【得捷电子Follow me第1期】第三贴:GPS定位
GPS定位信息
我们找到examples/gps_simpletest.py文件并打开,然后将Uart引脚修改成Uart0的GP0和GP1引脚,修改后的代码如下
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
# SPDX-License-Identifier: MIT
# Simple GPS module demonstration.
# Will wait for a fix and print a message every second with the current location
# and other details.
import time
import board
import busio
import adafruit_gps
# Create a serial connection for the GPS connection using default speed and
# a slightly higher timeout (GPS modules typically update once a second).
# These are the defaults you should use for the GPS FeatherWing.
# For other boards set RX = GPS module TX, and TX = GPS module RX pins.
uart = busio.UART(board.GP0, board.GP1, baudrate=9600, timeout=10)
# for a computer, use the pyserial library for uart access
# import serial
# uart = serial.Serial("/dev/ttyUSB0", baudrate=9600, timeout=10)
# If using I2C, we'll create an I2C interface to talk to using default pins
# i2c = board.I2C() # uses board.SCL and board.SDA
# i2c = board.STEMMA_I2C() # For using the built-in STEMMA QT connector on a microcontroller
# Create a GPS module instance.
gps = adafruit_gps.GPS(uart, debug=False) # Use UART/pyserial
# gps = adafruit_gps.GPS_GtopI2C(i2c, debug=False) # Use I2C interface
# Initialize the GPS module by changing what data it sends and at what rate.
# These are NMEA extensions for PMTK_314_SET_NMEA_OUTPUT and
# PMTK_220_SET_NMEA_UPDATERATE but you can send anything from here to adjust
# the GPS module behavior:
# https://cdn-shop.adafruit.com/datasheets/PMTK_A11.pdf
# Turn on the basic GGA and RMC info (what you typically want)
gps.send_command(b"PMTK314,0,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0")
# Turn on just minimum info (RMC only, location):
# gps.send_command(b'PMTK314,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0')
# Turn off everything:
# gps.send_command(b'PMTK314,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0')
# Turn on everything (not all of it is parsed!)
# gps.send_command(b'PMTK314,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0')
# Set update rate to once a second (1hz) which is what you typically want.
gps.send_command(b"PMTK220,1000")
# Or decrease to once every two seconds by doubling the millisecond value.
# Be sure to also increase your UART timeout above!
# gps.send_command(b'PMTK220,2000')
# You can also speed up the rate, but don't go too fast or else you can lose
# data during parsing. This would be twice a second (2hz, 500ms delay):
# gps.send_command(b'PMTK220,500')
# Main loop runs forever printing the location, etc. every second.
last_print = time.monotonic()
while True:
# Make sure to call gps.update() every loop iteration and at least twice
# as fast as data comes from the GPS unit (usually every second).
# This returns a bool that's true if it parsed new data (you can ignore it
# though if you don't care and instead look at the has_fix property).
gps.update()
# Every second print out current location details if there's a fix.
current = time.monotonic()
if current - last_print >= 1.0:
last_print = current
if not gps.has_fix:
# Try again if we don't have a fix yet.
print("Waiting for fix...")
continue
# We have a fix! (gps.has_fix is true)
# Print out details about the fix like location, date, etc.
print("=" * 40) # Print a separator line.
print(
"Fix timestamp: {}/{}/{} {:02}:{:02}:{:02}".format(
gps.timestamp_utc.tm_mon, # Grab parts of the time from the
gps.timestamp_utc.tm_mday, # struct_time object that holds
gps.timestamp_utc.tm_year, # the fix time. Note you might
gps.timestamp_utc.tm_hour, # not get all data like year, day,
gps.timestamp_utc.tm_min, # month!
gps.timestamp_utc.tm_sec,
print("Latitude: {0:.6f} degrees".format(gps.latitude))
print("Longitude: {0:.6f} degrees".format(gps.longitude))
print(
"Precise Latitude: {:2.}{:2.4f} degrees".format(
gps.latitude_degrees, gps.latitude_minutes
print(
"Precise Longitude: {:2.}{:2.4f} degrees".format(
gps.longitude_degrees, gps.longitude_minutes
print("Fix quality: {}".format(gps.fix_quality))
# Some attributes beyond latitude, longitude and timestamp are optional
# and might not be present. Check if they're None before trying to use!
if gps.satellites is not None:
print("# satellites: {}".format(gps.satellites))
if gps.altitude_m is not None:
print("Altitude: {} meters".format(gps.altitude_m))
if gps.speed_knots is not None:
print("Speed: {} knots".format(gps.speed_knots))
if gps.track_angle_deg is not None:
print("Track angle: {} degrees".format(gps.track_angle_deg))
if gps.horizontal_dilution is not None:
print("Horizontal dilution: {}".format(gps.horizontal_dilution))
if gps.height_geoid is not None:
print("Height geoid: {} meters".format(gps.height_geoid))
#while True:
# pass
然后将设备插上充电宝供电,并使用web调试页面查看串口信息,经过半分钟的搜星,就可以顺利获取到时间和GPS定位信息了。
使用CircuitPython就是这样简单粗暴,开心得不行
