853|1
2976
统计数据中1的个数的问题 [复制链接]
verilog程序
module ones(clk,rst,count_1);
input clk;
input rst;
inout reg [3:0]  count_1;
reg [3:0] j;
reg [3:0] i;
reg [3:0] k;
endmodule
test bench程序
`timescale 1 ns/ 1 ps
module ones_vlg_tst();
// constants
// general purpose registers
//reg eachvec;
// test vector input registers
reg clk;
reg [3:0] treg_count_1;
reg rst;
// wires
wire [3:0]  count_1;
reg [3:0] j;
reg [3:0] i;
reg [3:0] k;
reg [3:0] count;
// assign statements (if any)
assign count_1 = treg_count_1;
ones i1 (
// port map - connection between master ports and signals/registers
	.clk(clk),
	.count_1(count_1),
	.rst(rst)
initial
begin
// code that executes only once
// insert code here --> begin
// --> end
$display("Running testbench");
end
initial
// optional sensitivity list
// @(event1 or event2 or .... eventn)
begin
// code executes for every event on sensitivity list
clk=0;
forever
#10 clk=~clk;
// --> end
end
initial
begin
rst=1;
#15 rst=0;
#15 rst=1;
#1000 $stop;
// --> end
end
always @(posedge clk or negedge rst)
begin
if(!rst)
	begin
		i<=4'd0;
		count<=4'd0;
		treg_count_1<=4'd0;
	end
else
	begin
		treg_count_1<=4'd0;
		for(j=0;j<=3;j=j+1)
			begin
				k<=i;
				if((k&4'b0001)==4'b0001)
					begin
						treg_count_1<=treg_count_1+1;
					end
				if((k&4'b0010)==4'b0010)
					begin
					end
				if((k&4'b0100)==4'b0100)
					begin
					end
				if((k&4'b1000)==4'b1000)
					begin
					end
				end
		count<=treg_count_1;
		i<=(i+1);
		$display("%d,%d\n",treg_count_1,count);
		//treg_count_1<=4'd0;
		//count<=4'd0;
	end
end
endmodule
运行结果:
明显不对。请问高手,哪里出错了?谢谢
代码是自己写的? 没个注释自己最了解了   详情 回复 发表于 2023-7-29 09:51
个人签名为江山踏坏了乌骓马,为社稷拉断了宝雕弓。
5202
代码是自己写的?
没个注释自己最了解了
相关帖子
猜你喜欢
