775|0
1517
【小华HC32F448测评】+LCD接口直接驱动MDM2802显示模块 [复制链接]
有了前面使用GPIO口驱动MDM2802的基础,这次尝试通过LCD接口来驱动它。
该MDM2802显示模块的引脚连接关系为:
CS : PA4
SCK: PB8
RD : PB9(GND
RST: TCA9539控制
RS : PC13(GND
SDA: PE0
相应的输出高低电平的引脚定义语句为:
#define SET_CLK()      GPIO_SetPins(GPIO_PORT_B, GPIO_PIN_08)   //CLK
#define CLR_CLK()      GPIO_ResetPins(GPIO_PORT_B, GPIO_PIN_08)
#define SET_SDA()      GPIO_SetPins(GPIO_PORT_E, GPIO_PIN_00)   //DIN
#define CLR_SDA()      GPIO_ResetPins(GPIO_PORT_E, GPIO_PIN_00)
#define SET_CS()       GPIO_SetPins(GPIO_PORT_A, GPIO_PIN_04)   //CS
#define CLR_CS()       GPIO_ResetPins(GPIO_PORT_A, GPIO_PIN_04)
#define SET_RD()       GPIO_SetPins(GPIO_PORT_B, GPIO_PIN_09)   //GND
#define CLR_RD()       GPIO_ResetPins(GPIO_PORT_B, GPIO_PIN_09)
#define SET_RS()       GPIO_SetPins(GPIO_PORT_C, GPIO_PIN_13)   //GND
#define CLR_RS()       GPIO_ResetPins(GPIO_PORT_C, GPIO_PIN_13)
对所用引脚的配置函数为:
void Init_TFT(void)
    stc_gpio_init_t stcGpioInit;
    (void)GPIO_StructInit(&stcGpioInit);
    stcGpioInit.u16PinState = PIN_STAT_RST;
    stcGpioInit.u16PinDir = PIN_DIR_OUT;
	(void)GPIO_Init(GPIO_PORT_E, GPIO_PIN_00, &stcGpioInit);
  	(void)GPIO_Init(GPIO_PORT_A, GPIO_PIN_04, &stcGpioInit);
    (void)GPIO_Init(GPIO_PORT_B, GPIO_PIN_08, &stcGpioInit);
  	(void)GPIO_Init(GPIO_PORT_B, GPIO_PIN_09, &stcGpioInit);
    (void)GPIO_Init(GPIO_PORT_C, GPIO_PIN_13, &stcGpioInit);
    CLR_RD();
  	CLR_RS();
显示满屏图像显示的函数为:
void showimage(void)
    int i,j;
    set_cursor(0,0);
	gram_prepare();
    for(j=0;j<320;j++)
          set_cursor(0,j);
          gram_prepare();
	      for(i=0;i<240;i++)
              write_data(gImage_hy[(j*240+i)*2]);
              write_data(gImage_hy[(j*240+i)*2+1]);
实现测试的主程序为:
int32_t main(void)
      LL_PERIPH_WE(LL_PERIPH_GPIO);
	  Init_TFT();
      ili9341_init();
	  ili9341_clear(RED);
  	  showimage_A();
	  DDL_DelayMS(DLY_MS);
      ili9341_clear(RED);
	  LCD_DrawLine(WHITE ,0, 26, 239, 26);
	  LCD_DrawLine(WHITE,0, 296, 239, 296);
	  LCD_DrawRectangle(BLUE,40, 140, 160, 260);
	  Draw_Circle(GREEN,100,200,60);
	  BACK_COLOR=RED;
	  POINT_COLOR=YELLOW;
	  LCD_ShowString(60,10,"MDM-2802 & HC32F448");
	  LCD_ShowString(60,300,"BY: jinglixixi");
      showimage_B();
      while(1);
经程序的编译与下载,其测试效果如图1和图2所示。
图1 显示图片
图2 基本测试
