25|0
3624
ZCC1001E 100V 1.5A降压芯片 [复制链接]
The ZCC1001E is a high voltage, non-synchronous step-down converter operates over a wide range input voltage 9V to 100V. The ZCC1001E integrates a 120-V 400-mΩ high-side MOSFET.
The ZCC1001E delivers 1A continuous load current with up to 95% efficiency. The ZCC1001E operates with fixed frequency peak current control with built-in compensation eliminates the need for external components.Cycle-by-cycle current limit in high-side MOSFET protects the converter in an overload condition. Hiccup mode protection is triggered if the over-current condition has persisted for longer than the present time.
The ZCC1001E exhibits protection features that protect the load from faults like under-voltage,over-current and over-temperature.
The ZCC1001E is available in an ESOP-8 package.
• 9V to 100V input voltage range
 •1.5A current limit
 •1A continuous load current
• 95% Peak Efficiency
• 400µA operating quiescent current
 •120V 400-mΩ high-side MOSFET
• Peak Current mode control
• 150 kHz Fixed Frequency
 •Internal compensation for ease of use
 •Up to 92% duty cycle
• 0.8V voltage reference
• 1µA shutdown current
• 150ms Hiccup mode short circuit protection
Function
• Thermal shutdown Function
• ESOP-8 package
•Applications
 •Charger in vehicle
• Battery Chargers
• Power adapter
