4284|1
基于lvgl的表盘设计 [复制链接]
(1)main函数部分
int main(void)
    delay_init();
    LCD_Init();
    uart_initwBaudRate(115200);
    TIM_Int_Init(999,71);
    //tp_dev.init();                  //触摸屏初始化
     lv_init();                          //lvgl系统初始化
      lv_port_disp_init();        //lvgl显示接口初始化,放在lv_init()的后面
      lv_port_indev_init();       //lvgl输入接口初始化,放在lv_init()的后面
      lv_demo_widgets();
    while(1) {
             // tp_dev.scan(0);//触摸扫描
             lv_task_handler();
(2)窗口创建
void lv_demo_widgets(void)
    tv = lv_tabview_create(lv_scr_act(), NULL);
          uint32_t flag = LV_THEME_MATERIAL_FLAG_LIGHT;
       flag = LV_THEME_MATERIAL_FLAG_DARK;
    LV_THEME_DEFAULT_INIT(lv_theme_get_color_primary(), lv_theme_get_color_secondary(),
            flag,
            lv_theme_get_font_small(), lv_theme_get_font_normal(), lv_theme_get_font_subtitle(), lv_theme_get_font_title());
    t2 = lv_tabview_add_tab(tv, "RISC-V  2022");
    lv_style_init(&style_box);
    lv_style_set_value_align(&style_box, LV_STATE_DEFAULT, LV_ALIGN_OUT_TOP_LEFT);
    lv_style_set_value_ofs_y(&style_box, LV_STATE_DEFAULT, - LV_DPX(10));
    lv_style_set_margin_top(&style_box, LV_STATE_DEFAULT, LV_DPX(30));
    visuals_create(t2);
#if LV_DEMO_WIDGETS_SLIDESHOW
    lv_task_create(tab_changer_task_cb, 8000, LV_TASK_PRIO_LOW, NULL);
#endif
(3) 构件创建
static void visuals_create(lv_obj_t * parent)
    lv_page_set_scrl_layout(parent, LV_LAYOUT_PRETTY_TOP);
    lv_disp_size_t disp_size = lv_disp_get_size_category(NULL);
    lv_coord_t grid_h_chart = lv_page_get_height_grid(parent, 1, 1);
    lv_coord_t grid_w_chart = lv_page_get_width_grid(parent, disp_size <= LV_DISP_SIZE_LARGE ? 1 : 2, 1);
//    lv_obj_t * chart = lv_chart_create(parent, NULL);
//    lv_obj_add_style(chart, LV_CHART_PART_BG, &style_box);
//    if(disp_size <= LV_DISP_SIZE_SMALL) {
//        lv_obj_set_style_local_text_font(chart, LV_CHART_PART_SERIES_BG, LV_STATE_DEFAULT, lv_theme_get_font_small());
//    lv_obj_set_drag_parent(chart, true);
//    lv_obj_set_style_local_value_str(chart, LV_CONT_PART_MAIN, LV_STATE_DEFAULT, "Line chart");
//    lv_obj_set_width_margin(chart, grid_w_chart);
//    lv_obj_set_height_margin(chart, grid_h_chart);
//    lv_chart_set_div_line_count(chart, 3, 0);
//    lv_chart_set_point_count(chart, 8);
//    lv_chart_set_type(chart, LV_CHART_TYPE_LINE);
//    if(disp_size > LV_DISP_SIZE_SMALL) {
//        lv_obj_set_style_local_pad_left(chart,  LV_CHART_PART_BG, LV_STATE_DEFAULT, 4 * (LV_DPI / 10));
//        lv_obj_set_style_local_pad_bottom(chart,  LV_CHART_PART_BG, LV_STATE_DEFAULT, 3 * (LV_DPI / 10));
//        lv_obj_set_style_local_pad_right(chart,  LV_CHART_PART_BG, LV_STATE_DEFAULT, 2 * (LV_DPI / 10));
//        lv_obj_set_style_local_pad_top(chart,  LV_CHART_PART_BG, LV_STATE_DEFAULT, 2 * (LV_DPI / 10));
//        lv_chart_set_y_tick_length(chart, 0, 0);
//        lv_chart_set_x_tick_length(chart, 0, 0);
//        lv_chart_set_y_tick_texts(chart, "600\n500\n400\n300\n200", 0, LV_CHART_AXIS_DRAW_LAST_TICK);
//        lv_chart_set_x_tick_texts(chart, "Jan\nFeb\nMar\nApr\nMay\nJun\nJul\nAug", 0, LV_CHART_AXIS_DRAW_LAST_TICK);
//    lv_chart_series_t * s1 = lv_chart_add_series(chart, LV_THEME_DEFAULT_COLOR_PRIMARY);
