576|5
1977
ADX516 STM32驱动 [复制链接]
    Analogysemi xutong
    2023/02/15
#include "ADX516.h"
#include "cmsis_os2.h"
static void ADX516_GPIO_Init(void);
void ADX516_READ(uint32_t len, uint8_t *wdata, uint8_t *rdata);
void ADX516_WRITE(uint32_t len, uint8_t *wdata);
// 初始化ADX516
void ADX516_Init(void)
//  ADX516_GPIO_Init();
  //    START_L;
  //    XTAL_H;
//    	ADX516_PWD_L;
     osDelay(1);
//     ADX516_PWD_H;
     ADX516_REST_L;
     osDelay(150);
     ADX516_REST_H;
     osDelay(1);
     ADX516_REST_H;
  GPIO_InitTypeDef GPIO_InitStruct;
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  __HAL_RCC_GPIOG_CLK_ENABLE();
  __HAL_RCC_GPIOF_CLK_ENABLE();
  __HAL_RCC_GPIOD_CLK_ENABLE();
  GPIO_InitStruct.Pin = GPIO_PIN_10 | GPIO_PIN_11;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  HAL_GPIO_WritePin(GPIOA, GPIO_PIN_10 | GPIO_PIN_11, GPIO_PIN_SET);
  GPIO_InitStruct.Pin = GPIO_PIN_10 | GPIO_PIN_15 | GPIO_PIN_14;
  HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
  HAL_GPIO_WritePin(GPIOB, GPIO_PIN_10 | GPIO_PIN_15 | GPIO_PIN_14, GPIO_PIN_SET);
  GPIO_InitStruct.Pin = GPIO_PIN_11 | GPIO_PIN_12;
  HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
  HAL_GPIO_WritePin(GPIOD, GPIO_PIN_11 | GPIO_PIN_12, GPIO_PIN_SET);
  GPIO_InitStruct.Pin = GPIO_PIN_7;
  HAL_GPIO_Init(GPIOF, &GPIO_InitStruct);
  HAL_GPIO_WritePin(GPIOF, GPIO_PIN_7, GPIO_PIN_SET);
  HAL_GPIO_Init(GPIOG, &GPIO_InitStruct);
  GPIO_InitStruct.Pin = GPIO_PIN_9;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  GPIO_InitStruct.Pull = GPIO_PULLUP;
// 获取芯片的ID号
// Adx516 default Value 0x20
uint8_t ADX516_GetChipID(void)
  uint8_t ID;
  ID = ADX516_GetReg(ADX516_STATUS);
  return ID;
// 获取芯片寄存器值
uint8_t ADX516_GetReg(uint8_t Rreg)
  uint8_t TxData[3];
  uint8_t RxData[3];
  // 读取命令,
  TxData[0] = ADX516_RREG | Rreg;
  // 选择要读取的寄存器
  TxData[1] = 0x00;
  // 读取单个寄存器
  TxData[2] = 0X00;
  // 开始读取
  ADX516_READ(3, TxData, RxData);
  // 返回寄存器值
  return RxData[2];
// 写单个芯片寄存器值
void ADX516_WriteReg(uint8_t Wreg, uint8_t Data)
  uint8_t TxData[3];
  // 写入命令,
  TxData[0] = ADX516_WREG | Wreg;
  // 选择要写入的的寄存器
  TxData[1] = 0x00;
  // 读取写入寄存器
  TxData[2] = Data;
  ADX516_WRITE(3, TxData);
// 写多个芯片寄存器值
// StartReg 起始寄存器地址
// RegNum 要写的寄存器数量
//*Data  寄存器参数传入
void ADX516_WriteMultiReg(uint8_t StartReg, uint8_t RegNum, uint8_t *Data)
  uint8_t TxData[32];
  uint8_t i;
  // 写入命令,
  TxData[0] = ADX516_WREG | StartReg;
  // 选择要写入的的寄存器
  TxData[1] = RegNum - 1;
  for (i = 0; i < RegNum; i++)
    // 将指针数据赋值给Txdata
