400|3
[AT-START-F425测评] GPIO控制LCD12864显示 + USART收发数据 [复制链接]
本次测试模块包括: GPIO, USART
测试内容如下:
1. 使用GPIO控制LCD12864液晶显示
2. 初始化usart2,使用中断模式 接收串口数据,当接收数量超过10个时,显示在LCD上,并将数据通过串口发送出去
测试效果:
源码如下:
uart.c
#include "uart.h"
uint8_t   *rx_buffer;
uint32_t  rx_cnt = 0U;
uint8_t   *tx_buffer;
uint32_t  tx_cnt = 0U;
uint32_t  nbr_data_to_send = 0U;
uint8_t   uart_send_finish_flag = 0U;
void uart_nvic_irq_enable(usart_type* UARTx)
    if (USART1 == UARTx)
        nvic_irq_enable(USART1_IRQn, 0, 0);
    else if (USART2 == UARTx)
        nvic_irq_enable(USART2_IRQn, 0, 0);
    else if ((USART3 == UARTx)||(USART4 == UARTx))
        nvic_irq_enable(USART4_3_IRQn, 0, 0);
    else
void uart2_init(uint32_t bps)
    gpio_init_type gpio_init_struct;
    /* enable the usart2 and gpio clock */
    crm_periph_clock_enable(CRM_USART2_PERIPH_CLOCK, TRUE);
    crm_periph_clock_enable(CRM_GPIOA_PERIPH_CLOCK, TRUE);
    gpio_default_para_init(&gpio_init_struct);
    /* configure the usart2 tx/rx pin */
    gpio_init_struct.gpio_drive_strength = GPIO_DRIVE_STRENGTH_STRONGER;
    gpio_init_struct.gpio_out_type  = GPIO_OUTPUT_PUSH_PULL;
    gpio_init_struct.gpio_mode = GPIO_MODE_MUX;
    gpio_init_struct.gpio_pins = GPIO_PINS_2 | GPIO_PINS_3;
    gpio_init_struct.gpio_pull = GPIO_PULL_NONE;
    gpio_init(GPIOA, &gpio_init_struct);
    /* config usart2 iomux */
    gpio_pin_mux_config(GPIOA, GPIO_PINS_SOURCE2, GPIO_MUX_1);
    gpio_pin_mux_config(GPIOA, GPIO_PINS_SOURCE3, GPIO_MUX_1);
    /* config usart2 nvic interrupt */
    /* configure usart2 param */
    usart_init(USART2, 115200, USART_DATA_8BITS, USART_STOP_1_BIT);
    usart_transmitter_enable(USART2, TRUE);
    usart_receiver_enable(USART2, TRUE);
    /* enable usart2 interrupt */
    usart_interrupt_enable(USART2, USART_RDBF_INT, TRUE);
    usart_enable(USART2, TRUE);
  //  usart_interrupt_enable(USART2, USART_TDBE_INT, TRUE);
void uart_send_1byte(usart_type* UARTx, uint8_t data)
    /* write one byte to the transmit data register */
    usart_data_transmit(UARTx, data);
void uart_send_data(usart_type* UARTx, uint8_t *buff, uint32_t len)
    uart_send_finish_flag = 0;
    tx_buffer = buff;
    nbr_data_to_send = len;
    tx_cnt = 0;
    usart_interrupt_enable(UARTx, USART_TDBE_INT, TRUE);
    uart_nvic_irq_enable(UARTx);
void uart_receive_data(usart_type* UARTx, uint8_t *buff)
    rx_cnt = 0;
    rx_buffer = buff;
    usart_interrupt_enable(UARTx, USART_RDBF_INT, TRUE);
   // uart_nvic_irq_enable(UARTx);
void get_uart_rx_data(uint8_t *buff)
    uint32_t i = 0;
    for(i=0; i<rx_cnt; i++) {
        buff = rx_buffer;
    rx_cnt=0;
uint32_t get_uart_rx_len(void)
    return rx_cnt;
  * @brief this function handles usart2 handler.
  * @param  none
  * @retval none
void USART2_IRQHandler(void)
    if(usart_flag_get(USART2, USART_RDBF_FLAG) != RESET)
        /* read one byte from the receive data register */
        rx_buffer[rx_cnt++] = (uint8_t)usart_data_receive(USART2);
        /* disable the usart2 receive interrupt */
        //usart_interrupt_enable(USART2, USART_RDBF_INT, FALSE);
    if(usart_flag_get(USART2, USART_TDBE_FLAG) != RESET)
        usart_data_transmit(USART2, tx_buffer[tx_cnt++]);
        if(tx_cnt >= nbr_data_to_send) {
            /* disable the USART2 transmit interrupt */
            usart_interrupt_enable(USART2, USART_TDBE_INT, FALSE);
            uart_send_finish_flag = 1;
uart.h
#ifndef __UART_H__
#define __UART_H__
#include <stdint.h>
#include "at32f425_usart.h"
extern uint8_t   *rx_buffer;
extern uint32_t  rx_cnt;
extern uint8_t   uart_send_finish_flag;
void uart2_init(uint32_t bps);
void uart_send_1byte(usart_type* UARTx, uint8_t data);
void uart_send_data(usart_type* UARTx, uint8_t *buff, uint32_t len);
void uart_receive_data(usart_type* UARTx, uint8_t *buff);
uint32_t get_uart_rx_len(void);
void get_uart_rx_data(uint8_t *buff);
#endif
测试代码
#define SPP_COM   USART2
#define SPP_BUF_LEN  100
uint8_t spp_txbuf[SPP_BUF_LEN];
uint8_t spp_rxbuf[SPP_BUF_LEN];
uint32_t spp_rxlen=0;
void uart_test()
    uint8_t i;
    uart2_init(115200);
    for(i=0; i<SPP_BUF_LEN; i++)
        spp_rxbuf = 0;
        spp_txbuf = 0;
    uart_receive_data(SPP_COM, spp_rxbuf);//开启中断接收,并确定接收数组
    i=0;
    while(1)
        spp_rxlen = get_uart_rx_len();
        if (spp_rxlen >= 10)
            get_uart_rx_data(spp_rxbuf);
            LCD_printf_line(6,"%s %d",spp_rxbuf,i);
            uart_send_data(SPP_COM, spp_rxbuf, spp_rxlen);//开启中断发送
            i++;
6895
 USART的测试看到收发正确就可以了
1792
结合LCD显示,两个项目一起,很棒,期待更精彩测试!
5530
谢谢分享,期待后续。
默认摸鱼
