546|2
【得捷电子Follow me第1期】-2- 驱动外设OLED屏幕 [复制链接]
本文主要讲如何通过micropython让RP2040控制GROVE OLED扩展板。这个OLED扩展板使用的是SSD1315,而大家最熟悉的莫过于SSD1306。这两者分辨率都是128*64,电压都在3.3v,实际上它们可以互相替代,但是价格上SSD1315会比SSD1306便宜,毕竟使用的人少。
从上图可以看出,这款OLED屏幕可以使用IIC接口控制。 下面是本文使用的OLED SSD1315驱动,尤其要注意105行的addr= 0x3C,这个0x3C就是本实验OLED屏幕的7位I2C地址。
# MicroPython SSD1315 OLED driver, I2C and SPI interfaces
from micropython import const
import framebuf
# register definitions
SET_CONTRAST = const(0x81)
SET_ENTIRE_ON = const(0xA4)
SET_NORM_INV = const(0xA6)
SET_DISP = const(0xAE)
SET_MEM_ADDR = const(0x20)
SET_COL_ADDR = const(0x21)
SET_PAGE_ADDR = const(0x22)
SET_DISP_START_LINE = const(0x40)
SET_SEG_REMAP = const(0xA0)
SET_MUX_RATIO = const(0xA8)
SET_COM_OUT_DIR = const(0xC0)
SET_DISP_OFFSET = const(0xD3)
SET_COM_PIN_CFG = const(0xDA)
SET_DISP_CLK_DIV = const(0xD5)
SET_PRECHARGE = const(0xD9)
SET_VCOM_DESEL = const(0xDB)
SET_CHARGE_PUMP = const(0x8D)
# Subclassing FrameBuffer provides support for graphics primitives
# http://docs.micropython.org/en/latest/pyboard/library/framebuf.html
class SSD1315(framebuf.FrameBuffer):
    def __init__(self, width, height, external_vcc):
        self.width = width
        self.height = height
        self.external_vcc = external_vcc
        self.pages = self.height // 8
        self.buffer = bytearray(self.pages * self.width)
        super().__init__(self.buffer, self.width, self.height, framebuf.MONO_VLSB)
        self.init_display()
    def init_display(self):
        for cmd in (
            SET_DISP | 0x00,  # off
            # address setting
            SET_MEM_ADDR,
            0x00,  # horizontal
            # resolution and layout
            SET_DISP_START_LINE | 0x00,
            SET_SEG_REMAP | 0x01,  # column addr 127 mapped to SEG0
            SET_MUX_RATIO,
            self.height - 1,
            SET_COM_OUT_DIR | 0x08,  # scan from COM[N] to COM0
            SET_DISP_OFFSET,
            0x00,
            SET_COM_PIN_CFG,
            0x02 if self.width > 2 * self.height else 0x12,
            # timing and driving scheme
            SET_DISP_CLK_DIV,
            0x80,
            SET_PRECHARGE,
            0x22 if self.external_vcc else 0xF1,
            SET_VCOM_DESEL,
            0x30,  # 0.83*Vcc
            # display
            SET_CONTRAST,
            0xFF,  # maximum
            SET_ENTIRE_ON,  # output follows RAM contents
            SET_NORM_INV,  # not inverted
            # charge pump
            SET_CHARGE_PUMP,
            0x10 if self.external_vcc else 0x14,
            SET_DISP | 0x01,
        ):  # on
            self.write_cmd(cmd)
        self.fill(0)
        self.show()
    def poweroff(self):
        self.write_cmd(SET_DISP | 0x00)
    def poweron(self):
        self.write_cmd(SET_DISP | 0x01)
    def contrast(self, contrast):
        self.write_cmd(SET_CONTRAST)
