will always be less than the number of bytes in a size_t. */
#define configMESSAGE_BUFFER_LENGTH_TYPE		size_t
/* USER CODE END MESSAGE_BUFFER_LENGTH_TYPE */
/* Software timer definitions. */
#define configUSE_TIMERS						1
#define configTIMER_TASK_PRIORITY				( 2 )
#define configTIMER_QUEUE_LENGTH				10
#define configTIMER_TASK_STACK_DEPTH			256
/* Set the following definitions to 1 to include the API function, or zero
 * to exclude the API function. */
#define INCLUDE_vTaskPrioritySet				1
#define INCLUDE_uxTaskPriorityGet				1
#define INCLUDE_vTaskDelete						1
#define INCLUDE_vTaskCleanUpResources			0
#define INCLUDE_vTaskSuspend					1
#define INCLUDE_vTaskDelayUntil					1
#define INCLUDE_vTaskDelay						1
#define INCLUDE_xTaskGetSchedulerState			1
#define INCLUDE_xTimerPendFunctionCall			1
#define INCLUDE_xQueueGetMutexHolder			1
#define INCLUDE_uxTaskGetStackHighWaterMark		1
#define INCLUDE_eTaskGetState					1
/* Cortex-M specific definitions. */
#ifdef __NVIC_PRIO_BITS
	/* __BVIC_PRIO_BITS will be specified when CMSIS is being used. */
	#define configPRIO_BITS						__NVIC_PRIO_BITS
#else
	#define configPRIO_BITS						4
#endif
/* The lowest interrupt priority that can be used in a call to a "set priority"
 * function. */
#define configLIBRARY_LOWEST_INTERRUPT_PRIORITY	15
/* The highest interrupt priority that can be used by any interrupt service
 * routine that makes calls to interrupt safe FreeRTOS API functions.  DO NOT
 * CALL INTERRUPT SAFE FREERTOS API FUNCTIONS FROM ANY INTERRUPT THAT HAS A
 * HIGHER PRIORITY THAN THIS! (higher priorities are lower numeric values. */
#define configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 5
/* Interrupt priorities used by the kernel port layer itself.  These are generic
 * to all Cortex-M ports, and do not rely on any particular library functions. */
#define configKERNEL_INTERRUPT_PRIORITY				( configLIBRARY_LOWEST_INTERRUPT_PRIORITY << ( 8 - configPRIO_BITS ) )
/* !!!! configMAX_SYSCALL_INTERRUPT_PRIORITY must not be set to zero !!!!
See http://www.FreeRTOS.org/RTOS-Cortex-M3-M4.html. */
#define configMAX_SYSCALL_INTERRUPT_PRIORITY		( configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY << ( 8 - configPRIO_BITS ) )
/* Normal assert() semantics without relying on the provision of an assert.h
 * header file. */
#define configASSERT( x )							if ( ( x ) == 0 ) { taskDISABLE_INTERRUPTS(); for( ;; ); }
/* Definitions that map the FreeRTOS port interrupt handlers to their CMSIS
 * standard names. */
#define vPortSVCHandler								SVC_Handler
#define xPortPendSVHandler							PendSV_Handler
//#define xPortSysTickHandler							SysTick_Handler
/* Allow system call from within FreeRTOS kernel only. */
#define configENFORCE_SYSTEM_CALLS_FROM_KERNEL_ONLY	1
/* STM32H743 has 16 MPU regions and therefore it is necessary to configure
 * configTOTAL_MPU_REGIONS correctly. */
#define configTOTAL_MPU_REGIONS						16
/* The default TEX,S,C,B setting marks the SRAM as shareable and as a result,
 * disables cache. Do not mark the SRAM as shareable because caching is being
 * used. TEX=0, S=0, C=1, B=1. */
#define configTEX_S_C_B_SRAM						( 0x03UL )
#endif /* FREERTOS_CONFIG_H */
2.5、修改acm32g103_it.c
*[url=home.php?mod=space&uid=1307177]@File[/url] : acm32g103_it.c
*[url=home.php?mod=space&uid=159083]@brief[/url] : Main Interrupt Service Routines
*           This file provides template for all exceptions handler and
*           peripherals interrupt service routine.
