33|0
3428
ZCC5145 0.6A 45V DC/DC降压IC 替代HT7463 替代SY8401 [复制链接]
1 DESCRIPTION
The ZCC5145 is a monolithic, step-down, switch- mode converter with a built-in power MOSFET. It achieves a 0.6A peak-output current over a wide input supply range with excellent load and line regulation. Current-mode operation provides a fast transient response and eases loop stabilization. Fault condition protections include cycle-by-cycle current limiting and thermal shutdown.
The ZCC5145 requires a minimal number of readily-available external components. The ZCC5145 is available in a TSOT23-6 package.
2  FEATURES
• 0.6A Peak Output Current
 •0.6Ω Internal Power MOSFET
 •Capable to Start Up with Big Output Capacitor
 •Stable with Low-ESR Ceramic Output Capacitors
 •Up to 94% Efficiency
 •Fixed 1.2MHz Frequency
 •Cycle-by-Cycle Over-Current Protection
 •Wide 4.2V-to-45V Operating Input Range
 •Output Adjustable from 4.5V to 0.94xVIN
 •Available in a SOT23-6 Package
3  APPLICATIONS
• Power Meters
• Distributed Power Systems
 •Battery Chargers
 •Pre-Regulator for Linear Regulators
