705|2
303
【极海APM32F407 Tiny Board】lwip之tcp client通信 [复制链接]
这篇来测试下是tcp client通信测试。
在上篇http://bbs.eeworld.com.cn/thread-1245099-1-1.html移植LWIP基础上,增加tcp clent通信的测试。
tcp client模式下,客户端程序主动发起连接请求,向服务器发送请求信息,并等待服务器响应。一旦建立连接成功,客户端和服务器就可以相互发送和接收数据。
一、硬件连接
开发板的网口和PC机,同处一个IP段,测试tcp client模式下的数据通信。
二、程序部分
2.1、echo.c
/** This file was modified by Geehy Semiconductor */
#include "lwip/opt.h"
#include "lwip/debug.h"
#include "lwip/stats.h"
#include "lwip/tcp.h"
#include "echo_c.h"
#include <stdlib.h>
#include <string.h>
#if LWIP_TCP
static struct tcp_pcb *tcpc_echo_pcb;
enum tcpc_echo_states
  ES_NONE = 0,
  ES_ACCEPTED,
  ES_RECEIVED,
  ES_CLOSING
struct tcpc_echo_state
  u8_t state;
  u8_t retries;
  struct tcp_pcb *pcb;
  /* pbuf (chain) to recycle */
  struct pbuf *p;
struct tcpc_echo_state * tcpc_echo_es;
uint8_t testdata[50] = "TCP Client to connect server";
err_t tcpc_echo_accept(void *arg, struct tcp_pcb *newpcb, err_t err);
err_t tcpc_echo_recv(void *arg, struct tcp_pcb *tpcb, struct pbuf *p, err_t err);
void tcpc_echo_error(void *arg, err_t err);
err_t tcpc_echo_poll(void *arg, struct tcp_pcb *tpcb);
err_t tcpc_echo_sent(void *arg, struct tcp_pcb *tpcb, u16_t len);
void tcpc_echo_send(struct tcp_pcb *tpcb, struct tcpc_echo_state *es);
void tcpc_echo_close(struct tcp_pcb *tpcb, struct tcpc_echo_state *es);
void PrintfRecData(struct pbuf *p);
 * @brief   tcp client init
 * @param       tcpc_port£o client port
 * @param       ipaddr£o point to the client ip address
 * @retval      None
void
tcpc_echo_init(ip_addr_t *ipaddr,uint16_t tcpc_port)
  tcpc_echo_pcb = tcp_new();
  if (tcpc_echo_pcb != NULL)
    /* connect to server address£oport */
    tcp_connect(tcpc_echo_pcb,ipaddr,tcpc_port,tcpc_echo_accept);
  else
    /* abort? output diagnostic? */
 * @brief       closes tcp client
 * @param       None
 * @retval      None
void tcpc_echo_disable(void)
    tcpc_echo_close(tcpc_echo_pcb,tcpc_echo_es);
 * @brief       Printf TCP Receive Data
 * @param       p: pointer on the tcp pcb received pbuf
 * @retval      None
    char recbuf[100] = {0};
    memcpy(recbuf,p->payload,p->len);
    printf("received message:%s\r\n",recbuf);
 * @brief       LwIP tcp_accept callback function
 * @param       newpcb: point to the newly created tcp pcb
 * @retval      None
err_t
  err_t ret_err;
  struct tcpc_echo_state *es;
  LWIP_UNUSED_ARG(arg);
  LWIP_UNUSED_ARG(err);
  /* Unless this pcb should have NORMAL priority, set its priority now.
