443|3
963
RT1052 (8) 驱动Analogysemi CSD203 [复制链接]
       在上一篇中,驱动了spi的dac,这一篇我们用iic器件试试驱动csd203。大多数步骤和上一篇是重复的,最大的区别是代码和芯片,所以咱们看代码即可。
图1:测试环境
图2:CSD203介绍
图3:CSD选型手册
图4:CSD203 demo 原理图
代码1:ANALOGYSEMICSD.C
#include "AnalogysemiCSD.h"
/*Initial CSD203*/
void CSD203_Init(CSD_CONFIG *CSD203_CFG)
    uint16_t Data=0,ADDR=0;
    uint8_t Datas[2];
    Data|=(CSD203_CFG->RST)<<15;
    Data|=(CSD203_CFG->Average)<<9;
    Data|=(CSD203_CFG->VBUS_Conv_Time)<<5;
    Data|=(CSD203_CFG->VShunt_Conv_Time)<<2;
    Data|=CSD203_CFG->Mode;
    ADDR=(CSD203_CFG->DeviceADDR);
    Datas[0]=Data>>8;
    Datas[1]=Data&0x00ff;
    Lpi2c_Write(ADDR,CONFIGURATION,0x01,0x02,Datas);
    Data=CalParam/((CSD203_CFG->CurrentLSB)*(CSD203_CFG->Rshunt));
    Datas[0]=Data>>8;
    Lpi2c_Write(ADDR,CALIBRATION,0x01,0x02,Datas);
/* CSD203 Alert*/
void CSD203_Alert(CSD_ALERT *CSD_ALT)
       Data|=(CSD_ALT->RST)<<15;
       IIC_DUT_W(ADDR,MASKENABLE,Data);
       printf("ALERT Register :%x\r\n",Data);
/*Read Vbus*/
uint16_t CSD203_ReadVbus(CSD_CONFIG *CSD203_CFG)
    uint8_t datas[2];
    uint8_t datah,datal;
    //Data=IIC_DUT_R(ADDR,BUS_VOLTAGE);
    Lpi2c_Read(ADDR,BUS_VOLTAGE,0x01,0x02,datas);
    datah=datas[0];
    datal=datas[1];
    Data=datah;
    Data<<=8;
    Data|=datal;
    return Data;
/*Read Rshunt*/
uint16_t CSD203_ReadRshunt(CSD_CONFIG *CSD203_CFG)
    uint8_t datas[2];
    Lpi2c_Read(ADDR,SHUNT_VOLTAGE,0x01,0x02,datas);
    datah=datas[0];
    datal=datas[1];
    Data=datah;
    Data<<=8;
    Data|=datal;
    return Data;
/*Read Power*/
uint16_t CSD203_ReadPower(CSD_CONFIG *CSD203_CFG)
    uint8_t datas[2];
    Lpi2c_Read(ADDR,POWER,0x01,0x02,datas);
    datah=datas[0];
    datal=datas[1];
    Data=datah;
    Data<<=8;
    Data|=datal;
    return Data;
/*Read Curent*/
uint16_t CSD203_ReadCurrent(CSD_CONFIG *CSD203_CFG)
    uint8_t datas[2];
    Lpi2c_Read(ADDR,CURRENT,0x01,0x02,datas);
    datah=datas[0];
    datal=datas[1];
    Data=datah;
    Data<<=8;
    Data|=datal;
    return Data;
代码2:ANALOGYSEMICSD.H
#ifndef AnalogysemiCSD_H
#define AnalogysemiCSD_H
/* include mcu lib*/
//#include "stm32f4xx_hal.h"
#include "stdio.h"
#include "bsp_lpi2c.h"
//#include "IIC.h"
/* CSD203 Regsistor map */
#define CONFIGURATION   0X00
/*Read Only*/
#define SHUNT_VOLTAGE   0X01
#define BUS_VOLTAGE     0X02
#define POWER           0X03
#define CURRENT         0x04
/*Read Only*/
#define CALIBRATION     0x05
#define MASKENABLE      0x06
#define ALERTLIMIT      0x07
/*Calibration Calculation parameter*/
/* This Parameter Gain*10000K*/
#define CalParam        51200
/* ↓ add your shunt here ↓   */
#define CSD_CONFIG_Rs_1mR                                      1
#define CSD_CONFIG_Rs_2mR                                      2
#define CSD_CONFIG_Rs_5mR                                      5
#define CSD_CONFIG_Rs_10mR                             10
#define CSD_CONFIG_Rs_20mR                             20
#define CSD_CONFIG_Rs_50mR                             50
#define CSD_CONFIG_CurrentLsb1mA   10
#define CSD_CONFIG_CurrentLsb2mA   20
#define CSD_CONFIG_CurrentLsb5mA   50
