81|0
3816
ZCC103数字温度传感器芯片替代TMP103 [复制链接]
1 Description
The ZCC103 is a digital output temperature sensor in a four-ball wafer chip-scale package (WCSP). The ZCC103 is capable of reading temperatures to a resolution of 1°C. The ZCC103 features a two-wire interface that is compatible with both I2C and SMBus interfaces. In
addition, the interface supports multiple device access (MDA) commands that allow the master to communicate with multiple devices on the bus
simultaneously, eliminating the need to send individual commands to each ZCC103 on the bus. Up to eight ZCC103s can be tied together in parallel and easily read by the host. The ZCC103 is especially suitable for space-constrained, power-sensitive applications with multiple temperature measurement zones that must be monitored.
The ZCC103 is specified for operation over a temperature range of –40°C to 125°C
2 Features
Multiple Device Access (MDA):
Global Read/Write Operations
I2C™ and SMBus™-Compatible Interface Resolution: 8 Bits
Accuracy: ±1°C Typical (–10°C to 100°C)
Low Quiescent Current:
3-μAActiveIQ at0.25Hz
1-μA Shutdown
Supply Range: 1.4 V to 3.6 V
Digital Output
3 Applications
•Handests
•Notebooks
•SSDs
•Servers
•Telecom
•Set Top Boxes
•Low Power Environmertal
•Sensors
相关帖子