    TxData[2 + i] = *Data;
    // 指向下个数据地址
    Data++;
  // 最终发送多少个数据
  ADX516_WRITE(2 + RegNum, TxData);
// 读多个芯片寄存器值
// StartReg 起始寄存器地址
// RegNum 要写的寄存器数量
//*Data  寄存器参数传出
void ADX516_ReadMultiReg(uint8_t StartReg, uint8_t RegNum, uint8_t *Data)
  // 读取寄存器
  uint8_t TxData[3];
  // 读取命令,
  TxData[0] = ADX516_RREG | StartReg;
  // 选择要写入的的寄存器
  // 最终接收多少个数据
  ADX516_READ(2 + RegNum, TxData, Data);
// 打印所有寄存器地址
void ADX516_GetAllReg(void)
  uint8_t i, j;
  for (i = 0; i < 20; i++)
    j = ADX516_GetReg(i);
    // 打印所有寄存器值
    //    rt_kprintf("reg addr: %d reg default Value: %x\r\n",i,j);
// 发送ADX516 数据指令 如SDATAC或者RDATAC
// 详情见头文件command define部分
void ADX516_Command(uint8_t Com)
  uint8_t TxData[] = {Com};
  ADX516_WRITE(1, TxData);
// 设定通道并且获取adc数据
// 获取ADC的值
void ADX516_GetADC_Value(uint8_t Ch, uint32_t *Rxdata,uint32_t times)
  uint8_t TxData[] = {ADX516_RDATA};
  ADX516_Command(ADX516_SDATAC);
  ADX516_WriteReg(ADX516_MUX, Ch << 4 | 0X0F);
  ADX516_Command(ADX516_SYNC);
  ADX516_Command(ADX516_WAKEUP);
  // rt_thread_mdelay(1);
	osDelay(1);
	for (uint32_t i =0;i<times;i++){
		ADX516_READ(4, TxData, (uint8_t *)&Rxdata[i]);
		Rxdata[i] &=0x00FFFFFF;
		HAL_Delay(3);
  uint8_t buff;
  uint16_t timeout = 10;
  uint8_t RES = 0;
  ADX516_CS_H;
  ADX516_CLK_L;
  HAL_Delay(1);
//  ADX516_CS_L;
//  while(ADX516_DRDY);
  ADX516_CS_L;
  while (timeout--)
  for (uint32_t Num = 0; Num < len; Num++)
    buff = wdata[Num];
		RES = 0;
    for (int i = 7; i >= 0; i--)
      ADX516_CLK_H;
      if (buff & (0x01 << i))
        ADX516_DIN_H;
      else
        ADX516_DIN_L;
			timeout = 2;
      while (timeout--)
			if(ADX516_SDO)
				RES |= (0x1 << i);
			timeout = 3;
      while (timeout--)
      ADX516_CLK_L;
      timeout = 8;
      while (timeout--)
			rdata[len-Num-1]=RES;
  uint8_t buff;
  uint32_t RES = 0;
  ADX516_CS_H;
  ADX516_CLK_L;
  HAL_Delay(1);
  ADX516_CS_L;
  // while(ADX516_SDO);
  // ADX516_CS_L;
  while (timeout--)
    buff = wdata[Num];
        ADX516_DIN_H;
      else
        ADX516_DIN_L;
      ADX516_CLK_H;
			timeout = 5;
      while (timeout--)
      ADX516_CLK_L;
			timeout = 5;
      while (timeout--)
  HAL_Delay(1);
  ADX516_CS_H;
    Analogysemi xutong
    2023/02/15
#include "main.h"
#ifndef __ADX516_H
#define __ADX516_H
    device 需要先写入SDTAC 启动寄存器写入才可以对寄存器进行操作
    在此之前需要检查PWDN以及Reset引脚的状态是否为 高
    在操作完寄存器后,需要发送RDATAC 才能连续 读取数据
    bsp_lpspi 的接口函数如下:
    Lpspi_Write(uint8_t datasize,uint8_t *data);
    Lpspi_Read(uint8_t datasize,uint8_t *data,uint8_t *Rxdata);
