593|5
1422
【国民技术N32G457评测】RTC + 温度计 [复制链接]
        评测国民技术N32G457快一个月了,今天把前面几个项目整合了一下,合并成一个显示日历+温度,前面准备做一个电子烟测试系统的,因为手头上的硬件全部发走了,所以就没有能够展示。
     温度测量是用一个100K的NTC电阻+100K分压电阻组成的测度电路。LCD屏是1.8寸128*160的TFT LCD屏,9.9元买的,分辨率有点低。
    RTC是RT—thread Studio的软RTC实现。
具体配如置如下:
image.png    把ADC、ST7735文件夹放到packages下面。
image.png  ntc.c
 * Copyright (c) 2006-2021, RT-Thread Development Team
 * SPDX-License-Identifier: Apache-2.0
 * Change Logs:
 * Date           Author       Notes
 * 2022-02-13     Administrator       the first version
#include "ntc.h"
#include <stdio.h>
#include <stdint.h>
#include <rtthread.h>
#include <rtdevice.h>
#include <rtconfig.h>
#include <drv_adc.h>
函数:  static int16_t get_ntc_temperature(uint16_t ad_data)
功能:
参数:  ad_data: 的ADC采集到的NTC电路分压AD值
返回:  根据单位换算成摄氏度/华氏度,返回温度值*10
描述:  100K与NTC串联,接到3V3电源上
  float Rntc,t;
  uint8_t index;
  Rntc = 100.0*ad_data/(4095 - ad_data);//求出Rntc阻值,单位为Komh
  for(index = 0;index < (N-1);index++)
      if(Rntc > ntc[index])
          break;
  if(index <= 0)                       //temp lower than -20℃
      t = -20.0;                       //rail at -20℃
  else
  if(index >= (N-1))                   //temp higher than 170℃
      t = 170.0;                       //rail at 170℃
  else                                 //temp between -20℃ and 170℃
      t = (-20 + index) - (Rntc-ntc[index])/(ntc[index]-ntc[index-1]);
      t= t-3;
      t = t*100;                        // 温度扩大10倍
  return (int16_t)t;                  // 类型转换为int16_t
char v[6] = {'0','0','.','0','0','C'};
void adc_temp_sample(void)
    rt_adc_device_t adc_temp_dev;
    rt_uint32_t value, vol;
    double temperate;
    rt_err_t ret = RT_EOK;
    adc_temp_dev = (rt_adc_device_t)rt_device_find(ADC_DEV_NAME);
    if(adc_temp_dev == RT_NULL)
        rt_kprintf("adc_temp run failed ! can't find %s device!\n",ADC_DEV_NAME);
        //return RT_ERROR;
    /*使能设备 */
    ret = rt_adc_enable(adc_temp_dev, ADC_DEV_CHANNEL);
    if(ret == RT_EOK)
            rt_kprintf("adc sample run success!  find %s device!\n", ADC_DEV_NAME);
        while(1)
            value = rt_adc_read(adc_temp_dev, ADC_DEV_CHANNEL);
            temperate = get_ntc_temperature((rt_uint32_t)value);              //得到气温X10
            vol = (rt_uint32_t)temperate;
            v[0] = vol/1000 + '0';
            v[1] = vol/100%10 +'0';
            v[3] = vol/10%10 +'0';
            v[4] = vol%10 +'0';
            //LCD_ShowIntNum(20,110,vol,4,BLACK,WHITE,16);
            //LCD_ShowString(20,110,v, BROWN ,WHITE,16,0);
            rt_thread_mdelay(500);
ntc.h
 * Change Logs:
 * Date           Author       Notes
#ifndef PACKAGES_ADC_NTC_H_
#define PACKAGES_ADC_NTC_H_
#include <stdio.h>
#define ADC_DEV_NAME     "adc1"
#define ADC_DEV_CHANNEL  2  //PA1
#define N 191 //NTC温度对应阻值个数,即ntc[]数组大小
const static float ntc[N]=
    //-20℃  //-19    //-18    //-17    //-16    //-15    //-14    //-13    //-12    //-11
    975.8038,920.5962,868.8615,820.3603,774.8710,732.1889,692.1238,654.4999,619.1540,585.9346,
