1314|7
2931
【沁恒RISC-V内核 CH582】ADC内部温度转换 [复制链接]
按照官方提供的例程,内部温度读取。
ADC_InterTSSampInit();
RoughCalib_Value = ADC_DataCalib_Rough(); //  取得这个值为-2
temp_value =ADC_ExcutSingleConver() + RoughCalib_Value;      // 获取值为2851
查找到CH58x_adc.c里的温度转换函数,因为要有小数,所以我修改了一下函数:如下:
* Function Name  : ADC_GetCurrentTS
* Description    : 获取当前采样的温度值(℃)
* Input          : ts_v:当前温度传感器采样输出
* Return         : 转换后的温度值(℃)
float ADC_GetCurrentTS( UINT16 ts_v )
  int  C25;
  float  cal;
  C25 = (*((PUINT32)ROM_CFG_TMP_25C));
  cal = ( ( (ts_v * 1050) + 2048 ) >> 12 ) + ( 1050 >> 1 );
  cal = 25 + ((float)(cal - C25)*10/14);
  return (  cal );
主程序如下:
/********************************** (C) COPYRIGHT *******************************
 * File Name          : Main.c
 * Author             : 刘建华
 * Version            : V1.0
 * Date               : 2022/02/27
 * Description        : 演示ST7735 硬件SPI驱动
#include "CH58x_common.h"
#include "lcd_init.h"
#include "lcd.h"
UINT16 abcBuff[40];
uint32_t temp_value;
volatile UINT8 adclen;
void DebugInit( void )
  GPIOA_SetBits( GPIO_Pin_9 );
  GPIOA_ModeCfg( GPIO_Pin_8, GPIO_ModeIN_PU );
  GPIOA_ModeCfg( GPIO_Pin_9, GPIO_ModeOut_PP_5mA );
  UART1_DefInit();
int main()
  UINT8 i;
  char show_shr[30];
  double temperate;
  int  C25;
  int cal;
  signed short RoughCalib_Value = 0;    // ADC粗调偏差值
  SetSysClock( CLK_SOURCE_PLL_60MHz );
  /* 配置串口调试 */
  DebugInit();
  PRINT( "Start @ChipID=%02X\n", R8_CHIP_ID );
  sprintf(show_shr,"ChipID=%02X\n", R8_CHIP_ID);
  LCD_Init();
  LCD_Fill(0,0,LCD_W,LCD_H,WHITE);
  LCD_ShowString(0, 10, show_shr, BLUE, WHITE, 16, 0);
  mDelaymS(1000);
  LCD_ShowString(10,0,"CH582M",BLUE,WHITE,32,0);
  LCD_ShowString(16,36,"HELLO WORLD",RED,WHITE,16,0);
  LCD_ShowString(16,54,"ST7735",RED,WHITE,16,0);
  RoughCalib_Value = ADC_DataCalib_Rough(); // 用于计算ADC内部偏差,记录到变量 RoughCalib_Value中,注意这个变量需要定义为有符号变量
  PRINT("Rouh:%d\n",RoughCalib_Value);
  while( 1 )
    temp_value = 0;
    for( i = 0; i < 20; i++ )
        abcBuff[i] = ADC_ExcutSingleConver() + RoughCalib_Value;      // 连续采样20次
        temp_value = temp_value + abcBuff[i] ;
    temp_value = temp_value/20 ;
    LCD_ShowIntNum(20, 80, temp_value, 4, BLACK, WHITE, 16);
    temperate = ADC_GetCurrentTS(temp_value);
    LCD_ShowFloatNum1(20, 100, temperate, 6, BLACK, WHITE, 16);
    mDelaymS(1000);
获取温度值为:
1度左右,感觉换算公式还是有问题,用手摸芯片,温度也就显示2度左右。看看官方有什么测试过。
2931
在CH58x_adc.h中看到有一个设置内置温度校准值的函数。
#define        ADC_TempCalibCfg( d )    (R8_TEM_SENSOR=R8_TEM_SENSOR&(~RB_TEM_SEN_CALIB)|d)                /* 设置内部温度传感器校准值 */
不知道这个d,要传什么样的参数?
查看数据手册,也没有说明可以传参:
image.png  是我哪里没有弄,还是芯片有问题,求官方解答。
2931
贴子有更新。。修改一下
lugl4313820 发表于 2022-2-27 12:31 在CH58x_adc.h中看到有一个设置内置温度校准值的函数。 #define         ...
这边还未对外开放,等开放之后在手册中会对这部分有所介绍。
看你贴出来的代码,温度转换公式用的不是evt中最新的公式,可以下载官方最新的evt,使用新的公式,使用新的公式后,温度的变化是对的,但绝对温度需要自己校准。
我看了评测给的函数是: /********************************** (C) COPYRIGHT ******************************* * File Name          : CH58x_adc.c * Author        详情 回复 发表于 2022-2-28 14:52
2931
花花花hy 发表于 2022-2-28 14:35 看你贴出来的代码,温度转换公式用的不是evt中最新的公式,可以下载官方最新的evt,使用新的公式,使用新的 ...
我看了评测给的函数是:
* Author             : WCH
* Version            : V1.1
* Date               : 2020/04/01
* Description
int ADC_GetCurrentTS( UINT16 ts_v )
  int  C25;
  int cal;
  cal = 25 +( (cal - C25)*10/14);
  return (  cal );
然后另一个给的CH583 EVT例程下面又是这样的:
 * Author             : WCH
 * Version            : V1.2
 * Date               : 2021/11/17
 * Description
 * Copyright (c) 2021 Nanjing Qinheng Microelectronics Co., Ltd.
 * SPDX-License-Identifier: Apache-2.0
 * @fn      ADC_GetCurrentTS
 * @brief   获取当前采样的温度值(℃)
 * @param   ts_v    - 当前温度传感器采样输出
 * @return  转换后的温度值(℃)
int ADC_GetCurrentTS(uint16_t ts_v)
    uint32_t C25;
    int cal;
    cal = (ts_v * 2100) >> 12;
    cal = (((C25 >> 16) & 0xFFFF) ? ((C25 >> 16) & 0xFFFF) : 25) + ((cal - ((int)(C25 & 0xFFFF) - 1050 / 2) * 2) * 10 / 14);
    return (cal);
是不是要用v1.2?还是CH582的内部温度ADC需要另外提供的函数?
对v1.2是最新的,使用新的公式,使用新的公式后,温度的变化是对的,但绝对温度需要自己校准。
可以说明一下如何较对绝对温度吗,原来我想节约一下资源,做一个超低成本、超低功耗的温度传感器,但是感觉好象不是跟理想中的一样。原来用过MSP430G2253,他的温度也要较准,但是贵公司的对比起他,还有一定的理解  详情 回复 发表于 2022-3-14 21:33
2931
WCH_Risc5 发表于 2022-3-14 17:06 对v1.2是最新的,使用新的公式,使用新的公式后,温度的变化是对的,但绝对温度需要自己校准。
可以说明一下如何较对绝对温度吗,原来我想节约一下资源,做一个超低成本、超低功耗的温度传感器,但是感觉好象不是跟理想中的一样。原来用过MSP430G2253,他的温度也要较准,但是贵公司的对比起他,还有一定的理解,望多多指教!
相关帖子
