679|2
2691
【AT-START-F425测评】堆积木之CAN通信 [复制链接]
话说这款芯片在评测时的标题就是:雅特力AT-START-F425,USB与CAN应用首选
现在开始对CAN进行基本的使用:
1、在drivers文件夹中新增can.h、can.c:
这里官方给的DEMO的RX 为PB8,TX为PB9,复用配置为MUX4。从CAN的demo中复制IO配置函数:
  *  @brief can gpio config
  *  @param  none
  *  @retval none
static void can_gpio_config(void)
  gpio_init_type gpio_init_struct;
  /* enable the gpio clock */
  crm_periph_clock_enable(CRM_GPIOB_PERIPH_CLOCK, TRUE);
  gpio_default_para_init(&gpio_init_struct);
  /* configure the can tx, rx pin */
  gpio_init_struct.gpio_drive_strength = GPIO_DRIVE_STRENGTH_STRONGER;
  gpio_init_struct.gpio_out_type = GPIO_OUTPUT_PUSH_PULL;
  gpio_init_struct.gpio_mode = GPIO_MODE_MUX;
  gpio_init_struct.gpio_pins = GPIO_PINS_8 | GPIO_PINS_9;
  gpio_init_struct.gpio_pull = GPIO_PULL_NONE;
  gpio_init(GPIOB, &gpio_init_struct);
  gpio_pin_mux_config(GPIOB, GPIO_PINS_SOURCE9, GPIO_MUX_4);
  gpio_pin_mux_config(GPIOB, GPIO_PINS_SOURCE8, GPIO_MUX_4);
然后复制can的参数配置:can_configuration 配置CA1 为500K,没有设置ID过滤
  *  @brief  can configiguration.
  *  @param  none
  *  @retval none
static void can_configuration(void)
  can_base_type can_base_struct;
  can_baudrate_type can_baudrate_struct;
  can_filter_init_type can_filter_init_struct;
  /* enable the can clock */
  crm_periph_clock_enable(CRM_CAN1_PERIPH_CLOCK, TRUE);
  /* can base init */
  can_default_para_init(&can_base_struct);
  can_base_struct.mode_selection = CAN_MODE_COMMUNICATE;
  can_base_struct.ttc_enable = FALSE;
  can_base_struct.aebo_enable = TRUE;
  can_base_struct.aed_enable = TRUE;
  can_base_struct.prsf_enable = FALSE;
  can_base_struct.mdrsel_selection = CAN_DISCARDING_FIRST_RECEIVED;
  can_base_struct.mmssr_selection = CAN_SENDING_BY_ID;
  can_base_init(CAN1, &can_base_struct);
  /* can baudrate, set boudrate = pclk/(baudrate_div *(1 + bts1_size + bts2_size)) */
  can_baudrate_struct.baudrate_div = 16;
  can_baudrate_struct.rsaw_size = CAN_RSAW_1TQ;
  can_baudrate_struct.bts1_size = CAN_BTS1_8TQ;
  can_baudrate_struct.bts2_size = CAN_BTS2_3TQ; //这里配置常用的500K 即96M/(16*(1+8+3)) = 500K
  can_baudrate_set(CAN1, &can_baudrate_struct);
  /* can filter init */
  can_filter_init_struct.filter_activate_enable = TRUE;
  can_filter_init_struct.filter_mode = CAN_FILTER_MODE_ID_MASK;
  can_filter_init_struct.filter_fifo = CAN_FILTER_FIFO0;
  can_filter_init_struct.filter_number = 0;
  can_filter_init_struct.filter_bit = CAN_FILTER_32BIT;
  can_filter_init_struct.filter_id_high = 0;
  can_filter_init_struct.filter_id_low = 0;
  can_filter_init_struct.filter_mask_high = 0;
  can_filter_init_struct.filter_mask_low = 0;
  can_filter_init(CAN1, &can_filter_init_struct);
  /* can interrupt config */
  nvic_irq_enable(CAN1_IRQn, 0x00, 0x00);
