1549|38
5143
【国民技术N32WB031_STB开发板评测】GPIO之按键与LED灯 [复制链接]
【国民技术N32WB031_STB开发板评测】创建MDK模版
1、在这篇创建的基础上,复制这个模版,重命名为N32WB_KEY。并在bsp文件夹下新建key、led两个文件夹,添加好key.c、key.h、led.c、led.h。目录如下:
├─key
│      key.c
│      key.h
├─led
│      led.c
│      led.h
2、用mdk打开工程,把创建bsp/LED\bsp/key分组,并把.c\.h添加进工程:
image.png     image.png 3、led.c程序如下:
#include "led.h"
 * [url=home.php?mod=space&uid=159083]@brief[/url] Configures LED GPIO.
 * @param GPIOx x can be A to G to select the GPIO port.
 * @param Pin This parameter can be GPIO_PIN_0~GPIO_PIN_15.
void LedInit(GPIO_Module* GPIOx, uint16_t Pin)
    GPIO_InitType GPIO_InitStructure;
    /* Check the parameters */
    assert_param(IS_GPIO_ALL_PERIPH(GPIOx));
    /* Enable the GPIO Clock */
    if (GPIOx == GPIOA)
        RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOA, ENABLE);
    else if (GPIOx == GPIOB)
        RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOB, ENABLE);
    else
        return;
    /* Configure the GPIO pin */
    if (Pin <= GPIO_PIN_ALL)
        GPIO_InitStruct(&GPIO_InitStructure);
        GPIO_InitStructure.Pin = Pin;
        GPIO_InitStructure.GPIO_Mode = GPIO_MODE_OUTPUT_PP;
        GPIO_InitPeripheral(GPIOx, &GPIO_InitStructure);
 * @brief  Turns selected Led on.
void LedOn(GPIO_Module *GPIOx, uint16_t Pin)
    GPIO_SetBits(GPIOx, Pin);
 * @brief  Turns selected Led Off.
void LedOff(GPIO_Module* GPIOx, uint16_t Pin)
    GPIO_ResetBits(GPIOx, Pin);
 * @brief  Toggles the selected Led.
void LedBlink(GPIO_Module* GPIOx, uint16_t Pin)
    GPIO_TogglePin(GPIOx, Pin);
led.h:
#ifndef __LED_H__
#define __LED_H__
#include "n32wb03x.h"
void LedInit(GPIO_Module* GPIOx, uint16_t Pin);
void LedOn(GPIO_Module *GPIOx, uint16_t Pin);
void LedOff(GPIO_Module* GPIOx, uint16_t Pin);
void LedBlink(GPIO_Module* GPIOx, uint16_t Pin);
#endif
key.c:
#include "key.h"
#include "led.h"
#include "main.h"
 * @brief  Configures key port.
