社区导航
搜索
查看: 3338|回复: 6
wince播放音频,c#开发
106
TA的帖子
Rank: 1
发表于 2009-6-9 10:00 | 显示全部楼层 |阅读模式
public class Sound
        private byte[] m_soundBytes;
        private string m_fileName;
        private enum Flags
            SND_SYNC = 0x0000,  /* play synchronously (default) */
            SND_ASYNC = 0x0001,  /* play asynchronously */
            SND_NODEFAULT = 0x0002,  /* silence (!default) if sound not found */
            SND_MEMORY = 0x0004,  /* pszSound points to a memory file */
            SND_LOOP = 0x0008,  /* loop the sound until next sndPlaySound */
            SND_NOSTOP = 0x0010,  /* don't stop any currently playing sound */
            SND_NOWAIT = 0x00002000, /* don't wait if the driver is busy */
            SND_ALIAS = 0x00010000, /* name is a registry alias */
            SND_ALIAS_ID = 0x00110000, /* alias is a predefined ID */
            SND_FILENAME = 0x00020000, /* name is file name */
            SND_RESOURCE = 0x00040004  /* name is resource name or atom */
        [DllImport("CoreDll.DLL",EntryPoint="WCE_PlaySound", SetLastError = true)]
        private extern static int WCE_PlaySound(string szSound, IntPtr hMod, int flags);
        [DllImport("CoreDll.DLL", EntryPoint = "WCE_PlaySound", SetLastError = true)]
        private extern static int WCE_PlaySoundBytes(byte[] szSound, IntPtr hMod, int flags);
        /// Construct the Sound object to play sound data from the specified file.
        public Sound(string fileName)
            m_fileName = fileName;
        /// Construct the Sound object to play sound data from the specified stream.
        public Sound(Stream stream)
            // read the data from the stream
            m_soundBytes = new byte[stream.Length];
            stream.Read(m_soundBytes, 0, (int)stream.Length);
        /// Play the sound
        public void Play()
            // if a file name has been registered, call WCE_PlaySound,
            //  otherwise call WCE_PlaySoundBytes
            if (m_fileName != null)
                WCE_PlaySound(m_fileName, IntPtr.Zero, (int)(Flags.SND_ASYNC | Flags.SND_FILENAME));
            else
                WCE_PlaySoundBytes(m_soundBytes, IntPtr.Zero, (int)(Flags.SND_ASYNC | Flags.SND_MEMORY));
按照网友说的做的,调试出错。
无法找到 PInvoke DLL“CoreDll.DLL”中的入口点“WCE_PlaySound”
请教高手解答!
此帖出自WindowsCE论坛
104
TA的帖子
Rank: 1
发表于 2009-6-9 10:05 | 显示全部楼层
我把EntryPoint="WCE_PlaySound",
改成EntryPoint="PlaySound", 后不报错了。
调试通过,但是没有播放,没有声音。
private void btn1_Click(object sender, System.EventArgs e)
    Sound sound = new Sound(@"ResidentFlash\002.wav");
    sound.Play();
来人呢!!
使用道具 举报
105
TA的帖子
Rank: 1
发表于 2009-6-9 10:09 | 显示全部楼层
mark
使用道具 举报
113
TA的帖子
Rank: 1
发表于 2009-6-9 11:13 | 显示全部楼层
好像和音频文件有关,改用wince系统自带的wav文件就能播放。。奇怪了
使用道具 举报
112
TA的帖子
Rank: 1
发表于 2009-6-9 13:20 | 显示全部楼层
没结果了,来人散分了。来者有份
使用道具 举报
106
TA的帖子
Rank: 1
发表于 2009-6-9 17:28 | 显示全部楼层
这些函数都有返回值,看看这些返回值是什么错误!!
使用道具 举报
117
TA的帖子
Rank: 1
发表于 2009-7-22 16:13 | 显示全部楼层
有没有暂停、停止的方法?
使用道具 举报
站长推荐上一条 /5 下一条
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2020-2-23 03:39 , Processed in 0.226791 second(s), 18 queries , Gzip On, MemCache On.
