711|1
504
【ST多款开发板返场测评】STM32F767 Nucleo-144 基于FIFO的串口驱动 [复制链接]
前言
为了方便后面USB调试,所以先实现串口通讯接口,前面进行了串口测试,但是接口不方便使用,需要实现方便应用层使用的串口收发接口。通过实现FIFO方式来实现串口的中断接收,发送为了简单使用查询发送方式。
过程
Bsp层
先实现bsp层的串口接口
Bsp_uart.c/h
初始化
void bsp_uart_init(void)
  GPIO_InitTypeDef  GPIO_InitStruct;
	/* IO Cfg
	 * PD9 USART3_RX
	 * PD8 USART3_TX
	__HAL_RCC_GPIOD_CLK_ENABLE();
  GPIO_InitStruct.Pin = GPIO_PIN_8;
  GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  GPIO_InitStruct.Pull = GPIO_PULLUP;
	GPIO_InitStruct.Alternate = GPIO_AF7_USART3;
	GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
  HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
  GPIO_InitStruct.Pin = GPIO_PIN_9;
  /* Enable USART3 clock */
  __HAL_RCC_USART3_CLK_ENABLE();
	/* USART3 Cfg */
  UartHandle.Instance        = USART3;
  UartHandle.Init.BaudRate   = 115200;
  UartHandle.Init.WordLength = UART_WORDLENGTH_8B;
  UartHandle.Init.StopBits   = UART_STOPBITS_1;
  UartHandle.Init.Parity     = UART_PARITY_NONE;
  UartHandle.Init.HwFlowCtl  = UART_HWCONTROL_NONE;
  UartHandle.Init.Mode       = UART_MODE_TX_RX;
	HAL_UART_Init(&UartHandle);
	/* NVIC */
	HAL_NVIC_EnableIRQ(USART3_IRQn);
	HAL_NVIC_SetPriority(USART3_IRQn,0,1);
	LL_USART_EnableIT_RXNE(USART3);
发送
void uart_sendbyte(uint8_t ch)
	uint8_t tmp =ch;
	HAL_UART_Transmit(&UartHandle,&ch,1,0xFFFFFFFF);
	//LL_USART_TransmitData8(USART3,ch);
void bsp_uart_send(uint8_t* p, uint32_t len)
	HAL_UART_Transmit(&UartHandle,p,len,0xFFFFFFFF);
串口接收中断处理
extern void uart_rx_handler(const uint8_t *buffer, uint32_t length);
void USART3_IRQHandler(void)
	uint8_t ch;
  if(LL_USART_IsActiveFlag_RXNE(USART3) && LL_USART_IsEnabledIT_RXNE(USART3))
    /* RXNE flag will be cleared by reading of RDR register (done in call) */
		ch = LL_USART_ReceiveData8(USART3);
		//while(LL_USART_IsActiveFlag_TC(USART3) == 0);
		uart_rx_handler(&ch, 1);
代码详见
bap_uart.c
#include "stm32f7xx_hal.h"
#include "stm32f7xx_ll_usart.h"
UART_HandleTypeDef UartHandle;
	uint8_t ch;
	uint8_t tmp =ch;
	/* IO Cfg
	 * PD9 USART3_RX
	 * PD8 USART3_TX
	/* USART3 Cfg */
	/* NVIC */
bap_uart.h
#ifndef BSP_UART_H
#define BSP_UART_H
void bsp_uart_init(void);
void bsp_uart_send(uint8_t* p, uint32_t len);
#endif
驱动层
实现FIFO数据结构
typedef struct
        uint32_t datalen_u32;
        uint32_t maxlen_u32;
        uint32_t in_u32;
        uint32_t out_u32;
        uint8_t* buffer_pu8;
}ring_buffer_t;
uint8_t uart_ring_buffer[128];
ring_buffer_t s_ring_buffer_t=
	.datalen_u32 = 0,
	.maxlen_u32 = sizeof(uart_ring_buffer),
  .in_u32 = 0,
  .out_u32 = 0,
  .buffer_pu8 = uart_ring_buffer,
临界段处理
#define Alloc_Critical()
#define Enter_Critical()  __disable_irq()
#define Exit_Critical()   __enable_irq
接收处理,接收中断服务函数中调用
    uint32_t i;
    for(i=0;i<length; i++)
        if(s_ring_buffer_t.datalen_u32 < s_ring_buffer_t.maxlen_u32)
            s_ring_buffer_t.buffer_pu8[s_ring_buffer_t.in_u32] = buffer[i];
            s_ring_buffer_t.datalen_u32++;
            s_ring_buffer_t.in_u32++;
            s_ring_buffer_t.in_u32 %= s_ring_buffer_t.maxlen_u32;
        else
            /* full */
            break;
接收API
uint32_t uart_read(uint8_t *buff, uint32_t len)
    uint32_t readlen = 0;
    //uint32_t mask;
    if(s_ring_buffer_t.datalen_u32 == 0)
        return 0;
		Alloc_Critical();
    Enter_Critical();
    uint32_t i;
    for(i=0;i<len;i++)
			if(s_ring_buffer_t.datalen_u32 > 0)
				buff[i] = s_ring_buffer_t.buffer_pu8[s_ring_buffer_t.out_u32];
				s_ring_buffer_t.datalen_u32--;
				s_ring_buffer_t.out_u32++;
				s_ring_buffer_t.out_u32 %= s_ring_buffer_t.maxlen_u32;
				readlen++;
			else
				break;
    Exit_Critical();
    return readlen;
发送API
int uart_write(uint8_t *buff, uint32_t len)
	uint32_t i;
	for(i=0; i<len ;i++)
		uart_sendbyte(buff[i]);
	return 0;
代码详见
uart.c
#include "uart.h"
#include "bsp_uart.h"
#include "stm32f7xx.h"
#define Exit_Critical()   __enable_irq()
typedef struct
        uint32_t in_u32;
        uint32_t out_u32;
}ring_buffer_t;
	.datalen_u32 = 0,
  .in_u32 = 0,
  .out_u32 = 0,
    uint32_t i;
        else
            /* full */
            break;
    //uint32_t mask;
        return 0;
		Alloc_Critical();
    Enter_Critical();
    uint32_t i;
    for(i=0;i<len;i++)
				readlen++;
			else
				break;
    Exit_Critical();
    return readlen;
	uint32_t i;
	return 0;
uart.h
#ifndef UART_H
#define UART_H
#include <stdint.h>
uint32_t uart_read(uint8_t *buff, uint32_t len);
int uart_write(uint8_t *buff, uint32_t len);
extern void uart_sendbyte(uint8_t ch);
#endif
测试
main.c中
#include "uart.h"
bsp_uart_init();
  uint8_t tx_buffer[2]={0xAA,0x55};
  /* Infinite loop */
  while (1)
uint8_t buffer[128];
for(;;)
uint32_t len=0;
  if((len = uart_read(buffer, sizeof(buffer))) >0)
     uart_write(buffer, len);
使用串口调试助手发送数据,开发板收到原样返回
总结
基于bsp层的串口收发,实现了基于FIFO的串口驱动,给应用层提供串口收发接口,uart.c和uart.h具备可移植性,方便移植到不同平台。方便后面的调试使用。
此帖出自stm32/stm8论坛
谢谢分享,期待后续评测!   详情 回复 发表于 2023-10-30 15:52
7608
谢谢分享,期待后续评测!
此帖出自stm32/stm8论坛
默认摸鱼,再摸鱼。2022、9、28
