454|2
24
micropython 对 esp32/esp8266 添加 ESP-NOW 协议支持 [复制链接]
在最近一次更新中,micropython 对 esp32/esp8266 添加 ESP-NOW 协议支持
 esp32,esp8266: Add support for the Espressif ESP-NOW protocol.
ESP-NOW is a proprietary wireless communication protocol which supports
connectionless communication between ESP32 and ESP8266 devices, using
vendor specific WiFi frames. This commit adds support for this protocol
through a new `espnow` module.
This commit builds on original work done by @nickzoic, @shawwwn and with
contributions from @zoland. Features include:
- Use of (extended) ring buffers in py/ringbuf.[ch] for robust IO.
- Signal strength (RSSI) monitoring.
- Core support in `_espnow` C module, extended by `espnow.py` module.
- Asyncio support via `aioespnow.py` module (separate to this commit).
- Docs provided at `docs/library/espnow.rst`.
Methods available in espnow.ESPNow class are:
- active(True/False)
- config(): set rx buffer size, read timeout and tx rate
- recv()/irecv()/recvinto() to read incoming messages from peers
- send() to send messages to peer devices
- any() to test if a message is ready to read
- irq() to set callback for received messages
- stats() returns transfer stats:
(tx_pkts, tx_pkt_responses, tx_failures, rx_pkts, lost_rx_pkts)
- add_peer(mac, ...) registers a peer before sending messages
- get_peer(mac) returns peer info: (mac, lmk, channel, ifidx, encrypt)
- mod_peer(mac, ...) changes peer info parameters
- get_peers() returns all peer info tuples
- peers_table supports RSSI signal monitoring for received messages:
{peer1: [rssi, time_ms], peer2: [rssi, time_ms], ...}
ESP8266 is a pared down version of the ESP32 ESPNow support due to code
size restrictions and differences in the low-level API. See docs for
details.
Also included is a test suite in tests/multi_espnow. This tests basic
espnow data transfer, multiple transfers, various message sizes, encrypted
messages (pmk and lmk), and asyncio support.
Initial work is from https://github.com/micropython/micropython/pull/4115.
Initial import of code is from: https://github.com/nickzoic/micropython/tree/espnow-4115
链接已隐藏,如需查看请登录或者注册
esp-now是乐鑫自定义的无线协议,方便设备连接,以前micropython没有添加这个功能   详情 回复 发表于 2023-5-9 11:15
4917
这个好到哪里
24
相关帖子