    注意:
        Lpspi的时序并不一定满足ADX516的配置,以下配置经过验证
        lpspi_master_config_t config;
        LPSPI_MasterGetDefaultConfig(&config);
        config.whichPcs=kLPSPI_Pcs0;
        config.baudRate=50000;
        config.betweenTransferDelayInNanoSec = 1000000000 /500;
        config.pcsToSckDelayInNanoSec=1000000000 /500;
        config.lastSckToPcsDelayInNanoSec=1000000000 /500;
        config.cpha=kLPSPI_ClockPhaseSecondEdge;
        LPSPI_MasterInit(LPSPI3, &config, LPSPI3_CLOCK_FREQ);
/*command define*/
#define ADX516_REF 2.5
#define ADX516_PGA 1
#define ADX516_LSB (2*ADX516_REF)/(ADX516_PGA*8388607)
#define ADX516_WAKEUP 0x00
#define ADX516_RDATA   0x01
#define ADX516_RDATAC  0x03
#define ADX516_SDATAC  0x0F
#define ADX516_RREG    0x10
#define ADX516_WREG    0X50
#define ADX516_SELFCAL 0XF0
#define ADX516_SELFOCAL 0XF1
#define ADX516_SELFGCAL 0XF2
#define ADX516_SYSOCAL 0XF3
#define ADX516_SYSGCAL 0XF4
#define ADX516_SYNC     0XFC
#define ADX516_STANDBY 0xFD
#define ADX516_RESET   0xFE
//RREG Read n nnnn registers starting at address r rrrr
//First Byte 001r rrrr (2xh)
//Second Byte 000n nnnn
//n nnnn = number of registers to be read or written – 1. For example, to read or write three registers, set n nnnn = 0 (0010). r rrrr = the
//starting register address for read and write commands
//WREG 同上
    寄存器定义
#define  ADX516_STATUS 0x00
#define  ADX516_MUX 0x01
#define  ADX516_ADCON 0x02
#define  ADX516_DRATE 0x03
#define  ADX516_IO 0x04
#define  ADX516_OFC0 0x05
#define  ADX516_OFC1 0x06
#define  ADX516_OFC2 0x07
#define  ADX516_FSC0 0x08
#define  ADX516_FSC1 0x09
#define  ADX516_FSC2 0x0A
#define  ADX516_CFG0 0x0B
#define  ADX516_CFG1 0x0C
#define  ADX516_CFG2 0x0D
#define  ADX516_CFG3 0x0E
#define  ADX516_CFG4 0x0F
#define  ADX516_CFG5 0x10
#define  ADX516_DEV_CFG 0x11
#define  ADX516_MOD_STAT 0x12
#define  ADX516_DEV_STAT 0x13
#define  ADX516_CMD_STAT 0x14
#define ADX516_CLK_PORT GPIOB
#define ADX516_CLK_PIN GPIO_PIN_15
#define ADX516_REST_PORT GPIOD
#define ADX516_REST_PIN GPIO_PIN_12
//#define ADX516_SYN_PORT GPIOB
//#define ADX516_SYN_PIN GPIO_PIN_14
#define ADX516_CS_PORT GPIOB
#define ADX516_CS_PIN GPIO_PIN_14
#define ADX516_DIN_PORT GPIOD
#define ADX516_DIN_PIN GPIO_PIN_11
#define ADX516_DRDY_PORT GPIOA
#define ADX516_DRDY_PIN GPIO_PIN_11
#define ADX516_DO_PORT GPIOG
#define ADX516_DO_PIN GPIO_PIN_9
#define ADX516_SDO   (ADX516_DO_PORT->IDR & ADX516_DO_PIN)
#define ADX516_DRDY   HAL_GPIO_ReadPin(ADX516_DRDY_PORT,ADX516_DRDY_PIN)