//    lv_chart_series_t * s2 = lv_chart_add_series(chart, LV_THEME_DEFAULT_COLOR_SECONDARY);
//    lv_chart_set_next(chart, s1, 10);
//    lv_chart_set_next(chart, s1, 90);
//    lv_chart_set_next(chart, s1, 30);
//    lv_chart_set_next(chart, s1, 60);
//    lv_chart_set_next(chart, s2, 32);
//    lv_chart_set_next(chart, s2, 66);
//    lv_chart_set_next(chart, s2, 5);
//    lv_chart_set_next(chart, s2, 47);
//    lv_obj_t * chart2 = lv_chart_create(parent, chart);
//    lv_chart_set_type(chart2, LV_CHART_TYPE_COLUMN);
//    lv_obj_set_style_local_value_str(chart2, LV_CONT_PART_MAIN, LV_STATE_DEFAULT, "Column chart");
//    s1 = lv_chart_add_series(chart2, LV_THEME_DEFAULT_COLOR_PRIMARY);
//    s2 = lv_chart_add_series(chart2, LV_THEME_DEFAULT_COLOR_SECONDARY);
//    lv_chart_set_next(chart2, s1, 10);
//    lv_chart_set_next(chart2, s1, 90);
//    lv_chart_set_next(chart2, s1, 30);
//    lv_chart_set_next(chart2, s1, 60);
//    lv_chart_set_next(chart2, s2, 32);
//    lv_chart_set_next(chart2, s2, 66);
//    lv_chart_set_next(chart2, s2, 5);
//    lv_chart_set_next(chart2, s2, 47);
    lv_coord_t grid_w_meter;
    if(disp_size <= LV_DISP_SIZE_SMALL) grid_w_meter = lv_page_get_width_grid(parent, 1, 1);
    else if(disp_size <= LV_DISP_SIZE_MEDIUM) grid_w_meter = lv_page_get_width_grid(parent, 2, 1);
    else grid_w_meter = lv_page_get_width_grid(parent, 3, 1);
    lv_coord_t meter_h = lv_page_get_height_fit(parent);
    lv_coord_t meter_size = LV_MATH_MIN(grid_w_meter, meter_h);
    lv_obj_t * lmeter = lv_linemeter_create(parent, NULL);
    lv_obj_set_drag_parent(lmeter, true);
    lv_linemeter_set_value(lmeter, 50);
    lv_obj_set_size(lmeter, meter_size, meter_size);
    lv_obj_add_style(lmeter, LV_LINEMETER_PART_MAIN, &style_box);
    lv_obj_set_style_local_value_str(lmeter, LV_LINEMETER_PART_MAIN, LV_STATE_DEFAULT, "Line meter");
    lv_obj_t * label = lv_label_create(lmeter, NULL);
    lv_obj_align(label, lmeter, LV_ALIGN_CENTER, 0, 0);
    lv_obj_set_style_local_text_font(label, LV_LABEL_PART_MAIN, LV_STATE_DEFAULT, lv_theme_get_font_title());
    lv_anim_t a;
    lv_anim_init(&a);
    lv_anim_set_var(&a, lmeter);
    lv_anim_set_exec_cb(&a, (lv_anim_exec_xcb_t)linemeter_anim);
    lv_anim_set_values(&a, 0, 100);
    lv_anim_set_time(&a, 4000);
    lv_anim_set_playback_time(&a, 1000);
    lv_anim_set_repeat_count(&a, LV_ANIM_REPEAT_INFINITE);
    lv_anim_start(&a);
    lv_obj_t * gauge = lv_gauge_create(parent, NULL);
    lv_obj_set_drag_parent(gauge, true);
    lv_obj_set_size(gauge, meter_size, meter_size);
    lv_obj_add_style(gauge, LV_GAUGE_PART_MAIN, &style_box);
    lv_obj_set_style_local_value_str(gauge, LV_GAUGE_PART_MAIN, LV_STATE_DEFAULT, "      Gauge");
    label = lv_label_create(gauge, label);
    lv_obj_align(label, gauge, LV_ALIGN_CENTER, 0, grid_w_meter / 3);
    lv_anim_set_var(&a, gauge);
    lv_anim_set_exec_cb(&a, (lv_anim_exec_xcb_t)gauge_anim);
    lv_anim_start(&a);
    lv_obj_t * arc = lv_arc_create(parent, NULL);
    lv_obj_set_drag_parent(arc, true);
    lv_arc_set_bg_angles(arc, 0, 360);
    lv_arc_set_rotation(arc, 270);
    lv_arc_set_angles(arc, 0, 0);
    lv_obj_set_size(arc,  meter_size, meter_size);