void KeyInputExtiInit(GPIO_Module* GPIOx, uint16_t Pin)
    EXTI_InitType EXTI_InitStructure;
    NVIC_InitType NVIC_InitStructure;
    if (GPIOx == GPIOA)
        RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOA | RCC_APB2_PERIPH_AFIO, ENABLE);
        RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOB | RCC_APB2_PERIPH_AFIO, ENABLE);
    else
        return;
    /*Configure the GPIO pin as input floating*/
        GPIO_InitStructure.GPIO_Pull    = GPIO_PULL_UP;
    /*Configure key EXTI Line to key input Pin*/
    GPIO_ConfigEXTILine(KEY_INPUT_PORT_SOURCE, KEY_INPUT_PIN_SOURCE);
    /*Configure key EXTI line*/
    EXTI_InitStructure.EXTI_Line    = KEY_INPUT_EXTI_LINE;
    EXTI_InitStructure.EXTI_Mode    = EXTI_Mode_Interrupt;
    EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; // EXTI_Trigger_Rising;
    EXTI_InitStructure.EXTI_LineCmd = ENABLE;
    EXTI_InitPeripheral(&EXTI_InitStructure);
    /*Set key input interrupt priority*/
    NVIC_InitStructure.NVIC_IRQChannel                   = KEY_INPUT_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPriority           = 1;
    NVIC_InitStructure.NVIC_IRQChannelCmd                = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
ke.y:
#ifndef __KEY_H__
#define __KEY_H__
void KeyInputExtiInit(GPIO_Module* GPIOx, uint16_t Pin);
#endif
4、在n32wb03_it.c中添加按键中断程序:
void EXTI2_3_IRQHandler(void)
    if (RESET != EXTI_GetITStatus(KEY_INPUT_EXTI_LINE))
        if(GPIO_ReadInputDataBit(KEY_INPUT_PORT, KEY_INPUT_PIN) == RESET)
            Delay(10);
                LedBlink(LED2_PORT, LED2_PIN);
        EXTI_ClrITPendBit(KEY_INPUT_EXTI_LINE);
【注】这里只是演示所用,不能在实际项目中运行
然后在主程序里初始化key\led
#include "led.h"
#include "key.h"
int main(void)
    LedInit(LED1_PORT, LED1_PIN);
    LedInit(LED2_PORT, LED2_PIN);
    LedOn(LED1_PORT, LED1_PIN);
    LedOn(LED2_PORT, LED2_PIN);
		KeyInputExtiInit(KEY_INPUT_PORT, KEY_INPUT_PIN);
    while (1)
        LedBlink(LED1_PORT, LED1_PIN);
        Delay(0x28FFFF);
这样就可以实现LED1的周期闪烁,当按下Button1时翻转LED2【注】由于在中断中用了延时,所以效果不是很好,等讲了定时器,会进行优化。
此帖出自RF/无线论坛
建议看看反汇编代码,国民的delay函数在c99规范下会被常规gcc编译器优化掉。我之前用他们的N32G45x,搭配gcc的时候就遇到过。   详情 回复 发表于 2023-5-8 22:47
5143
附上工程,大家可以取用,如果有不足之处,还请指出。多谢! N32WB031_KEY.zip (234.21 KB, 下载次数: 3)
此帖出自RF/无线论坛
4664
后面是不是准备测评蓝牙了~
此帖出自RF/无线论坛
蓝牙是作业之一,我还是想能做出什么样的功耗的东西出来。  详情 回复 发表于 2023-4-29 17:03
5143
wangerxian 发表于 2023-4-29 14:33 后面是不是准备测评蓝牙了~
此帖出自RF/无线论坛
4589
期待一些基本作业,有空再有一点小实验就更好了
此帖出自RF/无线论坛
主要是水平有限呀,还得继续操练。  详情 回复 发表于 2023-4-29 20:58
5143
led2015 发表于 2023-4-29 20:01 期待一些基本作业,有空再有一点小实验就更好了
主要是水平有限呀,还得继续操练。
此帖出自RF/无线论坛
你好 我想问一下为啥我用国民的LED实例 在里面添加按键控制LED 按键没反应 只能在上电一瞬间才监测按键是否按下
此帖出自RF/无线论坛
你可以把代码帖到我下面,我帮看看怎么回事。  详情 回复 发表于 2023-5-5 13:34
能加个WX探讨下 帮我看下吗 我小白
此帖出自RF/无线论坛
5143
J1anbean 发表于 2023-5-5 11:56 你好 我想问一下为啥我用国民的LED实例 在里面添加按键控制LED 按键没反应 只能在上电一瞬间才监测按键是否 ...