  can_interrupt_enable(CAN1, CAN_RF0MIEN_INT, TRUE);
  can_interrupt_enable(CAN1, CAN_ETRIEN_INT, TRUE);
  can_interrupt_enable(CAN1, CAN_EOIEN_INT, TRUE);
复制发送函数:发送ID设置为标准ID,ID = 0x400  发送8位数据
  *  @brief  can transmit data
  *  @param  none
  *  @retval none
void can_transmit_data(void)
  uint8_t transmit_mailbox;
  can_tx_message_type tx_message_struct;
  tx_message_struct.standard_id = 0x400;
  tx_message_struct.extended_id = 0;
  tx_message_struct.id_type = CAN_ID_STANDARD;
  tx_message_struct.frame_type = CAN_TFT_DATA;
  tx_message_struct.dlc = 8;
  tx_message_struct.data[0] = 0x11;
  tx_message_struct.data[1] = 0x22;
  tx_message_struct.data[2] = 0x33;
  tx_message_struct.data[3] = 0x44;
  tx_message_struct.data[4] = 0x55;
  tx_message_struct.data[5] = 0x66;
  tx_message_struct.data[6] = 0x77;
  tx_message_struct.data[7] = 0x88;
  transmit_mailbox = can_message_transmit(CAN1, &tx_message_struct);
  while(can_transmit_status_get(CAN1, (can_tx_mailbox_num_type)transmit_mailbox) != CAN_TX_STATUS_SUCCESSFUL);
配置can1中断接收函数:
  *  @brief  can1 interrupt function
  *  @param  none
  *  @retval none
void CAN1_IRQHandler(void)
  __IO uint32_t err_index = 0;
  can_rx_message_type rx_message_struct;
  if(can_flag_get(CAN1,CAN_ETR_FLAG) != RESET)
    err_index = CAN1->ests & 0x70;
    can_flag_clear(CAN1, CAN_ETR_FLAG);
    if(err_index == 0x00000010)
      can_reset(CAN1);
      can_configuration();
  if(can_flag_get(CAN1,CAN_RF0MN_FLAG) != RESET)
    can_message_receive(CAN1, CAN_RX_FIFO0, &rx_message_struct);
    if(rx_message_struct.standard_id == 0x400)
            如果是接收到的ID 是0x400则显示接收到相对的ID,后期可以根据这个来作更进一步功能。
            LCD_ShowString(10, 240, "recv 0x400    ", BLUE,WHITE, 32, 0);
    else
            LCD_ShowString(10, 240, "recv not my ID", BLUE,WHITE, 32, 0);
在主任务函中初始化CAN1,接上CAN分析仪,配置为500K速率,接收到如下信息:
image.png  发送ID为400与非ID的数据,LDC显示相应的信息:
image.png image.png  堆积木到现在CAN通信已经评测通过。明天再调试与STM32、N32G45的三方通信。
7110
下面是调试与STM32、N32G45的三方通信的测评应该更加顺利
谢谢,你的作品也是写得很精彩的,大家共同进步,谢谢!  详情 回复 发表于 2022-3-30 14:11
2691
Jacktang 发表于 2022-3-30 13:38 下面是调试与STM32、N32G45的三方通信的测评应该更加顺利
相关帖子
    推荐帖子
    当CMOS遇上TTL
    当COMS遇上TTL,现阶段只有纠结,因为对两者之间的联系?区别?都没有理性的认识,为此今日在此做一小小比较。 TTL:Transist ...
    原来乐高配套的控制器是开源的啊!
    EV3和NXT分别采用ti的方案和ATMEL的方案 https://www.lego.com/zh-cn/mindstorms/downloads这里公布了些资料 354355 354356 ...
    MSP430 单片机的便携式气象仪设计
    设计了一种低功耗便携式气象仪,该气象检测系统以低功耗MSP430单片机为主控,利用温度传感器.湿度传感器.气压传感器.风速 ...
    MicroPython七周年庆祝
    来自:https://blog.adafruit.com/2020/04/28/micropython-turns-seven-years-old-micropython-python-micropython/ 4月2 ...
    R329 周易AIPU环境搭建和仿真实战
    本帖最后由 x1816 于 2021-8-1 01:16 编辑 申请了测评开发板,还在报名阶段,并没有拿到板子。好在入门教程已经发布了,先搭 ...
    揭秘“神舟十二号”的回家路!
    来源:科技日报记者付毅飞 回收着陆是载人飞船飞行任务的最后阶段,也决定着飞行任务的最终成败。为了护佑航天员安全回家 ...
