40|0
3816
100V 输入同步降压最大5A输出电流 ZCC1005 [复制链接]
The ZCC1005 is a high voltage, synchronous step-down converter operates over a wide range input voltage 9V to 100V. The ZCC1005 integrates a 100-V 400-mΩ high-side MOSFET.
The ZCC1005 delivers 1.5A continuous load current with up to 95% efficiency. The ZCC1005 operates with fixed frequency peak current control with built-in compensation eliminates the need for external components. Cycle-by-cycle current limit in high-side MOSFET protects the converter in an overload condition.
Hiccup mode protection is triggered if the over-current condition has persisted for longer than the present time.
The ZCC1005 exhibits protection features that protect the load from faults like under-voltage, over-current and over-temperature.
The ZCC1005 is available in an ESOP-8 package.
•  9V to 100V input voltage range
•  1.5A/5A continuous output current
•  95% Peak Efficiency
 • 400µA operating quiescent current
 • 100V 400-mΩ high-side MOSFET
•  Peak Current mode control
•  150 kHz Fixed Frequency
•  Internal compensation for ease of use
•  Up to 92% duty cycle
 • 0.8V voltage reference
•  1µA shutdown current
•  3A/6A cycle-by-cycle current limit
•  150ms Hiccup mode short circuit protection
Function
•  Thermal shutdown Function
•  ESOP-8 package
• Applications
•  Charger in vehicle
•  Battery Chargers
•  Power adapter