#define ADX516_PWD_H  HAL_GPIO_WritePin(ADX516_SYN_PORT,ADX516_SYN_PIN,GPIO_PIN_SET)
#define ADX516_PWD_L  HAL_GPIO_WritePin(ADX516_SYN_PORT,ADX516_SYN_PIN,GPIO_PIN_SET)
#define ADX516_CS_H   HAL_GPIO_WritePin(ADX516_CS_PORT,ADX516_CS_PIN,GPIO_PIN_SET)
#define ADX516_CLK_H  HAL_GPIO_WritePin(ADX516_CLK_PORT,ADX516_CLK_PIN,GPIO_PIN_SET)
#define ADX516_SYN_H  HAL_GPIO_WritePin(ADX516_SYN_PORT,ADX516_SYN_PIN,GPIO_PIN_SET)
#define ADX516_DIN_H  HAL_GPIO_WritePin(ADX516_DIN_PORT,ADX516_DIN_PIN,GPIO_PIN_SET)
#define ADX516_REST_H HAL_GPIO_WritePin(ADX516_REST_PORT,ADX516_REST_PIN,GPIO_PIN_SET)
#define ADX516_CS_L   HAL_GPIO_WritePin(ADX516_CS_PORT,ADX516_CS_PIN,GPIO_PIN_RESET)
#define ADX516_CLK_L  HAL_GPIO_WritePin(ADX516_CLK_PORT,ADX516_CLK_PIN,GPIO_PIN_RESET)
#define ADX516_SYN_L  HAL_GPIO_WritePin(ADX516_SYN_PORT,ADX516_SYN_PIN,GPIO_PIN_RESET)
#define ADX516_DIN_L  HAL_GPIO_WritePin(ADX516_DIN_PORT,ADX516_DIN_PIN,GPIO_PIN_RESET)
#define ADX516_REST_L HAL_GPIO_WritePin(ADX516_REST_PORT,ADX516_REST_PIN,GPIO_PIN_RESET)
  通道配置
  channel config
#define ADX516_ADC_CH0
#pragma anon_unions
typedef  union
	uint32_t data;
	struct
		uint8_t BYTE;
		uint8_t B_W_R;
	  uint8_t ADDR;
		uint8_t A_W_R;
}ADX516_RCOMMAND_TYPE;
typedef  union
	uint32_t data[2];
	struct
		uint16_t IO_DATA;
		uint16_t DATA;
		uint8_t BYTE;
		uint8_t B_W_R;
	  uint8_t ADDR;
		uint8_t A_W_R;
}ADX516_WCOMMAND_TYPE;
//写命令
void ADX516_Command(uint8_t Com);
//获取芯片的ID号
extern uint8_t ADX516_GetChipID(void);
//获取寄存器值
uint8_t ADX516_GetReg(uint8_t Rreg);
//获取多个寄存器值
void ADX516_ReadMultiReg(uint8_t StartReg,uint8_t RegNum,uint8_t *Data);
//写入寄存器值
extern void ADX516_WriteReg(uint8_t Wreg,uint8_t Data);
//写多个寄存器的值
extern void ADX516_WriteMultiReg(uint8_t StartReg,uint8_t RegNum,uint8_t *Data);
//获取所有寄存器值
extern void ADX516_GetAllReg(void);
//设定通道并且获取ADC的值
extern void ADX516_GetADC_Value(uint8_t Ch, uint32_t *Rxdata,uint32_t times);
//初始化ADX516
extern void ADX516_Init(void);
#endif
ADX516的驱动,eeworld备份
此帖出自stm32/stm8论坛
用STM32的驱动SDK就可以了啊 何必那么麻烦呢?哈哈   详情 回复 发表于 2023-9-7 19:41
希望做一些大家觉得好用的东西!
5097
楼主可以分享一下ADX516的基本参数,在.H中的宏定义可以标注寄存器的具体定义,这样拿到驱动后就会知道为什么这样做了。
此帖出自stm32/stm8论坛
下次写的时候更新下,现在先把这些东西搬运过来  详情 回复 发表于 2023-9-7 13:44
1977
lugl4313820 发表于 2023-9-7 12:52 楼主可以分享一下ADX516的基本参数,在.H中的宏定义可以标注寄存器的具体定义,这样拿到驱动后就会知道为什 ...
此帖出自stm32/stm8论坛
希望做一些大家觉得好用的东西!
93
用STM32的驱动SDK就可以了啊
此帖出自stm32/stm8论坛
93
此帖出自stm32/stm8论坛
还有很多人用的不是STM32 方便移植  详情 回复 发表于 2023-9-7 21:01
1977
wang12011201 发表于 2023-9-7 19:41 用STM32的驱动SDK就可以了啊 何必那么麻烦呢?哈哈
还有很多人用的不是STM32 方便移植
此帖出自stm32/stm8论坛
希望做一些大家觉得好用的东西!
猜你喜欢
