1930|8
95
[GD32F310评测]ADC的配置和使用 [复制链接]
循着上一次的设置,我们需要完成ADC的端口的初始化和调试准备。
修改外设配置函数
添加ADC的初始化函数,基本步骤完成GPIO的设置,完成ADC的排序器设计(之后实现),进行ADC使能和adc的校准。
引脚编号 引脚名称 端口分类 引脚复用 复用分类 说明
6 PA0-WKUP I/O ADC_IN0 ADC *I DC bus
7 PA1 I/O ADC_IN1 ADC *Uu
8 PA2 I/O ADC_IN2 ADC Uv
9 PA3 I/O ADC_IN3 ADC Uw
10 PA4 I/O ADC_IN4 ADC Iu
11 PA5 I/O ADC_IN5 ADC Iv
12 PA6 I/O ADC_IN6 ADC Iw
备注:目前仅考虑电流采样,因为电压采样接口存在冲突。
修改之后的测试用外设配置函数为:
 #define _ADC_TEST
 uint16_t adc_i[3]; // ADC result for current.
 dma_parameter_struct dma_adc;
 void peripheral_init()
     // RCU:
     rcu_periph_clock_enable(RCU_GPIOA);  // GPIO A
     rcu_periph_clock_enable(RCU_CFGCMP); // CFGCMP clock
     rcu_periph_clock_enable(RCU_ADC);    // ADC
      rcu_adc_clock_config(RCU_ADCCK_APB2_DIV6);
     rcu_periph_clock_enable(RCU_DMA); // DMA
     // System tick
     systick_config();
     // GPIO config
     gpio_mode_set(GPIOA, GPIO_MODE_INPUT, GPIO_PUPD_PULLUP, GPIO_PIN_0); // Input Key
     gpio_mode_set(GPIOA, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_1);  // Output Key
     gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_MAX, GPIO_PIN_1);
     gpio_bit_reset(GPIOA, GPIO_PIN_1);
     // NVIC - EXTI
     nvic_irq_enable(EXTI0_1_IRQn, 2U, 0U); // GPIO A0 -> EXTI 0
     syscfg_exti_line_config(EXTI_SOURCE_GPIOA, EXTI_SOURCE_PIN0); // GPIO A0 Interrupt enable
     exti_init(EXTI_0, EXTI_INTERRUPT, EXTI_TRIG_FALLING);
     exti_interrupt_flag_clear(EXTI_0);
     // ADC GPIO
     gpio_mode_set(GPIOA,GPIO_MODE_ANALOG,GPIO_PUPD_NONE,GPIO_PIN_4); // Iu
     gpio_mode_set(GPIOA,GPIO_MODE_ANALOG,GPIO_PUPD_NONE,GPIO_PIN_5); // Iv
     gpio_mode_set(GPIOA,GPIO_MODE_ANALOG,GPIO_PUPD_NONE,GPIO_PIN_6); // Iw
     // ADC channel config
     adc_channel_length_config(ADC_REGULAR_CHANNEL, 3);
     adc_regular_channel_config(0,ADC_CHANNEL_4,ADC_SAMPLETIME_1POINT5); // 1.5 cycle
     adc_regular_channel_config(1,ADC_CHANNEL_5,ADC_SAMPLETIME_1POINT5); // 1.5
     adc_regular_channel_config(2,ADC_CHANNEL_6,ADC_SAMPLETIME_1POINT5); // 1.5
     adc_data_alignment_config(ADC_DATAALIGN_RIGHT); // Right align
     adc_resolution_config(ADC_RESOLUTION_12B);
     adc_special_function_config(ADC_SCAN_MODE,ENABLE); // Scan mode
     adc_dma_mode_enable(); // Setup dma mode
     adc_external_trigger_config(ADC_REGULAR_CHANNEL, ENABLE);
 #ifdef _ADC_TEST
     // Case I: for now, the timer has not setup. So just test ADC
     adc_external_trigger_source_config(ADC_REGULAR_CHANNEL,ADC_EXTTRIG_REGULAR_NONE); // software trigger FOR DEBUG
 #else
     // Case II: If Timer has been setup
     adc_external_trigger_source_config(ADC_REGULAR_CHANNEL,ADC_EXTTRIG_REGULAR_T1_CH1);
     // NOTE: Three channel of Timer0 is setup for generate PWM, so T1 may be a reasonable solution.