     When running out of pcbs, low priority pcbs can be aborted to create
     new pcbs of higher priority. */
  tcp_setprio(newpcb, TCP_PRIO_MIN);
  es = (struct tcpc_echo_state *)mem_malloc(sizeof(struct tcpc_echo_state));
  tcpc_echo_es=es;
  if (es != NULL)
    es->state = ES_ACCEPTED;
    es->pcb = newpcb;
    es->retries = 0;
    es->p = NULL;
    /* pass newly allocated es to our callbacks */
    tcp_arg(newpcb, es);
    tcp_recv(newpcb, tcpc_echo_recv);
    tcp_err(newpcb, tcpc_echo_error);
    tcp_poll(newpcb, tcpc_echo_poll, 0);
	/** Allocates the pbuf of the given type */
    es->p = pbuf_alloc(PBUF_TRANSPORT, strlen((char*)testdata) , PBUF_POOL);
    /** copy data to pbuf */
    pbuf_take(es->p, (char*)testdata, strlen((char*)testdata));
	/** send data */
    tcp_sent(newpcb, tcpc_echo_sent);
    tcpc_echo_send(newpcb,es);
    ret_err = ERR_OK;
  else
    /** close tcp connection */
    tcpc_echo_close(newpcb, es);
    ret_err = ERR_MEM;
  return ret_err;
 * @brief       LwIP tcp_recv callback function
 * @param       None
 * @retval      None
err_t
  err_t ret_err;
  LWIP_ASSERT("arg != NULL",arg != NULL);
  es = (struct tcpc_echo_state *)arg;
  if (p == NULL)
    /* remote host closed connection */
    es->state = ES_CLOSING;
    if(es->p == NULL)
       /* we're done sending, close it */
       tcpc_echo_close(tpcb, es);
    else
      /* we're not done yet */
      tcp_sent(tpcb, tcpc_echo_sent);
      tcpc_echo_send(tpcb, es);
    ret_err = ERR_OK;
  else if(err != ERR_OK)
    /* cleanup, for unkown reason */
    if (p != NULL)
      es->p = NULL;
      pbuf_free(p);
    ret_err = err;
  else if(es->state == ES_ACCEPTED)
    tcp_recved(tpcb, p->tot_len);
    /** Printf TCP Receive Data */
    PrintfRecData(p);
    es->p = NULL;
    pbuf_free(p);
    ret_err = ERR_OK;
  else
    /* unkown es->state, trash data  */
    es->p = NULL;
    pbuf_free(p);
    ret_err = ERR_OK;
  return ret_err;
 * @brief       LwIP tcp_err callback function
 * @param       None
 * @retval      None
void
  if (es != NULL)
    mem_free(es);
 * @brief       LwIP tcp_poll callback function
 * @param       None
 * @retval      None
err_t
  err_t ret_err;
  if (es != NULL)
    if (es->p != NULL)
      /* there is a remaining pbuf (chain)  */
    else
      /* no remaining pbuf (chain)  */
      if(es->state == ES_CLOSING)
    ret_err = ERR_OK;
  else
    /* nothing to be done */
    tcp_abort(tpcb);
    ret_err = ERR_ABRT;
  return ret_err;
 * @brief       LwIP tcp_sent callback function
 * @param       None
 * @retval      None
err_t
  LWIP_UNUSED_ARG(len);
  es->retries = 0;
  if(es->p != NULL)
    /* still got pbufs to send */
  else
    /* no more pbufs to send */
  return ERR_OK;
 * @brief       tcp send data function
 * @param       tpcb: point to the tcp pcb
 * @param       es: point to tcps_echo_state structure
 * @retval      None
void
  struct pbuf *ptr;
  err_t wr_err = ERR_OK;
  while ((wr_err == ERR_OK) &&
         (es->p != NULL) &&
         (es->p->len <= tcp_sndbuf(tpcb)))
  ptr = es->p;
  /* enqueue data for transmission */
  wr_err = tcp_write(tpcb, ptr->payload, ptr->len, 1);
  if (wr_err == ERR_OK)
     //u16_t plen;
      u8_t freed;
     //plen = ptr->len;
     /* continue with next pbuf in chain (if any) */
     es->p = ptr->next;
     if(es->p != NULL)
       /* new reference! */
       pbuf_ref(es->p);
     /* chop first pbuf from chain */
      do
        /* try hard to free pbuf */
        freed = pbuf_free(ptr);
      while(freed == 0);
      // /* we can read more data now */
      // tcp_recved(tpcb, plen);
   else if(wr_err == ERR_MEM)