#define CSD_CONFIG_CurrentLsb10mA  100
#define CSD_CONFIG_CurrentLsb20mA  200
/* CSD203 Regsistor Config*/
#define CSD_CONFIG_RST          1
#define CSD_CONFIG_UnRST      0
#define CSD_CONFIG_Avg1              0
#define CSD_CONFIG_Avg4              1
#define CSD_CONFIG_Avg16            2
#define CSD_CONFIG_Avg64            3
#define CSD_CONFIG_Avg128          4
#define CSD_CONFIG_Avg256          5
#define CSD_CONFIG_Avg512          6
#define CSD_CONFIG_Avg1024  7
#define CSD_CONFIG_VBUS_CT1_1mS 4
#define CSD_CONFIG_VShunt_CT1_1mS 4
#define CSD_CONFIG_ShuntBus_CON 7
#define CSD_CONFIG_ADDR_A1_GND_A0_GND 0x80
#define CSD_CONFIG_ADDR_A1_GND_VS_GND 0x82
#define CSD_CONFIG_ADDR_A1_GND_SDA_GND 0x84
#define CSD_CONFIG_ADDR_A1_GND_SCL_GND 0x86
#define CSD_CONFIG_ADDR_A1_VS_A0_GND 0x88
#define CSD_CONFIG_ADDR_A1_VS_A0_VS 0x8a
#define CSD_CONFIG_ADDR_A1_VS_A0_SDA 0x8c
#define CSD_CONFIG_ADDR_A1_VS_A0_SCL 0x8e
#define CSD_CONFIG_ADDR_A1_SDA_A0_GND 0x90
#define CSD_CONFIG_ADDR_A1_SDA_A0_VS 0x92
#define CSD_CONFIG_ADDR_A1_SDA_A0_SDA 0x94
#define CSD_CONFIG_ADDR_A1_SDA_A0_SCL 0x96
#define CSD_CONFIG_ADDR_A1_SCL_A0_GND 0x98
#define CSD_CONFIG_ADDR_A1_SCL_A0_VS 0x9a
#define CSD_CONFIG_ADDR_A1_SCL_A0_SDA 0x9c
#define CSD_CONFIG_ADDR_A1_SCL_A0_SCL 0x9e
/*CSD Alert Option*/
/*Vshunt Voltage Over Voltage*/
#define CSD_ALERT_VShunt_OVA_ON     1
#define CSD_ALERT_VShunt_OVA_OFF    0
/*Vshunt Voltage Under Voltage*/
#define CSD_ALERT_VShunt_UVA_ON      1
#define CSD_ALERT_VShunt_UVA_OFF     0
/*VBus Voltage Over Voltage*/
#define CSD_ALERT_VBUS_OVA_ON        1
#define CSD_ALERT_VBUS_OVA_OFF       0
/*VBus Voltage Under Voltage*/
#define CSD_ALERT_VBUS_UVA_ON 1
#define CSD_ALERT_VBUS_UVA_OFF       0
/* Power Over Limit */
#define CSD_ALERT_Power_Over_ON      1
#define CSD_ALERT_Power_Over_OFF      0
/* ADC Coversion Ready */
#define CSD_ALERT_CoversionReady_ON       1
#define CSD_ALERT_CoversionReady_OFF       0
#define CSD_ALERT_CNVR_FLAG_ON      1
#define CSD_ALERT_CNVR_FLAG_OFF      0
/*  ALERT Function Flag and Alert latch Work Together */
#define CSD_ALERT_ALERT_FLAG_ON      1
#define CSD_ALERT_ALERT_FLAG_OFF     0
#define CSD_ALERT_ALERT_Latch_ON      1
#define CSD_ALERT_ALERT_Latch_OFF     0
/*Power over flow */
#define CSD_ALERT_OVF_ON    1
#define CSD_ALERT_OVF_OFF   0
/*Alert Pin */
#define CSD_ALERT_APOL_ActiveLow      1
#define CSD_ALERT_APOL_ActiveHigh 0
/*CSD Basic Configuration struct*/
typedef struct{
       uint8_t DeviceADDR;
       uint8_t RST;
       uint8_t Average;
       uint8_t VBUS_Conv_Time;
       uint8_t VShunt_Conv_Time;
       uint8_t Mode;
       uint16_t CurrentLSB;
       uint16_t Rshunt;
}CSD_CONFIG;
/*CSD ALERT Configuration struct*/
typedef struct{
       uint8_t VShunt_OVA;
       uint8_t VShuntUVA;
       uint8_t VBUS_OVA;
       uint8_t VBUS_UVA;
       uint8_t Power_OVER_Limit;
       uint8_t CNVR;
       uint8_t ALERT_FLAG;
       uint8_t CNVR_FLAG;
       uint8_t OVF;
       uint8_t APOL;
       uint8_t ALERT_Latch;
}CSD_ALERT;
/*Initial CSD203 Config*/
void CSD203_Alert(CSD_ALERT *CSD_ALT);
void CSD203_Init(CSD_CONFIG *CSD203_CFG);
