379|2
226
[极海M3内核 APM32E103VET6S MINI开发板]05.ADC高速采样和DAC模拟外设功能 [复制链接]
APM32E103VET6S带有3个采样精度达到12位的ADC单元,每个ADC单元最多有16个外部通道和2个内部通道。其中ADC1和ADC2有16个外部通道、ADC3一般有8个外部通道;每个通道都支持单次、连续、扫描和间断的工作方式,支持左右对齐的数据存储方式。对于ADC来说,最大时钟频率为14MHz,最短的采样周期为14个周期,采样的电压范围由VREF来决定;通过APM32E103VET6S MINI开发板我们来实现一路ADC采样功能,程序配置如下:
 * @brief  * @param
 * @retval
 * @attention  *******************************************************************************/
void ADC_MultiTimerCallback(MultiTimer *timer, void *userData)
    ADC_EnableSoftwareStartConv(ADC1);
    while(ADC_ReadSoftwareStartConvStatus(ADC1) != BIT_RESET);
    ADC_ClearStatusFlag(ADC1, ADC_FLAG_EOC);
    uint32_t Value = ADC_ReadConversionValue(ADC1);
    printf("\r\nADC Voltage : %0.1fv", (float)Value / 4096.0 * 3.3);
    MultiTimerStart(&ADC_MultiTimer, 1000, ADC_MultiTimerCallback, "ADC");
 * @brief
 * @param
 * @retval
 * @attention
void ADC_Init(void)
    ADC_Config_T  ADC_ConfigStruct;
    GPIO_Config_T GPIO_ConfigStruct;
    RCM_ConfigADCCLK(RCM_PCLK2_DIV_4);  /* ADCCLK = PCLK2/4 */
    RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_ADC1 );
    RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_GPIOA);
    GPIO_ConfigStructInit(&GPIO_ConfigStruct);
    GPIO_ConfigStruct.pin   = GPIO_PIN_2;
    GPIO_ConfigStruct.mode  = GPIO_MODE_ANALOG;
    GPIO_Config(GPIOA, &GPIO_ConfigStruct);
    ADC_ConfigStructInit(&ADC_ConfigStruct);
    ADC_ConfigStruct.mode               = ADC_MODE_INDEPENDENT;
    ADC_ConfigStruct.scanConvMode       = DISABLE;
    ADC_ConfigStruct.continuosConvMode  = ENABLE;
    ADC_ConfigStruct.externalTrigConv   = ADC_EXT_TRIG_CONV_None;
    ADC_ConfigStruct.dataAlign          = ADC_DATA_ALIGN_RIGHT;
    ADC_ConfigStruct.nbrOfChannel       = 1;
    ADC_Config(ADC1, &ADC_ConfigStruct);
    ADC_ConfigRegularChannel(ADC1, ADC_CHANNEL_2, 1, ADC_SAMPLETIME_239CYCLES5);
    ADC_Enable(ADC1);
    ADC_ResetCalibration(ADC1);
    while(ADC_ReadResetCalibrationStatus(ADC1));
    ADC_StartCalibration(ADC1);
    while(ADC_ReadCalibrationStartFlag(ADC1));
运行结果:
我们使用的PA2这个引脚做ADC采样通道,当PA2悬空时,采样到的电压为1.6V即:(VREF+)+(VREF-))/2,当PA2接GND时,采样电压为0V,当PA2按VDD时,采样电压为3.3V,如下图所示:
APM32E103VET6S带有2路DAC输出引脚,分别为PA4和PA5,这两路通道互不影响;通道有多个触发源可触发转换,可单路触发转换,也可双路触发转换;另外除了输出固定的电平外,这两个通道还都可以生产噪声波形和三角波形。通过APM32E103VET6S MINI开发板我们来实现2路DAC输出固定电平,然后通过ADC来读取DAC输出的电平电压,打印输出,程序配置如下:
 * @brief
 * @param
 * @retval
 * @attention
void DAC_Init(void)
    DAC_Config_T  DAC_ConfigStruct;
    RCM_EnableAPB1PeriphClock(RCM_APB1_PERIPH_DAC  );
    GPIO_ConfigStruct.pin   = GPIO_PIN_4 | GPIO_PIN_5;
    DAC_ConfigStructInit(&DAC_ConfigStruct);
    DAC_ConfigStruct.trigger             = DAC_TRIGGER_NONE;
    DAC_ConfigStruct.waveGeneration      = DAC_WAVE_GENERATION_NONE;
    DAC_ConfigStruct.maskAmplitudeSelect = DAC_TRIANGLE_AMPLITUDE_4095;
    DAC_ConfigStruct.outputBuffer        = DAC_OUTPUT_BUFFER_DISABLE;
    DAC_Config((uint32_t)DAC_CHANNEL_1, &DAC_ConfigStruct);
    DAC_Config((uint32_t)DAC_CHANNEL_2, &DAC_ConfigStruct);
    DAC_Enable(DAC_CHANNEL_1);
    DAC_Enable(DAC_CHANNEL_2);
    DAC_ConfigDualChannelData(DAC_ALIGN_12BIT_R, (uint16_t)(4096.0*1.0/3.3), (uint16_t)(4096.0*2.2/3.3));
运行结果:
将PA2引脚连接PA4或PA5进行测量(PA2在切换/悬空的时候,采样到的电压为1.6V左右),PA4输出电压为1.0V,PA5输出电压为2.2V,如下图所示:
软件工程源代码:
Project.zip (298.33 KB, 下载次数: 0)
个人签名We are a team and we work as a team !
感谢您对极海半导体的关注和建议,我们后续将进行SDK版本迭代,同时也会不断丰富相关例程
226
傲娇树獭 发表于 2022-9-30 09:49 感谢您对极海半导体的关注和建议,我们后续将进行SDK版本迭代,同时也会不断丰富相关例程
相关帖子
    推荐帖子
    “电池均衡”的一些问题
    “电池均衡”并不是新鲜的名词,至少在镍镉电池上使用了30年。只是早期的技术简单、低效,其原理和方法是:使用功率型电阻 ...
    凌特LT3789如果要输出12V10A 直接并联MOS就可以?
    【I-Prober 520】测试总结
    本帖最后由 nemo1991 于 2019-9-30 14:11 编辑 非常荣幸能参与I-Prober 520探头的测评,感谢AIM-TTI与EE。 经过一段时间 ...
    MicroPython动手做(12)——掌控板之Hello World
    1、连接掌控板(显示最新固件日期) 470843 此内容由EEWORLD论坛网友eagler8原创,如需转载或用于商业用途需征得作者 ...
    开关模式电源电流检测:检测电阻如何放置
    电流检测电阻的位置连同开关稳压器架构决定了要检测的电流。检测的电流包括峰值电感电流、谷值电感电流(连续导通模式下电感电流 ...
    开关电源波纹的产生、测量及抑制,一篇全搞定!
    开关电源纹波的产生 我们最终的目的是要把输出纹波降低到可以忍受的程度,达到这个目的最根本的解决方法 ...