     //       This part may be changed, during debugging process.
 #endif
     // DMA for ADC
     dma_struct_para_init(&dma_adc);
     dma_adc.periph_addr = ADC_BASE;
     dma_adc.periph_width = DMA_PERIPHERAL_WIDTH_16BIT; // 2 byte(s)
     dma_adc.memory_addr = (uint32_t)adc_i;
     dma_adc.memory_width = DMA_MEMORY_WIDTH_16BIT;
     dma_adc.memory_inc = (uint8_t)DMA_MEMORY_INCREASE_ENABLE;
     dma_adc.number = 3;
     dma_adc.priority = (uint32_t)DMA_PRIORITY_HIGH;
     dma_circulation_enable(DMA_CH0); // ADC DMA setup
     dma_init(DMA_CH0, &dma_adc); // inti DMA for ADC(1)
     dma_periph_address_config(DMA_CH0,ADC_BASE);
     dma_transfer_direction_config(DMA_CH0,DMA_PERIPHERAL_TO_MEMORY);
     dma_channel_enable(DMA_CH0);
     // ADC setup
     adc_enable();
     delay_1ms(10);
     adc_calibration_enable(); // calibration
 #ifdef _ADC_TEST
     // This only for ADC debug.
     adc_software_trigger_enable(ADC_REGULAR_CHANNEL); // First time read ADC
 #endif
采样方法
为了实现采样,我们应当尝试扫描转换模式,在引脚定义章节我们已经计划需要读取7个通道的ADC信息。在数据手册11.4.5节介绍的“扫描转换模式”,其驱动时序如下图所示:
理论上电机驱动过程中应当关注采样的时间点,在11.4节给出了ADC的模块框图如下:
在10.4.10节给出了触发信号的规则:
规则通道的触发
ETSRC[2:0] 触发源
000 TIMER0_CH0
001 TIMER0_CH1
010 TIMER0_CH2
011 TIMER1_CH1
100 TIMER2_TRGO
101 TIMER14_CH0
110 EXTI_11(外部通道输入)
111 SWRCST(软件触发)
注入通道的触发
ETSIC[2:0] 触发源
000 TIMER0_TRGO
001 TIMER0_CH3
010 TIMER1_TRGO
011 TIMER1_CH0
100 TIMER2_CH3
101 TIMER14_TRGO
110 EXTI_15(外部通道输入)
111 SWRCST(软件触发)
对于芯片ADC的使用有如下注意事项,需要注意,否则可能导致ADC并未正常启动:
  • 时钟使能(ADC,ADC总线时钟分频器,DMA时钟)
  • ADC需要用到的GPIO通道复用
  • 配置排序器(rank)
  • 配置数据长度和数据对齐方式
  • 启用扫描模式和DMA
  • 允许外部触发,并选择外部触发源(为了测试通常选用软件触发源)
  • 配置ADC的DMA通道,我们此处使用了通道0,注意外设地址是ADC_BASE而不是要读取的目标位置RDATA
  • 启用ADC并进行ADC校准
  • 通过软件源触发ADC转换(测试用)
这一部分的代码已经从上面的初始化代码中得到了体现。
实际应用场景
在ADC的实际应用中,实际上是为了采集电机的反电动势和电机的电流,它们配置的关键如下:
  • 电流采样
对于电流采样为了规避开关信号的冲击,应当在下溢中断发生的时候开始转换。而Timer0通常设置为中间对齐模式,下溢出中断可以通过TIMER0_TRGO来选择。找张网图来说明一下位置关系。
  • 电压采样
电压采样应当在三相桥关断的情况下进行,此时可以读取到电机的反电动势,但是此时可以暂不做考虑,无论是在实际电机的驱动中,或者是在仿真中,由于电压是由发生器(脉冲)给定的,所以可以直接用调制值来代替采样值。目前局限于时间问题,考虑对于直流电机的驱动,暂且也不考虑。
ADC测试代码中可以使用软件触发来实现ADC的读取,可以通过如下测试代码实现:
     while(adc_flag_get(ADC_FLAG_EOC) != SET); // pending until convertion cmpt.
     while(dma_flag_get(DMA_CH0,DMA_FLAG_FTF) != SET); // pending until DMA transfer cmpt.
