591|0
353
GD32L233C-START 评测 (3)片上硬件过采样ADC [复制链接]
     GD32L233C的一个特点是集成了片上硬件过采样ADC。片上硬件过采样ADC单元执行预处理以减轻CPU的负担。它能够处理多个转换,并将多个转换的结果取平均,得出一个16位宽的数据。过采样单元通过ADC_OVSAMPCLT寄存器的OCSEN位来使能。它以降低数据输出率换取较高的数据分辨率。
    本次评测体验以256倍硬件过采样ADC采样率,对内部温度传感器采样,然后右移8位得到转换结果。并从LPUART输出到串口终端。
   本例采用下图红框的配置
   执行结果
    GD32L233C片上硬件过采样ADC可以达到16位分辨率,在需要较高的数据分辨率的实际应用中是一个非常实用的功能。
#include "gd32l23x.h"
#include "systick.h"
#include <stdio.h>
#include "gd32l233r_eval.h"
uint16_t adc_value = 0U;
float temperature;
int32_t value;
void rcu_config(void);
void adc_config(void);
void lpuart_config(void);
#define ADC_TEMP_CALIBRATION_VALUE          REG16(0x1FFFF7F8)
int main(void)
    rcu_config();
    systick_config();
    gpio_config();
    adc_config();
		lpuart_config();
     while(1) {
			adc_software_trigger_enable(ADC_INSERTED_CHANNEL);
			value = (int32_t)ADC_TEMP_CALIBRATION_VALUE;
			temperature = ((float)((int32_t)ADC_IDATA0-value ) * 3.3f / 4095 * 1000 / 4.3f) + 25;
			printf(" Current Temperature = %2.1f  \r\n", temperature);
			printf(" \r\n");
      delay_1ms(1000U);
    rcu_periph_clock_enable(RCU_GPIOA);
    rcu_periph_clock_enable(RCU_ADC);
    rcu_adc_clock_config(RCU_ADCCK_APB2_DIV6);
    adc_channel_length_config(ADC_INSERTED_CHANNEL, 1);
    adc_inserted_channel_config(0U, ADC_CHANNEL_16, ADC_SAMPLETIME_239POINT5);
    adc_external_trigger_source_config(ADC_INSERTED_CHANNEL, ADC_EXTTRIG_INSERTED_NONE);
    adc_data_alignment_config(ADC_DATAALIGN_RIGHT);
    adc_special_function_config(ADC_SCAN_MODE, DISABLE);
    adc_channel_16_to_19(ADC_TEMP_CHANNEL_SWITCH, ENABLE);
    adc_external_trigger_config(ADC_INSERTED_CHANNEL, ENABLE);
    adc_oversample_mode_config(ADC_OVERSAMPLING_ALL_CONVERT,
    ADC_OVERSAMPLING_SHIFT_8B, ADC_OVERSAMPLING_RATIO_MUL256);
    adc_oversample_mode_enable();
    adc_enable();
    delay_1ms(1U);
    adc_calibration_enable();
    rcu_periph_clock_enable(RCU_LPUART);
    gpio_af_set(GPIOA, GPIO_AF_8, GPIO_PIN_2);
    gpio_af_set(GPIOA, GPIO_AF_8, GPIO_PIN_3);
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_2);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, GPIO_PIN_2);
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_3);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, GPIO_PIN_3);
    lpuart_deinit();
	  lpuart_word_length_set(LPUART_WL_8BIT);
    lpuart_stop_bit_set(LPUART_STB_1BIT);
    lpuart_parity_config(LPUART_PM_NONE);
    lpuart_baudrate_set(115200U);
    lpuart_receive_config(LPUART_RECEIVE_ENABLE);
    lpuart_transmit_config(LPUART_TRANSMIT_ENABLE);
    lpuart_enable();
int fputc(int ch, FILE *f)
    lpuart_data_transmit((uint8_t)ch);
    while(RESET == lpuart_flag_get(LPUART_FLAG_TBE));
    return ch;
此帖出自GD32 MCU论坛
