193|4
91
ESP32没有pyb要怎么改这段代码 [复制链接]
esp32/8266的定时器和pyb.timer不一样,要怎么改让他工作在esp32/8266下呢。
import pyb
import micropython
micropython.alloc_emergency_exception_buf(100)
# Futaba PPM decoder
# http://diydrones.com/profiles/blogs/705844:BlogPost:38393
class Decoder():
    def __init__(self, pin: str):
        self.pin = pin
        self.current_channel = -1
        self.channels = [0] * 10 # up to 10 channels
        self.timer = pyb.Timer(2, prescaler=83, period=0x3fffffff)
        self.timer.counter(0)
        # clear any previously set interrupt
        pyb.ExtInt(pin, pyb.ExtInt.IRQ_RISING, pyb.Pin.PULL_NONE, None)
        self.ext_int = pyb.ExtInt(pin, pyb.ExtInt.IRQ_RISING, pyb.Pin.PULL_NONE, self._callback)
    def _callback(self, line) -> None:
        ticks = self.timer.counter()
        if ticks > 5000:
            self.current_channel = 0
        elif self.current_channel > -1:
            self.channels[self.current_channel] = ticks
            self.current_channel += 1
    def get_channel_value(self, channel: int) -> int:
        return self.channels[channel]
    def enable(self):
        self.ext_int.enable()
    def disable(self):
        self.ext_int.disable()
23
ESP32
ESP8266目前只支持软件定时器
91
可以实现上面的功能吗?
2317
换ESP32自带的定时器呗,定时器执行的功能移植一下就好了!
手上暂时没有PPM解码器,改了也不知道能不能用
相关帖子
