38|0
3428
同步升压充4节锂电池芯片ZCC6984 [复制链接]
同步升压4节锂电池充电芯片ZCC6984
描述
ZCC6984 is a highly integrated synchronous boost  charger IC for Lithium-ion batteries with four cells in  series .  The charge current  up  to 2A  can be  programmed by using the external resistor for different  portable applications.
Robust  protections  include  input  over -voltage  protection (OVP), battery OVP, battery short protection,  thermal shut down, battery temperature monitor, a configurable timer to prevent prolonged charging of a dead battery.
特性
■ 3.0V to 9V Operating Input Voltage
■ Up to 26V Sustainable Voltage
■ Up to 1A Configurable Charge Current for Battery  with 4 Cells in Series
■ Configurable Input Voltage Limit
■ Charge Status Indication
■ Constant Voltage Selectable
■ Programmable Charge Timeout
■ Thermal Regulation Protection
■ External Shutdown Function
■ Input Voltage UVLO and OVP
■ Over Temperature Protection
■ Output  Short  Circuit  Protect ion Normal Synchronous Boost Operation When Battery  Removed
应用
■ Power Bank
■ Cellular Telephones,MP3Players,MP4 Players
■ PSP Game Players,NDS game Players
■ Notebook
