152|4
357
同一个vivado工程不能有多个仿真文件吗? [复制链接]
新建了一个vivado工程文件,开始只有uv_calculation和仿真文件vtf_uv_calculation,
经过仿真看波形都是没有问题的。
后面增加了scaler_3to2和仿真文件vtf_scaler_3to2,并设置为顶层文件后仿真结果全是“Z”和“X”,添加文件后的层级关系如下图:
image.png  添加scaler文件后的仿真结果(不论是calculation还是scaler的仿真输出都是“Z”,和“X”):
calculation仿真(输出波形还多了u_d和u_v,仿真激励文件没有定义这两个变量):
image.png  scaler文件仿真波形:
其中calculation文件之前仿真过没有问题的,添加scaler之后就出问题了,
现在把calculation单独复制出来新建工程测试是没问题的:
最后附上calculation和scaler的代码:
uv_calculation:
`timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date: 2022/06/23 09:39:54
// Design Name:
// Module Name: uv_calculation
// Project Name:
// Target Devices:
// Tool Versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module uv_calculation(
    input           clk,
    input           rst_n,
    input           col_cnt,
    input           row_cnt,
    output [9:0]    u,
    output [9:0]    v
    reg [10:0]   u_d;
    reg [10:0]   v_d;
    always@(posedge clk or negedge rst_n) begin
    if(rst_n == 1'b0) begin
        u_d <= 10'd0;
        v_d <= 10'd0;
    end
    else begin
            u_d <= col_cnt * 10'd1023 * 3 / 2 - col_cnt * 10'd1023;
            v_d <= row_cnt * 10'd1023 * 3 / 2 - row_cnt * 10'd1023;
        end
    end
    assign u = u_d;
    assign v = v_d;
endmodule
vtf_uv_calfulation:
// Company:
// Engineer:
// Create Date: 2022/06/23 09:40:57
// Design Name:
// Module Name: vtf_uv_calculation
// Project Name:
// Target Devices:
// Tool Versions:
// Description:
// Dependencies:
// Revision:
module vtf_uv_calculation(
    reg     clk;
    reg     rst_n;
    reg     col_cnt;
    reg     row_cnt;
    wire [9:0]   u;
    wire [9:0]   v;
uv_calculation uut
    .clk(clk),
    .rst_n(rst_n),
    .col_cnt(col_cnt),
    .row_cnt(row_cnt),
    .u(u),
    .v(v)
    initial begin
        clk = 0;
        rst_n = 0;
        col_cnt = 0;
        row_cnt = 0;
        #50;
            clk = 1;
            rst_n = 1;
    end
    always #5 clk = ~clk;
    always@(posedge clk) begin
        col_cnt = {$random}%2;
        row_cnt = {$random}%2;
    end
endmodule
scaler_3to2:
// Company:
// Engineer:
// Create Date: 2022/06/22 17:05:46
// Design Name:
// Module Name: scaler_3to2
// Project Name:
// Target Devices:
// Tool Versions:
// Description:
// Dependencies:
// Revision:
module scaler_3to2(
    input           clk,
    input           rst_n,
    input   [ 9: 0] u,
    input   [ 9: 0] v,
    input   [23: 0] ref_data00,
    input   [23: 0] ref_data01,
    input   [23: 0] ref_data10,
    input   [23: 0] ref_data11,
    output          pix_valid,
    output  [23: 0] pix_out
    reg     [23: 0] pix_out_d;
    reg             pix_valid_d;
    reg     [ 7: 0] ref_red;
    reg     [ 7: 0] ref_green;
    reg     [ 7: 0] ref_blue;
    assign pix_out = pix_out_d;
    assign pix_valid = pix_valid_d;
            pix_out_d <= 24'd0;
            pix_valid_d <= 1'b0;
        end
        else begin
            pix_out_d <= (11'd1023 - u) * (11'd1023 - v) * ref_data00 + (11'd1023 - v) * u * ref_data10
            + (11'd1023-u) * v * ref_data01 + u * v * ref_data11;
            pix_valid_d <= 1'b1;
        end
    end
endmodule
vtf_scaler_3to2:
// Company:
// Engineer:
// Create Date: 2022/06/22 17:20:15
// Design Name:
// Module Name: vtf_scaler_3to2
// Project Name:
// Target Devices:
// Tool Versions:
// Description:
// Dependencies:
// Revision:
module vtf_scaler_3to2();
    reg             clk;
    reg             rst_n;
    reg     [ 9: 0] u;
    reg     [ 9: 0] v;
    reg     [23: 0] ref_data00;
    reg     [23: 0] ref_data01;
    reg     [23: 0] ref_data10;
    reg     [23: 0] ref_data11;
    wire            pix_valid;
    wire    [23: 0] pix_out;
scaler_3to2 uut
    .clk(clk),
    .rst_n(rst_n),
    .u(u),
    .v(v),
    .ref_data00(ref_data00),
    .ref_data01(ref_data01),
    .ref_data10(ref_data10),
    .ref_data11(ref_data11),
    .pix_valid(pix_valid),
    .pix_out(pix_out)
    initial begin
        clk = 0;
        rst_n = 0;
        u = 10'd0;
        v = 10'd0;
        ref_data00 = 24'd0;
        ref_data01 = 24'd0;
        ref_data10 = 24'd0;
        ref_data11 = 24'd0;
        #50;
            clk = 1;
            rst_n = 1;
    end
        u = {$random}%2;
        v = {$random}%2;
        ref_data00 = {$random};
        ref_data01 = {$random};
        ref_data10 = {$random};
        ref_data11 = {$random};
    end
endmodule
357
之前也有发过一次帖子问过类似的问题,后面不知道怎么又可以了,之前应该也是新建工程之后可以的,应该跟这次经历差不多,不知道有没有人知道具体是什么原因呢?
357
这个有点反人类啊,总不能每写一个模块都新建一个工程,都单独在新工程里面仿真把
357
发现问题了:
设置顶层文件的时候出错了,源文件设置顶层文件时正确的,
仿真文件设置错误,应该将vtf……设置成顶层文件,而不是uut……设置为顶层
image.png  但是还是存在一个问题,就是切换顶层仿真文件时,关闭上次的仿真窗口之后,再仿真会出现文件占用情况。
image.png  百度上说要关闭这个窗口(点叉叉):
image.png  但是好像没有用,实际上要关闭整个工程大退软件之后重开仿真才行,不知道是不是软件的问题,目前用的版本是2019.1
试试在导航栏的仿真那里右键关闭仿真