#include "main.h"
#include "acm32g103_it.h"
extern TIM_HandleTypeDef tim2_handler;
extern void xPortSysTickHandler(void);
void NMI_Handler(void)
void HardFault_Handler(void)
    while (1)
void MemManage_Handler(void)
    while (1)
void BusFault_Handler(void)
    while (1)
void UsageFault_Handler(void)
    while (1)
//void SVC_Handler(void)
void DebugMon_Handler(void)
//void PendSV_Handler(void)
*@brief : System tick handler
*@param : none
*@return: none
void SysTick_Handler(void)
	HAL_IncTick();
	if (xTaskGetSchedulerState() != taskSCHEDULER_NOT_STARTED)
		xPortSysTickHandler();
//void EXTI0_IRQHandler(void)
//	HAL_EXTI_IRQHandler(GPIO_PIN_0);
//void EXTI1_IRQHandler(void)
//	HAL_EXTI_IRQHandler(GPIO_PIN_1);
//void EXTI2_IRQHandler(void)
//	HAL_EXTI_IRQHandler(GPIO_PIN_2);
//void EXTI3_IRQHandler(void)
//	HAL_EXTI_IRQHandler(GPIO_PIN_3);
//void EXTI4_IRQHandler(void)
//	HAL_EXTI_IRQHandler(GPIO_PIN_4);
//void EXTI9_5_IRQHandler(void)
//	HAL_EXTI_IRQHandler(GPIO_PIN_5);
//	HAL_EXTI_IRQHandler(GPIO_PIN_6);
//	HAL_EXTI_IRQHandler(GPIO_PIN_7);
//	HAL_EXTI_IRQHandler(GPIO_PIN_8);
//	HAL_EXTI_IRQHandler(GPIO_PIN_9);
//void EXTI15_10_IRQHandler(void)
//	HAL_EXTI_IRQHandler(GPIO_PIN_10);
//	HAL_EXTI_IRQHandler(GPIO_PIN_11);
//	HAL_EXTI_IRQHandler(GPIO_PIN_12);
//	HAL_EXTI_IRQHandler(GPIO_PIN_13);
//	HAL_EXTI_IRQHandler(GPIO_PIN_14);
//	HAL_EXTI_IRQHandler(GPIO_PIN_15);
void TIM2_IRQHandler(void)
    HAL_TIM_IRQHandler(&tim2_handler);
2.6、fun_task.c
#include "main.h"
#define START_TASK_PRO		1
#define START_STK_SIZE		128
TaskHandle_t StartTask_Handler;
#define TASK1_PRIO      4
#define TASK1_STK_SIZE  128
static TaskHandle_t            Task1Task_Handler = NULL;
#define TASK2_PRIO      3
#define TASK2_STK_SIZE  128
static TaskHandle_t            Task2Task_Handler = NULL;
void start_task(void *pvParameters);
void gui_task(void *pvParameters);
void task1(void *pvParameters);
void task2(void *pvParameters);
void task_create(void)
	//start_task
	xTaskCreate((TaskFunction_t )start_task,
							(const char*    )"start_task",
							(uint16_t       )START_STK_SIZE,
							(void*          )NULL,
							(UBaseType_t    )START_TASK_PRO,
							(TaskHandle_t*  )&StartTask_Handler);
	vTaskStartScheduler();
	taskENTER_CRITICAL();
	//task1
	xTaskCreate((TaskFunction_t )task1,
							(const char*    )"task1",
							(uint16_t       )TASK1_STK_SIZE,
							(void*          )NULL,
							(UBaseType_t    )TASK1_PRIO,
							(TaskHandle_t*  )&Task1Task_Handler);
	//task2
	xTaskCreate((TaskFunction_t )task2,
							(const char*    )"task2",
							(uint16_t       )TASK2_STK_SIZE,
							(void*          )NULL,
							(UBaseType_t    )TASK2_PRIO,
							(TaskHandle_t*  )&Task2Task_Handler);
	taskEXIT_CRITICAL();
	vTaskDelete(StartTask_Handler);
//task1
    while (1)
        printf("task1 run ...\r\n");
        vTaskDelay(200);
//task2
    while (1)
        printf("task2 run ...\r\n");
        vTaskDelay(100);
2.7、main.c
#include "main.h"
int main(void)
	HAL_Init();
	SystemClock_Config();
	usart_init(115200);
	printf("\r\n\r\n====== ACM32G103 MCU is runing ======\r\nSysCoreClk: %dHz, HCLK:%dHz\r\nPCLK1:%dHz, PCLK2:%dHz\r\n\r\n",g_SystemCoreClock, HAL_RCC_GetHCLKFreq(),HAL_RCC_GetPCLK1Freq(),HAL_RCC_GetPCLK2Freq());
	init_led();
	init_tim2();
	init_key();
	task_create();
	while(1)
三、程序运行
下载程序到开发板,复位开发板后,串口输出
楼主的帖子,非常优秀!   详情 回复 发表于 2024-1-14 10:46
7056
跑上rtos啦,66666,楼主的帖子,非常优秀!
41
楼主的帖子,非常优秀!
