878|0
183
【2022得捷电子创新设计大赛】内存不够,不能蛮干 [复制链接]
本准备用零零碎碎的器件做电子标签,没搞定。突然想到 ESP32-S2-Kaluga-1 既有无线、又有显示屏 ,完全可以胜任啊。
于是打了个wamp,放了个id2info.php在根目录:
<?php
$id=$_GET["id"];
switch ($id)
case "0x01":
    echo "http://192.168.137.1/book.jpg?id=1" ;
    break;
case "0x02":
    echo "It is a square." ;
    break;
case "0x03":
    echo "It is a rectangle." ;
    break;
case "0x0111":
    echo "It is RED." ;
    break;
case "0x0222":
    echo "It is GREEN." ;
    break;
case "0x0333":
    echo "It is BLUE." ;
    break;
default:
    echo "ERROR." ;
然后看了下官方例程,发现 http_request适合干这个,于是改写了官方代码,从get到的内容里,取最后一行。主要方法如下:
    char recv_buf[64];
    char result_buf[64];
	int result_buf_ptr=0;
	int result_buf_cnt=0;
		result_buf_ptr=0;
		result_buf_cnt=0;
		bzero(result_buf, sizeof(result_buf));
        do {
            bzero(recv_buf, sizeof(recv_buf));
            r = read(s, recv_buf, sizeof(recv_buf)-1);
            for(int i = 0; i < r; i++) {
                putchar(recv_buf[i]);
				result_buf_cnt++;
				if(result_buf_cnt>=150 && recv_buf[i]=='\n'){//让过http头,150是随便写的,0也无所谓
					result_buf_ptr=0;
				if(result_buf_ptr<64 && recv_buf[i]!='\n' ){
					result_buf[result_buf_ptr]=recv_buf[i];
					result_buf_ptr++;
        } while(r > 0);
在git找到了一个文件很少,编译后也小的库(https://github.com/ricmoo/QRCode),没费多大劲就用上了:
    // Create the QR code
	QRCode qrcode;
    uint8_t qrcodeData[qrcode_getBufferSize( MY_QR_VER )];
	qrcode_initText(&qrcode, qrcodeData, MY_QR_VER , 0, msg);
    uint16_t *data_buf = (uint16_t *)heap_caps_calloc(IMAGE_WIDTH * IMAGE_HIGHT, sizeof(uint16_t), MALLOC_CAP_SPIRAM);
	for (int j = 0; j < IMAGE_HIGHT; j++) {
		for (int i = 0; i < IMAGE_WIDTH; i++) {
			color = color_white;
			data_buf[i + IMAGE_WIDTH * j] =color;
	int p_x = 4 ,p_y = 4;
	for(int n_y =0 ; n_y< MY_QR_SIZE ;n_y++){
		p_x = 4 ;
		for(int n_x =0 ; n_x< MY_QR_SIZE ;n_x++){
			color = qrcode_getModule(&qrcode, n_y, n_x )==1?color_black:color_white;
			for(int n_d_j =0 ; n_d_j<8;n_d_j++){
				for(int n_d_i =0 ; n_d_i<8;n_d_i++){
					data_buf[ ( p_x + n_d_i )   + IMAGE_WIDTH * ( p_y + n_d_j ) ] = color;
			p_x +=8;
		p_y +=8;
	lcd_set_index(0, 0, IMAGE_WIDTH - 1, IMAGE_HIGHT - 1);
	lcd_write_data((uint8_t *)data_buf, IMAGE_WIDTH * IMAGE_HIGHT * sizeof(uint16_t));
	vTaskDelay(2000 / portTICK_RATE_MS);
	free(data_buf);
	return;
刚开始内存分配不够,总崩溃,后来改用heap_caps_calloc来分配就可以了,但是要注意,需要开启外部SPI RAM。方法是通过​idf.py menuconfig->component config->ESP32-specific​​来操作。首先运行​idf.py menuconfig,出现界面后按下面更改:
这样空间就够用了,效果如下:
VID_20221029_202815 电子标签
附赠代码:
ESP32-S2 显示二维码
