294|4
216
一起读《深度强化学习实战》- 经验回放、目标网络优化random的Gridworld [复制链接]
定义
  • 强化学习如果只是记忆相同的步骤,那它是没有任何价值的(状态复杂、数据量变大,都将无法有效的记忆),故随机模式下损失函数将变得无法收敛(每次的游戏初始状态都是随机的)
  • 在线训练中,不断地反向传播,从而更新权重,使其loss逐渐变小,达到学习的效果
  • 非常相似的状态-动作对下,得到的Q值不同,会导致对相似(甚至相同的)状态-动作对之前的学习得到的权重被覆盖(白学了),称之灾难性遗忘(catastrophic forgeting)
  • 经验回放,将过去的经验存起来(存到一个双端队列deque),反向传播时使用过去经验的随机子集(避免使用最近一条,造成灾难性遗忘),但结果仍然呈不稳定性。
  • 更新规则中增加目标网络作为维度,以平滑不稳定性,定期同步目标网络和著网络的参数,通过它的Q网络预测的Q值用来反向传播和训练主Q网络
17. Double DQN - Deep Learning Bible - 5. Reinforcement Learning - 한글 (wikidocs.net)
实践
随机模式
将Gridworld的模式切换成random,将随机生成初始状态,再运行loss损失计算,得到如下图
game = Gridworld(size=4, mode='random')
python3 Gridworld-Q-funciton-loss.py,随机模式下的Loss损失并未收敛
灾难性遗忘
增加经验回放解决,由于是随机的状态,增大学习的epochs次数
import numpy as np
import torch
from Gridworld import Gridworld
# from IPython.display import clear_output
import random
from matplotlib import pylab as plt
import math
l1 = 64
l2 = 150
l3 = 100
l4 = 4
model = torch.nn.Sequential(
    torch.nn.Linear(l1, l2),
    torch.nn.ReLU(),
    torch.nn.Linear(l2, l3),
    torch.nn.ReLU(),
    torch.nn.Linear(l3,l4)
loss_fn = torch.nn.MSELoss()
learning_rate = 1e-3
optimizer = torch.optim.Adam(model.parameters(), lr=learning_rate)
gamma = 0.9
epsilon = 0.3
action_set = {
    0: 'u',
    1: 'd',
    2: 'l',
    3: 'r',
from collections import deque
epochs = 5000
losses = []
mem_size = 1000 #A
batch_size = 200 #B
replay = deque(maxlen=mem_size) #C
max_moves = 50 #D
h = 0
for i in range(epochs):
    state1_ = game.board.render_np().reshape(1,64) + np.random.rand(1,64)/100.0
    state1 = torch.from_numpy(state1_).float()
    status = 1
    mov = 0
    while(status == 1):
        mov += 1
        qval = model(state1) #E
        qval_ = qval.data.numpy()
        if (random.random() < epsilon): #F
            action_ = np.random.randint(0,4)
        else:
            action_ = np.argmax(qval_)
        action = action_set[action_]
        game.makeMove(action)
        state2_ = game.board.render_np().reshape(1,64) + np.random.rand(1,64)/100.0
        state2 = torch.from_numpy(state2_).float()
        reward = game.reward()
        done = True if reward > 0 else False
        exp =  (state1, action_, reward, state2, done) #G
        replay.append(exp) #H
        state1 = state2
        if len(replay) > batch_size: #I
            minibatch = random.sample(replay, batch_size) #J
            state1_batch = torch.cat([s1 for (s1,a,r,s2,d) in minibatch]) #K
            action_batch = torch.Tensor([a for (s1,a,r,s2,d) in minibatch])
            reward_batch = torch.Tensor([r for (s1,a,r,s2,d) in minibatch])
            state2_batch = torch.cat([s2 for (s1,a,r,s2,d) in minibatch])
            done_batch = torch.Tensor([d for (s1,a,r,s2,d) in minibatch])
