675|6
361
【VisionFive 2:集成3D GPU RISC-V单板计算机】反馈个bug,软件reboot总是卡住? [复制链接]
软件reboot复位,总是卡在如下位置
[  OK  ] Stopped Create System Users.
[  OK  ] Stopped Remount Root and Kernel File Systems.
[  OK  ] Reached target System Shutdown.
[  OK  ] Reached target Late Shutdown Services.
[  OK  ] Finished System Reboot.
[  OK  ] Reached target System Reboot.
[47482.093440] systemd-shutdown[1]: Using hardware watchdog 'StarFive Watchdog', version 0, device /dev/watchdog0
[47482.109363] systemd-shutdown[1]: Failed to set timeout to 10min: Invalid argument
[47482.133053] systemd-shutdown[1]: Syncing filesystems and block devices.
[47482.311780] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[47482.368205] systemd-journald[263]: Received SIGTERM from PID 1 (systemd-shutdow).
[47482.437286] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[47482.459205] systemd-shutdown[1]: Unmounting file systems.
[47482.467478] [4596]: Remounting '/' read-only with options ''.
[47482.562631] EXT4-fs (mmcblk1p4): re-mounted. Opts: (null). Quota mode: disabled.
[47482.624188] systemd-shutdown[1]: All filesystems unmounted.
[47482.636029] systemd-shutdown[1]: Deactivating swaps.
[47482.641214] systemd-shutdown[1]: All swaps deactivated.
[47482.646541] systemd-shutdown[1]: Detaching loop devices.
[47482.660157] systemd-shutdown[1]: All loop devices detached.
[47482.665853] systemd-shutdown[1]: Stopping MD devices.
[47482.671263] systemd-shutdown[1]: All MD devices stopped.
[47482.676684] systemd-shutdown[1]: Detaching DM devices.
[47482.682354] systemd-shutdown[1]: All DM devices detached.
[47482.688021] systemd-shutdown[1]: All filesystems, swaps, loop devices, MD devices and DM devices detached.
[47482.709776] systemd-shutdown[1]: Syncing filesystems and block devices.
[47482.716773] systemd-shutdown[1]: Rebooting.
[47482.772768] reboot: Restarting system
dwmci_s: Response Timeout.
BOOT fail,Error is 0xffffffff
我碰到的一种情形是电源供电能力不足导致reboot卡住,更换PD电源就好了(DC5V - 3A)。   详情 回复 发表于 2023-7-20 10:46
3188
dwmci_s: 响应超时 你是不把啥玩意拔了啊~
没有动任何东西,直接reboot的  详情 回复 发表于 2023-7-17 17:09
361
吾妻思萌 发表于 2023-7-17 16:14 dwmci_s: 响应超时 你是不把啥玩意拔了啊~
没有动任何东西,直接reboot的
咦~那问问官方吧~  详情 回复 发表于 2023-7-17 17:31
3188
没有动任何东西,直接reboot的
咦~那问问官方吧~
qinyunti 发表于 2023-7-17 17:09 没有动任何东西,直接reboot的
可以到RVsapce论坛上发帖问一下
感谢提醒,我换个电源试试  详情 回复 发表于 2023-7-21 10:42
361
卿小小 发表于 2023-7-20 10:46 我碰到的一种情形是电源供电能力不足导致reboot卡住,更换PD电源就好了(DC5V - 3A)。
感谢提醒,我换个电源试试
猜你喜欢
推荐帖子
几款经典的LPC213x/LPC214x开发板原理图
最近在网络上找到了几款经典的LPC213x/LPC214x开发板原理图,感觉非常专业,所以发上来大家分享。 49432 本帖最后由 zhaoju ...
找喜欢流明的ARM芯片的人,和我一起做ARM项目的设计
1. 有没有人愿意参与到我的打印机ARM项目中来。参与本项目可以获得以下提高: 1。 熟悉TI LM3S9B90 ARM 的硬件和软件 设计, ...
第1篇-玩转Thinker Board之Hello MacroBlaze
Thinker Board 第一篇之 Hello MacroBlaze 112593 112590 本帖最后由 sblpp 于 2013-3-4 21:51 编辑 ]
枚举变量与宏的应用
本帖最后由 zhaojun_xf 于 2015-4-17 11:43 编辑 想必会C的网友对枚举和宏的定义与使用并不陌生,对于枚举和宏的区别大家应该 ...
DRV8703-Q1使用方法
本人在TCU的H桥设计软件编写过程中,在刷写H桥软件进入前,DRV8703-Q1温度为常温,正常;但是在刷写进入H桥相关软件后,DRV8703- ...
调了下ufun的三轴
加速度: -278mg 加速度: -37mg 加速度: 985mg 角度: -15.77° 角度: -2.16° 角度: 89.12° 加速度: -274mg 加速度: - ...
“a data verification error occurred, file load failed”可行性解决方案
# AM5708的DSP核在Debug仿真时出现“a data verification error occurred, file load failed”可行性解决方案 ##一、问题描述 ...
高精度湿度和温度传感器
SENSIRION SHT45 高精度湿度和温度传感器提供更高的精度,采用卷带包装,并适用于标准 SMD 组装工艺。该器件基于全新优化的 CM ...
【语音识别定位】物料开箱-ESP32-S2-KALUGA-1
很早就听闻ESP32系列芯片的强大,但是工作中确无缘使用,正好借这次得捷设计大赛的机会,接触一下ESP32,也为以后的工作方案多增 ...
