416|8
【Beetle ESP32-C3】几个micropython的例子 [复制链接]
下载了micropython固件,就可以轻松开始测试。先通过几个小程序测试一下:
闪灯
from machine import Pin
from time import sleep_ms
LED = Pin(10, Pin.OUT)
while 1:
    LED(not LED())
    sleep_ms(500)
此帖出自RF/无线论坛
呼吸灯(通过定时器改变PWM占空比)
from machine import Pin, Timer, PWM
LED = PWM(Pin(10))
n = 0
def breathing(t):
    global n
    LED.duty(abs(1023- n*32))
    n = (n + 1) % 64
T0 = Timer(0)
T0.init(period=20, mode=Timer.PERIODIC, callback=breathing)
引脚电平中断(改变引脚上的电平,触发中断,下面使用IO0)
def pin_irq(t):
    LED(not LED())
p0 = Pin(0, Pin.IN, pull=Pin.PULL_UP)
p0.irq(trigger = Pin.IRQ_FALLING, handler=pin_irq)
定时器
tm =Timer(0)
tm.init(period=1000, mode=Timer.PERIODIC, callback=lambda t:LED(not LED()))
目前的micropython固件在esp32c3上存在bug,定时器的时间是实际时间2倍。
ADC
from machine import ADC, Pin
led = Pin(10, Pin.OUT)
adc = ADC(Pin(3))
cnt = 0
while 1:
    print(cnt, adc.read_uv())
    led(not led())
    cnt+=1
    sleep_ms(500)
串口(串口可以使用任意IO,下面程序使用IO5发送,IO7接收)
from machine import Pin, UART
uart = UART(1, tx=5, rx=7)
cnt = 1
while 1:
    uart.write(str(cnt))
    if uart.any():
        print('>', uart.read())
    cnt+=1
    led(not led())
    sleep_ms(500)
RTC
from machine import RTC
rtc = RTC()
while 1:
    print(rtc.datetime())
    sleep_ms(1000)
异步(多任务)
import uasyncio as asyncio
import time
async def blink():
    while True:
        LED(not LED())
        await asyncio.sleep(1)
async def show():
    cnt = 1
    T1 = time.ticks_us()
    while True:
        T2 = time.ticks_us()
        print(cnt, time.ticks_diff(T2, T1))
        T1 = T2
        cnt += 1
        await asyncio.sleep(2)
asyncio.create_task(blink())
asyncio.create_task(show())
asyncio.Loop.run_forever()
SHT30温湿度传感器
为了省事,直接将SHT30传感器插到开发板。因为GND引脚顺序同,因此使用IO0做GND,此外 SDA=IO1,SCL=IO4。使用SoftI2C模式。
from machine import Pin, SoftI2C
Pin(0, Pin.OUT, value=0)
class SHT3x():
    def __init__(self, i2c, addr = 68):
        self.i2c = i2c
        self._addr = addr
        self.ver = '1.0'
        self.info = 'SHT3x I2C drive for micropython'
        self._mode = 1
        self._cmd = 0x240b
        self._delay = 6
        self._decimal = 1
        self._tb = bytearray(2)
        self._rb = bytearray(3)
        self._ht = bytearray(6)
        self._T = 0
        self._H = 0
        self.reset()
    def status(self):
        self.write(0xf32d)
        self.i2c.readfrom_into(self._addr, self._rb)
        return self._rb[0]*256 + self._rb[1]
    def clear_status(self):
        self.write(0x3041)
    def write(self, cmd):
        self._tb[0] = cmd>>8
        self._tb[1] = cmd
        self.i2c.writeto(self._addr, self._tb)
    def reset(self):
        self.write(0x30a2)
    def heater(self, on=0):
        if on: self.write(0x306d)
        else:  self.write(0x3066)
    def config(self, mode = 0x240b, delay = 6, decimal = 1):
        t = mode >> 8
        self._mode = 1 if t == 0x24 or t == 0x2C else 0
        self._cmd = mode
        self._delay = delay
        self._decimal = decimal
        self.write(mode)
    def measure(self):
        if self._mode:
            self.write(self._cmd)
            sleep_ms(self._delay)
        self.write(0xe000)
        self.i2c.readfrom_into(self._addr, self._ht)
        self._T = self._ht[0]*256+self._ht[1]
        self._H = self._ht[3]*256+self._ht[4]
    def humidity(self):
        return round(100*self._H/65535, self._decimal)
    def temperature(self):
        return round(175*self._T/65535 - 45, self._decimal)
    def ht(self):
        return self.humidity(), self.temperature()
i2c= SoftI2C(sda=Pin(1), scl=Pin(4))
sh = SHT3x(i2c)
sleep_ms(10)
while 1:
    sh.measure()
    print(sh.ht())
    sleep_ms(1000)