        self.write_cmd(contrast)
    def invert(self, invert):
        self.write_cmd(SET_NORM_INV | (invert & 1))
    def show(self):
        x0 = 0
        x1 = self.width - 1
        if self.width == 64:
            # displays with width of 64 pixels are shifted by 32
            x0 += 32
            x1 += 32
        self.write_cmd(SET_COL_ADDR)
        self.write_cmd(x0)
        self.write_cmd(x1)
        self.write_cmd(SET_PAGE_ADDR)
        self.write_cmd(0)
        self.write_cmd(self.pages - 1)
        self.write_data(self.buffer)
class SSD1315_I2C(SSD1315):
    def __init__(self, width, height, i2c, addr=0x3C, external_vcc=False):
        self.i2c = i2c
        self.addr = addr
        self.temp = bytearray(2)
        self.write_list = [b"\x40", None]  # Co=0, D/C#=1
        super().__init__(width, height, external_vcc)
    def write_cmd(self, cmd):
        self.temp[0] = 0x80  # Co=1, D/C#=0
        self.temp[1] = cmd
        self.i2c.writeto(self.addr, self.temp)
    def write_data(self, buf):
        self.write_list[1] = buf
        self.i2c.writevto(self.addr, self.write_list)
class SSD1315_SPI(SSD1315):
    def __init__(self, width, height, spi, dc, res, cs, external_vcc=False):
        self.rate = 10 * 1024 * 1024
        dc.init(dc.OUT, value=0)
        res.init(res.OUT, value=0)
        cs.init(cs.OUT, value=1)
        self.spi = spi
        self.dc = dc
        self.res = res
        self.cs = cs
        import time
        self.res(1)
        time.sleep_ms(1)
        self.res(0)
        time.sleep_ms(10)
        self.res(1)
        self.spi.init(baudrate=self.rate, polarity=0, phase=0)
        self.cs(1)
        self.dc(0)
        self.cs(0)
        self.spi.write(bytearray([cmd]))
        self.cs(1)
        self.cs(1)
        self.dc(1)
        self.cs(0)
        self.spi.write(buf)
        self.cs(1)
有了这个驱动库,接下来就可以编写相应的屏幕应用程序了
from machine import Pin, I2C
from ssd1315_goBro import SSD1315_I2C
i2c=I2C(0,sda=Pin(8), scl=Pin(9), freq=400000)
oled = SSD1315_I2C(128, 64, i2c)
oled.text("WELCOME!", 0, 0)
oled.text("This is EEWORLD", 0, 16)
oled.text("FOLLOW ME", 0, 32)
oled.text("JOIN US", 0, 48)
oled.show()
第一行引入Pin, I2C两个子模块,后面可以作为库来使用;
第二行引入SSD1315_I2C,方便后续对OLED屏幕进行初始化,清屏等控制
第四行初始化一个i2c实例,
第五行初始化一个SSD1315_I2C实例,同时传入屏幕的分辨率以及I2C实例作为参数。
接下来就可以愉快的控制屏幕咯!下面是效果图:
image.png   Grove - OLED Display 0.96 (SSD1315)_v1.0.zip (109.42 KB, 下载次数: 3)
好吧,要注意105行的addr= 0x3C,这个0x3C就是本实验OLED屏幕的7位I2C地址。   详情 回复 发表于 2023-6-7 07:32
5202
对的,板子标的是0x78 即 0b' 0111-1000 最后一位为0的时候表示写,最后一位为1的时候表示读数据。在micropython库中初始化i2c设备的时候,只需要传入ssd1315的7位地址即可,即去掉最后一位剩下的:0b'01  详情 回复 发表于 2023-6-7 08:30
Jacktang 发表于 2023-6-7 07:32 好吧,要注意105行的addr= 0x3C,这个0x3C就是本实验OLED屏幕的7位I2C地址。
最后一位为0的时候表示写,最后一位为1的时候表示读数据。在micropython库中初始化i2c设备的时候,只需要传入ssd1315的7位地址即可,即去掉最后一位剩下的:0b'0111-100 (0x3C)
相关帖子
猜你喜欢