      // read ADC result here.
     delay_1ms(1); // break point here.
 #ifdef _ADC_TEST
 #endif
将这一段代码加入到项目中即可实现ADC测试效果。上图中标记出了可以通过全局变量监测的方式读取ADC的位置。
总结,GD32的手感总体还是相当棒的,由于之前被ST养出了懒病还没有改好,导致实际的调试过程异常痛苦。时长出现忘记使能时钟、忘记打开标志位的情况,不过后来简单看了看上古时期自己的笔记,加上慢慢熟悉整个系统之后,调试还是比较容易的。
此帖出自GD32 MCU论坛
2601
写了这么长的帖子,辛苦了!建议出一些实际应用的例程,这样效果会好些。
谢谢,这个和之前是一整套,等之后也许会形成一套体系吧  详情 回复 发表于 2022-5-25 00:17
2325
感谢分享,这个ADC的采用率和精度如何?
目前还没有直观感受,主要是这个东西不是PCB集中采样,都是用杜邦线跳线的话精度应该也不成参考  详情 回复 发表于 2022-5-25 00:17
95
wangerxian 发表于 2022-5-24 18:54 感谢分享,这个ADC的采用率和精度如何?
95
lugl4313820 发表于 2022-5-24 10:10 写了这么长的帖子,辛苦了!建议出一些实际应用的例程,这样效果会好些。
2546
辛苦楼主能不能做个“串口中断USART_INT_IDLE”的实验
这个可能还不在我这次主题的范围之内,我可以之后仔细看看,了解一下,感谢您的建议!  详情 回复 发表于 2022-6-5 21:26
受教了!好有创意,俺作为学生党很喜欢,在实践过程中受益匪浅
加油呀!  详情 回复 发表于 2022-6-5 21:25
95
Neeooc 发表于 2022-6-4 21:30 受教了!好有创意,俺作为学生党很喜欢,在实践过程中受益匪浅
加油呀!
95
bigbat 发表于 2022-6-2 11:41 辛苦楼主能不能做个“串口中断USART_INT_IDLE”的实验
相关帖子
    推荐帖子
    用线性光耦设计一个隔离系统时,要求达到隔离强度1800伏,设计的时候要考虑哪些
    请各位大佬指点一下,谢谢!
    TI工业月第三季——参考设计亮点抢先看
    TI工业月第三季——参考设计亮点抢先看 三次抽奖机会~快来~ 点击进入活动 活动时间:即日起&m ...
    MicroPython动手做(25)——语音合成与语音识别
    本帖最后由 eagler8 于 2020-5-22 06:57 编辑 1、TTS(Text-To-Speech,文本到语音) TTS是Text To Speech的缩写,即“ ...
    【Perf-V评测】(总结) 一次RISC-V之旅
      通过这两月的Perf-V开发板测评活动,我从零开始学习RISC-V,以开源的蜂鸟E203 CPU及SOC为基础进行实验,也翻阅了作者的书籍 ...
    高速电路环境下的旁路电容器应用
    附件是TI的技术文档 高速电路中旁路电容的应用,本文中对旁路有明确的定义,从中可以进一步验证我之前的帖子“旁路电容的选 ...
    【平头哥RVB2601创意应用开发】开箱、开发环境CDK安装、Demo测试
    收货开箱 593131593132593133 593134 上电测试 593136593135按照指导手册安装串口驱动和CDK 开发环境CDK安装 CD ...