    lv_obj_add_style(arc, LV_ARC_PART_BG, &style_box);
    lv_obj_set_style_local_value_str(arc, LV_ARC_PART_BG, LV_STATE_DEFAULT, "        Arc");
    label = lv_label_create(arc, label);
    lv_obj_align(label, arc, LV_ALIGN_CENTER, 0, 0);
    lv_anim_set_var(&a, arc);
    lv_anim_set_exec_cb(&a, (lv_anim_exec_xcb_t)arc_anim);
    lv_anim_set_values(&a, 0, 360);
    lv_anim_start(&a);
    /*Create a bar and use the background's value style property to display the current value*/
    lv_obj_t * bar_h = lv_cont_create(parent, NULL);
    lv_cont_set_fit2(bar_h, LV_FIT_NONE, LV_FIT_TIGHT);
    lv_obj_add_style(bar_h, LV_CONT_PART_MAIN, &style_box);
    lv_obj_set_style_local_value_str(bar_h, LV_CONT_PART_MAIN, LV_STATE_DEFAULT, "Bar");
//    if(disp_size <= LV_DISP_SIZE_SMALL) lv_obj_set_width(bar_h, lv_page_get_width_grid(parent, 1, 1));
//    else if(disp_size <= LV_DISP_SIZE_MEDIUM) lv_obj_set_width(bar_h, lv_page_get_width_grid(parent, 2, 1));
//    else lv_obj_set_width(bar_h, lv_page_get_width_grid(parent, 3, 2));
    bar = lv_bar_create(bar_h, NULL);
    lv_obj_set_width(bar, lv_obj_get_width_fit(bar_h));
    lv_obj_set_style_local_value_font(bar, LV_BAR_PART_BG, LV_STATE_DEFAULT, lv_theme_get_font_small());
    lv_obj_set_style_local_value_align(bar, LV_BAR_PART_BG, LV_STATE_DEFAULT, LV_ALIGN_OUT_BOTTOM_MID);
    lv_obj_set_style_local_value_ofs_y(bar, LV_BAR_PART_BG, LV_STATE_DEFAULT, LV_DPI / 20);
    lv_obj_set_style_local_margin_bottom(bar, LV_BAR_PART_BG, LV_STATE_DEFAULT, LV_DPI / 7);
    lv_obj_align(bar, NULL, LV_ALIGN_CENTER, 0, 0);
//    lv_obj_t * led_h = lv_cont_create(parent, NULL);
//    lv_cont_set_layout(led_h, LV_LAYOUT_PRETTY_MID);
//    if(disp_size <= LV_DISP_SIZE_SMALL) lv_obj_set_width(led_h, lv_page_get_width_grid(parent, 1, 1));
//    else if(disp_size <= LV_DISP_SIZE_MEDIUM) lv_obj_set_width(led_h, lv_page_get_width_grid(parent, 2, 1));
//    else lv_obj_set_width(led_h, lv_page_get_width_grid(parent, 3, 1));
//    lv_obj_set_height(led_h, lv_obj_get_height(bar_h));
//    lv_obj_add_style(led_h, LV_CONT_PART_MAIN, &style_box);
//    lv_obj_set_drag_parent(led_h, true);
//    lv_obj_set_style_local_value_str(led_h, LV_CONT_PART_MAIN, LV_STATE_DEFAULT, "LEDs");
//    lv_obj_t * led = lv_led_create(led_h, NULL);
//    lv_coord_t led_size = lv_obj_get_height_fit(led_h);
//    lv_obj_set_size(led, led_size, led_size);
//    lv_led_off(led);
//    led = lv_led_create(led_h, led);
//    lv_led_set_bright(led, (LV_LED_BRIGHT_MAX - LV_LED_BRIGHT_MIN) / 2 + LV_LED_BRIGHT_MIN);
//    lv_led_on(led);
//    if(disp_size == LV_DISP_SIZE_MEDIUM) {
//        lv_obj_add_protect(led_h, LV_PROTECT_POS);
//        lv_obj_align(led_h, bar_h, LV_ALIGN_OUT_BOTTOM_MID, 0, lv_obj_get_style_margin_top(led_h, LV_OBJ_PART_MAIN) + lv_obj_get_style_pad_inner(parent, LV_PAGE_PART_SCROLLABLE));
//      lv_bar_set_anim_time(bar, 2000);
//    lv_bar_set_value(bar, 100, LV_ANIM_ON);
//    lv_task_create(bar_anim, 1, LV_TASK_PRIO_MID, bar);
    lv_anim_set_var(&a, bar);
    lv_anim_set_exec_cb(&a, (lv_anim_exec_xcb_t)bar_anim);
    lv_anim_start(&a);
注:在创建表盘的时候,我们将所需要的素材图片转化成.c文件进行存储,关于lvgl我们使用了NXP开发的辅助工具GUI Guider
其实我建议呀,注释掉的代码,可以劳苦一下你发财的小手,删了再发上来,节约的美德,咱们要发扬!   详情 回复 发表于 2022-6-5 19:23
7044