/* Read Vbus Voltage*/
uint16_t CSD203_ReadVbus(CSD_CONFIG *CSD203_CFG);
/*Read Rshunt*/
uint16_t CSD203_ReadRshunt(CSD_CONFIG *CSD203_CFG);
/*Read Power*/
uint16_t CSD203_ReadPower(CSD_CONFIG *CSD203_CFG);
/*Read Current*/
uint16_t CSD203_ReadCurrent(CSD_CONFIG *CSD203_CFG);
#endif
代码3:LPI2C.c
#include "fsl_iomuxc.h"
#include "fsl_gpio.h"
#include "fsl_lpi2c.h"
#include "pad_config.h"
static void LPI2C_GPIO_Init(void);
        IOMUXC_SetPinMux(
        IOMUXC_GPIO_AD_B1_00_LPI2C1_SCL, /* GPIO_AD_B1_00 is configured as LPI2C1_SCL */
        1U);
        /* Software Input On Field: Input Path is determined by functionality */
        IOMUXC_SetPinMux(
        IOMUXC_GPIO_AD_B1_01_LPI2C1_SDA, /* GPIO_AD_B1_01 is configured as LPI2C1_SDA */
        1U); /* Software Input On Field: Input Path is determined by functionality */
        IOMUXC_SetPinConfig(IOMUXC_GPIO_AD_B1_00_LPI2C1_SCL, 0x18B0U);
        IOMUXC_SetPinConfig(IOMUXC_GPIO_AD_B1_01_LPI2C1_SDA, 0x18B0U);
void LPI2C_Init(void)
    //config Lpi2c clock
    CLOCK_SetMux(kCLOCK_Lpi2cMux, 0u);
    CLOCK_SetDiv(kCLOCK_Lpi2cDiv, 5u);
    //initial Gpio config
    LPI2C_GPIO_Init();
    lpi2c_master_config_t lpi2cConfig = {0};
    * lpi2cConfig.debugEnable = false;
    * lpi2cConfig.ignoreAck = false;
    * lpi2cConfig.pinConfig = kLPI2C_2PinOpenDrain;
    * lpi2cConfig.baudRate_Hz = 100000U;
    * lpi2cConfig.busIdleTimeout_ns = 0;
    * lpi2cConfig.pinLowTimeout_ns = 0;
    * lpi2cConfig.sdaGlitchFilterWidth_ns = 0;
    * lpi2cConfig.sclGlitchFilterWidth_ns = 0;
    //lpi2cConfig.ignoreAck = true;
    //lpi2cConfig.baudRate_Hz=1000U;
    LPI2C_MasterGetDefaultConfig(&lpi2cConfig);
    LPI2C_MasterInit(LPI2C1, &lpi2cConfig, LPI2C1_CLOCK_FREQ);
bool Lpi2c_Write(uint8_t SlaveAdd,uint8_t subAdd,uint8_t subAddsize,uint8_t datasize,uint8_t *data)
    lpi2c_master_transfer_t trans;
    status_t reVal = kStatus_Fail;
    trans.data=data;
    trans.dataSize=datasize;
    trans.direction=kLPI2C_Write;
    trans.slaveAddress=(SlaveAdd>>1);
    trans.subaddress=subAdd;
    trans.subaddressSize=subAddsize;
    trans.flags=kLPI2C_TransferDefaultFlag;
    reVal = LPI2C_MasterTransferBlocking(LPI2C1,&trans);
    if (reVal != kStatus_Success)
    return 1;
    return 0;
void Lpi2c_Read(uint8_t SlaveAdd,uint8_t subAdd,uint8_t subAddsize,uint8_t datasize,uint8_t *data)
    trans.data=data;
    trans.direction=kLPI2C_Read;
   // return data;
代码5:LPI2C.h
#ifndef __BSP_LPI2C_H
#define __BSP_LPI2C_H
#include "fsl_common.h"
#define LPI2C1_CLOCK_FREQ 3000000UL
void LPI2C_Init(void);
bool Lpi2c_Write(uint8_t SlaveAdd,uint8_t subAdd,uint8_t subAddsize,uint8_t datasize,uint8_t *data);
void Lpi2c_Read(uint8_t SlaveAdd,uint8_t subAdd,uint8_t subAddsize,uint8_t datasize,uint8_t *data);
#endif /* __BSP_LPSPI_H */
参考文档:
RT1052 (7) 驱动SPI-DAC
Power Monitor by AnalogySemi
此帖出自NXP MCU论坛
希望做一些大家觉得好用的东西!
963
工程文件
RTT NANO.7z (21.64 MB, 下载次数: 0)
此帖出自NXP MCU论坛
希望做一些大家觉得好用的东西!
963
CSD20X_Server_Apps Brief_Ver1.0_20221119.pdf (4.87 MB, 下载次数: 0)
此帖出自NXP MCU论坛
希望做一些大家觉得好用的东西!
963
此帖出自NXP MCU论坛
希望做一些大家觉得好用的东西!
相关帖子
站长推荐上一条 1/5 下一条