此帖出自RF/无线论坛
5143
J1anbean 发表于 2023-5-5 11:56 能加个WX探讨下 帮我看下吗 我小白
可以的,你发私信我wx吧。
此帖出自RF/无线论坛
#ifndef __MAIN_H__
#define __MAIN_H__
#ifdef __cplusplus
extern “C” {
#endif
#include “N32G031.H”
/*LED1-PB1,Led2-PB6,Led3-PB7*/
#define PORT_GROUP GPIOB
#define LED1_PORT PORT_GROUP
#define LED2_PORT PORT_GROUP
#define LED3_PORT PORT_GROUP#define LED1_PIN GPIO_PIN_1
#define LED2_PIN GPIO_PIN_6#define LED3_PIN GPIO_PIN_7
#define KEY_INPUT_PORT GPIOA
#define KEY_INPUT_PIN GPIO_PIN_5
#define KEY_INPUT_EXTI_LINE EXTI_LINE5#define KEY_INPUT_PORT_SOURCE GPIOA_PORT_SOURCE
#define KEY_INPUT_PIN_SOURCE GPIO_PIN_SOURCE5#define KEY_INPUT_IRQn EXTI4_15_IRQn
无效延迟(uint32_t计数);
void LedBreath(GPIO_Module* GPIOx, uint16_t Pin);
//uint8_t Key_Scan(GPIO_Module *GPIOx,uint16_t pin);
#ifdef __cplusplus
}#endif
#endif /* __MAIN_H__ */
此帖出自RF/无线论坛
此帖出自RF/无线论坛
此帖出自RF/无线论坛
    if (GPIOx == GPIOA)
    else if (GPIOx == GPIOC)
        RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOC | RCC_APB2_PERIPH_AFIO, ENABLE);
    else if (GPIOx == GPIOF)
        RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOF | RCC_APB2_PERIPH_AFIO, ENABLE);
    else
        return;
 * @brief  Inserts a delay time.
 * @param count specifies the delay time length.
void Delay(uint32_t count)
    for (; count > 0; count--)
 * @brief  Configures LED GPIO.
    if (GPIOx == GPIOA)
        RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOC, ENABLE);
        RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOF, ENABLE);
    else
        return;
        unsigned char i = 0;
        unsigned int t = 1;
        unsigned char flag = 1;
         while(1)
           if(flag == 1) //LED??
            for(i=0;i<10;i++)
                GPIO_ResetBits(PORT_GROUP, LED1_PIN | LED2_PIN | LED3_PIN);
                Delay(t);
                GPIO_SetBits(PORT_GROUP,LED1_PIN | LED2_PIN | LED3_PIN);        //LED??
                Delay(1001-t);
            t++;
            if(t == 1000)
                flag = 0;
        if(flag == 0) //LED????
            for(i=0;i<10;i++)
                GPIO_ResetBits(PORT_GROUP, LED1_PIN | LED2_PIN | LED3_PIN);     //LED??
                Delay(t);
                Delay(1001-t);
            t--;
            if(t == 1)
                flag = 1;
* @brief 用户断言失败的功能。
* @param文件 失败的调用的名称。
* @param行 失败的呼叫的源线路号。
#ifdef USE_FULL_ASSERT
void assert_failed(const uint8_t* expr, const uint8_t* file, uint32_t line){
while (1)
此帖出自RF/无线论坛
帮忙看看 楼主 下面是LED KEY初始化 和LED 点亮熄灭的函数 最上面是头文件和宏定义  中间是main函数
此帖出自RF/无线论坛
5143
你如果要想检测按键,你这样写阻塞式的delay是不行的,要用状态机来写才行。
此帖出自RF/无线论坛
就算我不这么写延迟按键按下去也没反应 不知道哪里有问题
此帖出自RF/无线论坛
可以看看代码打包发你了
此帖出自RF/无线论坛
好的,晚上回去修改发给你。你要去学习一下状态机的知识,这样才行。  详情 回复 发表于 2023-5-5 16:17
Project.rar (3.95 MB, 下载次数: 1)
此帖出自RF/无线论坛
5143
J1anbean 发表于 2023-5-5 16:10 可以看看代码打包发你了
此帖出自RF/无线论坛
猜你喜欢