      /* we are low on memory, try later / harder, defer to poll */
     es->p = ptr;
   else
     /* other problem ?? */
 * @brief       closes tcp pcb function
 * @retval      None
void
  tcp_arg(tpcb, NULL);
  tcp_sent(tpcb, NULL);
  tcp_recv(tpcb, NULL);
  tcp_err(tpcb, NULL);
  tcp_poll(tpcb, NULL, 0);
  if (es != NULL)
    mem_free(es);
  tcp_close(tpcb);
#endif /* LWIP_TCP */
2.2、echo.h
#ifndef __ECHO_H__
#define __ECHO_H__
#include "main.h"
void tcpc_echo_init(ip_addr_t *ipaddr,uint16_t tcpc_port);
void tcpc_echo_disable(void);
#endif /* __MINIMAL_ECHO_H */
2.3、main.c
#include "main.h"
#include "Board.h"
#include "oled.h"
#include "stdio.h"
#include "usart.h"
#include "echo_c.h"
/** Global pointers on Rx descriptor used to transmit and receive descriptors */
extern ETH_DMADescConfig_T  *DMARxDescToGet;
/** current Ethernet LocalTime value */
volatile uint32_t ETHTimer = 0;
/** lwip network interface structure for ethernetif */
struct netif UserNetif;
/** TCP periodic Timer */
uint32_t TCPTimer = 0;
/** ARP periodic Timer */
uint32_t ARPTimer = 0;
/** MAC address */
uint8_t SetMACaddr[6] = {0,0,0,0,0,8};
int main(void)
	ip4_addr_t destipaddr;
	SysTick_Init();
	init_led();
	init_usart();
	ConfigEthernet();
	LwIP_Init();
	led2_off();
	led3_on();
	IP4_ADDR(&destipaddr, 192, 168, 1, 112);
	tcpc_echo_init(&destipaddr,5000);
	printf("server ip : %d.%d.%d.%d :%d  \r\n",192,168,1,112,5000);
	while (1)
		/** check if any packet received */
			if (ETH_ReadRxPacketSize(DMARxDescToGet))
					/** process received ethernet packet */
					LwIP_Pkt_Handle();
					/** handle periodic timers for LwIP */
			LwIP_Periodic_Handle(ETHTimer);
void LwIP_Init(void)
	ip4_addr_t ipaddr;
	ip4_addr_t netmask;
	ip4_addr_t gw;
    /** Initializes the dynamic memory heap */
    mem_init();
    /** Initializes the memory pools */
    memp_init();
    IP4_ADDR(&ipaddr, 192, 168, 1, 22);
    IP4_ADDR(&netmask, 255, 255 , 255, 0);
    IP4_ADDR(&gw, 192, 168, 1, 1);
    /** Config MAC Address */
    ETH_ConfigMACAddress(ETH_MAC_ADDRESS0, SetMACaddr);
    /** Add a network interface to the list of lwIP netifs */
    netif_add(&UserNetif, &ipaddr, &netmask, &gw, NULL, ðernetif_init, ðernet_input);
    /** Registers the default network interface */
    netif_set_default(&UserNetif);
    /** When the netif is fully configured this function must be called */
    netif_set_up(&UserNetif);
    /** Use Com printf static IP address*/
    printf("\n  Static IP address   \r\n");
    printf("IP: %d.%d.%d.%d\r\n",192,168,1,22);
    printf("NETMASK: %d.%d.%d.%d\r\n",255,255,255,0);
    printf("Gateway: %d.%d.%d.%d\r\n",192,168,1,1);
 * @brief       This function received ethernet packet
 * @param       None
 * @retval      None
void LwIP_Pkt_Handle(void)
  /** Read a received packet from the Ethernet buffers and send it to the lwIP for handling */
  ethernetif_input(&UserNetif);
 * @brief       This function LwIP periodic tasks
 * @param       ETHTimer the current Ethernet Timer value
 * @retval      None
void LwIP_Periodic_Handle(__IO uint32_t ETHTimer)
#if LWIP_TCP
    /** TCP periodic process every 250 ms */
    if (ETHTimer - TCPTimer >= TCP_TMR_INTERVAL)
        TCPTimer =  ETHTimer;
        tcp_tmr();
#endif
    /** ARP periodic process every 5s */
    if ((ETHTimer - ARPTimer) >= ARP_TMR_INTERVAL)
        ARPTimer =  ETHTimer;
        etharp_tmr();
三、程序运行
3.1、打开调试助手,设置tcp server模式
3.2、复位开发板,上电后,自动连接服务器,串口调试助手发送数据,开发板串口输出接收的信息。
四、工程文件
apm32f407i_prj.rar (11.14 MB, 下载次数: 1)
能把工程发一下我吗?我的网络调试不通,着急啊   详情 回复 发表于 2023-6-14 21:10
263
好的,我已经上传到帖子里了。  详情 回复 发表于 2023-6-15 08:10
gitee/casy
303
caizhiwei 发表于 2023-6-14 21:10 能把工程发一下我吗?我的网络调试不通,着急啊
好的,我已经上传到帖子里了。
