708|1
1170
59
【先楫HPM6750EVK2测评】硬件spi驱动ad9833波形发生器芯片 [复制链接]
例程提供了SPI主机轮询的参考代码,根据例程修改,能够十分简单的将1SPI接口应用起来,这里驱动常见的SPI接口DDS芯片AD9833代码如下:
 * Copyright (c) 2021 HPMicro
 * SPDX-License-Identifier: BSD-3-Clause
#include "board.h"
#include "hpm_debug_console.h"
#include "hpm_spi_drv.h"
#include "hpm_clock_drv.h"
#define FMCLK 25000000        // Master Clock On AD9833
enum WaveType{SIN, SQR, TRI}; // Wave Selection Enum
uint16_t FRQLW = 0;    // MSB of Frequency Tuning Word
uint16_t FRQHW = 0;    // LSB of Frequency Tuning Word
uint32_t  phaseVal=0;  // Phase Tuning Value
uint8_t WKNOWN=0;      // Flag Variable
// -------------------------------- Functions --------------------------------
// ------------------------------------------------ Software SPI Function
void writeSPI(uint16_t word)
    hpm_stat_t stat = spi_write_data(BOARD_APP_SPI_BASE, 2, &word, 2);
    if (stat == status_success)
        printf("SPI-Master transfer ends.\n");
    else
        printf("SPI-Master transfer error[%d]!\n", stat);
// ------------------------------------------------ Sets Output Wave Type
void AD9833_SetWave(uint16_t Wave)
  switch(Wave){
  case 0:
    writeSPI(0x2000); // Value for Sinusoidal Wave
    WKNOWN=0;
    break;
  case 1:
    writeSPI(0x2028); // Value for Square Wave
    WKNOWN=1;
    break;
  case 2:
    writeSPI(0x2002); // Value for Triangle Wave
    WKNOWN=2;
    break;
  default:
    break;
// ------------------------------------------------ Sets Wave Frequency & Phase (In Degree) In PHASE0 & FREQ0 Registers
void AD9833_SetWaveData(float Frequency,float Phase)
  // ---------- Tuning Word for Phase ( 0 - 360 Degree )
  if(Phase<0)Phase=0; // Changing Phase Value to Positive
  if(Phase>360)Phase=360; // Maximum value For Phase (In Degree)
  phaseVal  = ((int)(Phase*(4096/360)))|0XC000;  // 4096/360 = 11.37 change per Degree for Register And using 0xC000 which is Phase 0 Register Address
  // ---------- Tuning word for Frequency
  long freq=0;
  freq=(int)(((Frequency*pow(2,28))/FMCLK)+1); // Tuning Word
  FRQHW=(int)((freq & 0xFFFC000) >> 14); // FREQ MSB
  FRQLW=(int)(freq & 0x3FFF);  // FREQ LSB
  FRQLW |= 0x4000;
  FRQHW |= 0x4000;
  // ------------------------------------------------ Writing DATA
  writeSPI(0x2100); // enable 16bit words and set reset bit
  writeSPI(FRQLW);
  writeSPI(FRQHW);
  writeSPI(phaseVal);
  writeSPI(0x2000); // clear reset bit
  AD9833_SetWave(WKNOWN);
  return;
// ------------------------------------------------ Initializing AD9833
void AD9833_Init(uint16_t WaveType,float FRQ,float Phase)
  AD9833_SetWave(WaveType);                              // Type Of Wave
  AD9833_SetWaveData(FRQ,Phase);                         // Frequency & Phase Set
  return;
int main(void)
    uint8_t wbuff[10] = {0xa0, 0xa1, 0xa2, 0xa3, 0xa4, 0xa5, 0xa6, 0xa7, 0xa8, 0xa9};
    uint8_t rbuff[10] = {0};
    spi_timing_config_t timing_config = {0};
    spi_format_config_t format_config = {0};
    spi_control_config_t control_config = {0};
    hpm_stat_t stat;
    /* bsp initialization */
    board_init();
    board_init_spi_clock(BOARD_APP_SPI_BASE);
    board_init_spi_pins(BOARD_APP_SPI_BASE);
    printf("SPI-Master Polling Transfer Example\n");
    /* set SPI sclk frequency for master */
    spi_master_get_default_timing_config(&timing_config);
    timing_config.master_config.clk_src_freq_in_hz = clock_get_frequency(BOARD_APP_SPI_CLK_NAME);;
    timing_config.master_config.sclk_freq_in_hz = BOARD_APP_SPI_SCLK_FREQ;
    spi_master_timing_init(BOARD_APP_SPI_BASE, &timing_config);
    printf("SPI-Master transfer timing is configured.\n");
    printf("SPI-Master transfer source clock frequency: %dHz\n", timing_config.master_config.clk_src_freq_in_hz);
    printf("SPI-Master transfer sclk frequency: %dHz\n", timing_config.master_config.sclk_freq_in_hz);
    /* set SPI format config for master */
    spi_master_get_default_format_config(&format_config);
    format_config.common_config.data_len_in_bits = BOARD_APP_SPI_DATA_LEN_IN_BITS;
    format_config.common_config.mode = spi_master_mode;
    format_config.common_config.cpol = spi_sclk_high_idle;
    format_config.common_config.cpha = spi_sclk_sampling_even_clk_edges;
    spi_format_init(BOARD_APP_SPI_BASE, &format_config);
    printf("SPI-Master transfer format is configured.\n");
    /* set SPI control config for master */
    spi_master_get_default_control_config(&control_config);
    control_config.master_config.cmd_enable = false;  /* cmd phase control for master */
    control_config.master_config.addr_enable = false; /* address phase control for master */
    control_config.common_config.trans_mode = spi_trans_write_read_together;
    printf("SPI-Master transfer starts.\n");
    AD9833_Init(SIN,10000,0);
    while(1)
    return 0;
先把楼主分享的驱动常见的SPI接口DDS芯片AD9833代码收藏再说   详情 回复 发表于 2023-5-15 07:31
5400
