感谢这次能被选中来测评国民技术低功耗N32L43x系列芯片开发板
N32L43x系列采用32位ARM Cortex-M4内核,最高主频108MHz,支持浮点运算和DSP指令,集成高达128KB嵌入式加密FLash,32KB SRAM,集成用于流量计量的低功耗外设、丰富的高性能模拟器件,内置1个12bit 5Msps ADC,2路独立轨到轨运算放大器,2个高速比较器,1个1Msps 12bit DAC,支持多达24通道电容式触摸按键,集成多大320段的Segment LCD驱动,集成多路U(S)ART、I2C、SPI、USB、CAN等数字通信接口,内置密码算法硬件加速引擎
1、前期准备
官方FTP资料库下载:使用文件资源管理器输入ftp://58.250.18.138匿名用户登录,无密码
安装芯片Keil支持包
Pack Installer -> File -> Import... 选择支持包Nationstech.N32L43x_DFP.0.1.0.pack安装
安装成功后
2、新建测试工程
设置Options for Target,芯片型号选择N32L436RB
勾选Create HEX File
添加.h头文件路径
选择仿真器型号
工程如下
3、PWM初始化
设置LED2驱动引脚PB4为PWM输出,PWM周期400us
PWM初始化代码
* @brief PWM初始化
void hal_pwmInit(void)
GPIO_InitType GPIO_InitStructure;
TIM_TimeBaseInitType TIM_TimeBaseStructure;
OCInitType TIM_OCInitStructure;
/* TIM3 clock enable */
RCC_EnableAPB1PeriphClk(RCC_APB1_PERIPH_TIM3, ENABLE);
/* GPIOB clock enable */
RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOB | RCC_APB2_PERIPH_AFIO, ENABLE);
GPIO_InitStruct(&GPIO_InitStructure);
GPIO_InitStructure.Pin = LED2_PIN;
GPIO_InitStructure.GPIO_Current = GPIO_DC_4mA;
//GPIO_InitStructure.GPIO_Pull = GPIO_No_Pull;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Alternate = GPIO_AF2_TIM3;
GPIO_InitPeripheral(LED2_PORT, &GPIO_InitStructure);
//GPIO_ResetBits(LED2_PORT, LED2_PIN);
/* Time base configuration */
TIM_TimeBaseStructure.Prescaler = 108-1; //分频值108 108MHz/108 = 1MHz 1us
TIM_TimeBaseStructure.Period = 400-1; //周期值400,定时周期400*1us = 400us
TIM_TimeBaseStructure.CntMode = TIM_CNT_MODE_UP;
TIM_TimeBaseStructure.ClkDiv = 0;
TIM_InitTimeBase(TIM3, &TIM_TimeBaseStructure);
/* PWM1 Mode configuration: Channel1 */
TIM_OCInitStructure.OcMode = TIM_OCMODE_PWM1;
TIM_OCInitStructure.OutputState = TIM_OUTPUT_STATE_ENABLE;
TIM_OCInitStructure.OcPolarity = TIM_OC_POLARITY_HIGH;
TIM_OCInitStructure.Pulse = 0;
TIM_InitOc1(TIM3, &TIM_OCInitStructure);
//使能预装载寄存器
TIM_ConfigOc1Preload(TIM3, TIM_OC_PRE_LOAD_ENABLE);
//使能自动重装载的预装载寄存器允许位
TIM_ConfigArPreload(TIM3, ENABLE);
/* TIM3 enable counter */
TIM_Enable(TIM3, ENABLE);
4、效果如下
WeChat_20220626141907
5、测试代码
N32L43_LEDBreathingtest.rar
(419.4 KB, 下载次数: 0)
