341|8
51
【纯干货】23种编程语言说“hello world”的区别? [复制链接]
01. Python
print('Hello, world!')
02. C
#include <stdio.h>int main() {  printf("Hello, World!");  return 0;}
03. C++
#include <iostream>int main() {  std::cout << "Hello World!";  return 0;}
04. Java
class HelloWorld {  public static void main(String[] args) {    System.out.println("Hello, World!");   }}
05. C#
namespace HelloWorld{  class Hello {             static void Main(string[] args)    {      System.Console.WriteLine("Hello World!");    }  }}
06. Visual Basic
Imports System Module Module1  Sub Main()    Console.WriteLine("Hello World!")    Console.WriteLine("Press Enter Key to Exit.")    Console.ReadLine()  End SubEnd Module
07. JavaScript
  console.log('Hello World');
08. SQL
CREATE TABLE helloworld (phrase TEXT);INSERT INTO helloworld VALUES ("Hello, World!");SELECT * FROM helloworld;
09. Assembly Language
global    _start            section   .text_start:   mov       rax, 1                  ; system call for write          mov       rdi, 1                  ; file handle 1 is stdout          mov       rsi, message            ; address of string to output          mov       rdx, 13                 ; number of bytes          syscall                           ; invoke operating system to do the write          mov       rax, 60                 ; system call for exit          xor       rdi, rdi                ; exit code 0          syscall                           ; invoke operating system to exit            section   .datamessage:  db        "Hello, World", 10      ; note the newline at the end
10. PHP
<!DOCTYPE html><html><body>  <h1>My first PHP page</h1>  <?phpecho "Hello World!";?>  </body></html>
11. Swift
print("Hello, world!")
12. Go
package main  import "fmt"  func main() {    fmt.Println("hello world")}
13. R
print("Hello World!")
14. Classic Visual Basic
15. MATLAB
function y = hello_world %#codegeny = 'Hello World!';
16. Ruby
puts "Hello World"
17. Rust
fn main() {  println!("Hello World!");}
18. Scala
[url=home.php?mod=space&uid=17]@main[/url]  def hello() = println("Hello, World!")
19. Perl
#!/usr/bin/perluse warnings;print("Hello, World!\n");
20. Scratch
  say Hello World!
21. (Visual) FoxPro
Messagebox("Hello World!",64)? "Hello World"
22. SAS
proc ds2 libs=work;data _null_;    /* init() - system method */  method init();    declare varchar(16) message; /* method (local) scope */    message = 'Hello World!';    put message;  end;enddata;run;quit;
23. Objective-C
- (BOOL)application:(UIApplication *)application didFinishLaunchingWithOptions:(NSDictionary *)launchOptions {
有时间有能力全掌握的是超人。我连一种都没有完全掌握 。   详情 回复 发表于 2023-3-15 17:18
3312
JS:console.log("hello worl");
VBA: Debug.Print "hello world");
python2.7 print "hell world");
vba的 msgbox哈哈我工作有用到~  详情 回复 发表于 2023-3-12 14:24
2029
hell world      上大学学习的第一节操作课
3427
有的简简单单,有的复杂繁琐,有时间有能力全掌握的不是一般人
1854
JS:console.log(&quot;hello worl&quot;); VBA:&nbsp;Debug.Print &quot;hello world&quot;); python2.7 print &quot;hell world&quot;);
对对,版主大佬,多才多艺呀。我是十多年前搞,现在忘得差不多了。  详情 回复 发表于 2023-3-12 15:56
3312
吾妻思萌 发表于 2023-3-12 14:24 vba的 msgbox哈哈我工作有用到~
1854
补一个
data segment ;数据段
    string db 'Hello,World!$'
data ends
code segment ;代码段
assume cs:code,ds:data
start:
    mov ax,data ;获取段基址
    mov ds,ax ;将段基址送入寄存器
    mov dx,offset string
    mov ah,9
    int 21h
    mov ah,4ch
    int 21h
code ends
end start
有大佬知道这个是啥子吗~  详情 回复 发表于 2023-3-12 22:49
1854
吾妻思萌 发表于 2023-3-12 22:49 补一个 data segment ;数据段 string db 'Hello,World!$' data ends code segment ;代码段 as ...
有大佬知道这个是啥子吗~
如果您需要查看本帖隐藏内容,请登录或者注册
相关帖子