            Q1 = model(state1_batch) #L
            with torch.no_grad():
                Q2 = model(state2_batch) #M
            Y = reward_batch + gamma * ((1 - done_batch) * torch.max(Q2,dim=1)[0]) #N
            X = Q1.gather(dim=1,index=action_batch.long().unsqueeze(dim=1)).squeeze()
            loss = loss_fn(X, Y.detach())
            print(i, loss.item())
            # clear_output(wait=True)
            optimizer.zero_grad()
            loss.backward()
            losses.append(loss.item())
            optimizer.step()
        if reward != -1 or mov > max_moves: #O
            status = 0
            mov = 0
losses = np.array(losses)
plt.figure(figsize=(10,7))
plt.plot(losses)
plt.xlabel("Epochs",fontsize=22)
plt.ylabel("Loss",fontsize=22)
plt.show()
运行后,效果如下,可以看到,逐渐收敛,但仍有较大程度的震荡
目标网络
增加目标网络
import numpy as np
import torch
import random
import math
import copy
l1 = 64
l2 = 150
l3 = 100
l4 = 4
    torch.nn.ReLU(),
    torch.nn.ReLU(),
model2 = copy.deepcopy(model) #A
model2.load_state_dict(model.state_dict()) #B
gamma = 0.9
epsilon = 0.3
action_set = {
    0: 'u',
    1: 'd',
    2: 'l',
    3: 'r',
epochs = 5000
losses = []
mem_size = 1000 #A经验回放内存总大小
batch_size = 200 #B小排量随机自己的大小
replay = deque(maxlen=mem_size) #C经验回放的deque双端队列
max_moves = 50 #D如果单次超过50次还未找到目标就退出
h = 0
sync_freq = 500 #A
j=0
    status = 1
    mov = 0
    while(status == 1):
        j+=1
        mov += 1
        else:
        exp =  (state1, action_, reward, state2, done) #G创建一条状态、动作、奖励、下一个状态的经验
        replay.append(exp) #H塞进队列
        state1 = state2
        if len(replay) > batch_size: #I当经验列表长度大于随机自己大小,开始小批量训练
            minibatch = random.sample(replay, batch_size) #J使用random.sample进行随机抽样子集
            state1_batch = torch.cat([s1 for (s1,a,r,s2,d) in minibatch]) #K,将每一部分抽离成单独的张量,这里是状态张量
            action_batch = torch.Tensor([a for (s1,a,r,s2,d) in minibatch]) #这里是动作张量
            Q1 = model(state1_batch) #L重新计算小批量的Q值,得到梯度
                Q2 = model2(state2_batch) #M计算下一状态的Q值,不计算梯度
            Y = reward_batch + gamma * ((1 - done_batch) * torch.max(Q2,dim=1)[0]) #N计算目标Q值
            X = Q1.gather(dim=1,index=action_batch.long().unsqueeze(dim=1)).squeeze() #gather函数可以通过动作索引获取Q1张量的子集,这样只选择与实际被选择动作相关的Q值
            loss.backward()
            optimizer.step()
            if j % sync_freq == 0: #C
            status = 0
            mov = 0
plt.plot(losses)
plt.show()
视频讲解
谢谢分享,一堆公式,好复杂!   详情 回复 发表于 2023-12-19 20:42
319
先盛赞一下楼主,先收藏起来,慢慢研究研究,顶起来
666  详情 回复 发表于 2023-12-18 15:50
216
chejm 发表于 2023-11-26 20:20 先盛赞一下楼主,先收藏起来,慢慢研究研究,顶起来
666
6754
谢谢分享,一堆公式,好复杂!
公式实际上就几个,其他的都是流程  详情 回复 发表于 2023-12-22 08:06
默认摸鱼,再摸鱼。2022、9、28
216
freebsder 发表于 2023-12-19 20:42 谢谢分享,一堆公式,好复杂!
公式实际上就几个,其他的都是流程