    //-10℃  //-9     //-8     //-7     //-6     //-5     //-4     //-3     //-2     //-1
    554.7016,525.3245,497.6821,471.6621,447.1599,424.0781,402.3264,381.8204,362.4818,344.2375,
    //0℃    //1      //2      //3      //4      //5      //6      //7      //8      //9
    327.0195,310.7640,295.4121,280.9084,267.2014,254.2428,241.9877,230.3940,219.4224,209.0361,
    //10℃   //11     //12     //13     //14     //15     //16     //17     //18     //19
    199.2007,189.8841,181.0559,172.6881,164.7540,157.2290,150.0898,143.3144,136.8825,130.7749,
    //20℃   //21     //22     //23     //24     //25     //26     //27     //28     //29
    124.9734,119.4612,114.2223,109.2417,104.5053,100.0000,95.7132, 91.6333, 87.7492, 84.0505,
    //30℃   //31     //32     //33     //34     //35     //36     //37     //38     //39
    80.5274, 77.1707, 73.9717, 70.9222, 68.0144, 65.2411, 62.5954, 60.0707, 57.6610, 55.3604,
    //40℃   //41     //42     //43     //44     //45     //46     //47     //48     //49
    53.1635, 51.0651, 49.0602, 47.1443, 45.3130, 43.5621, 41.8878, 40.2862, 38.7539, 37.2876,
    //50℃   //51     //52     //53     //54     //55     //56     //57     //58     //59
    35.8842, 34.5405, 33.2538, 32.0214, 30.8408, 29.7096, 28.6253, 27.5860, 26.5895, 25.6338,
    //60℃   //61     //62     //63     //64     //65     //66     //67     //68     //69
    24.7171, 23.8376, 22.9937, 22.1836, 21.4061, 20.6594, 19.9424, 19.2537, 18.5920, 17.9562,
    //70℃   //71     //72     //73     //74     //75     //76     //77     //78     //79
    17.3452, 16.7578, 16.1930, 15.6499, 15.1276, 14.6251, 14.1417, 13.6764,13.2286, 12.7976,
    //80℃   //81     //82     //83     //84     //85     //86     //87     //88     //89
    12.3825, 11.9828, 11.5978, 11.2270, 10.8697, 10.5254, 10.1935, 9.8736, 9.5652,  9.2678,
    //90℃   //91     //92     //93     //94     //95     //96     //97     //98     //99
    8.9809,  8.7042,  8.4373,  8.1797,  7.9312, 7.6912,   7.4596,  7.2360, 7.0201,  6.8115,
    //100℃  //101    //102    //103    //104    //105    //106    //107    //108    //109
    6.6101,  6.4155, 6.2274,  6.0457,   5.8701,  5.7003,  5.5362,  5.3775,  5.2240, 5.0755,
    //110℃  //111    //112    //113    //114    //115    //116    //117    //118    //119
    4.9319,  4.7930, 4.6586,  4.5285,   4.4026,  4.2807,  4.1627,  4.0484, 3.9378,  3.8306,
    //120℃  //121    //122    //123    //124    //125    //126    //127    //128    //129
    3.7268, 3.6263,  3.5289,  3.4345,   3.3430,  3.2543,  3.1683,  3.0850,  3.0042,  2.9258,
    //130℃  //131    //132    //133    //134    //135    //136    //137    //138    //139
    2.8498, 2.7761,  2.7045,  2.6352,   2.5678,  2.5025, 2.4391,   2.3775,  2.3178,  2.2598,
    //140℃  //141    //142    //143    //144    //145    //146    //147    //148    //149
    2.2034, 2.1487, 2.0956,  2.0440,    1.9939,  1.9452,  1.8978,  1.8518,  1.8071, 1.7637,
    //150℃  //151    //152    //153    //154    //155    //156    //157    //158    //159
    1.7215, 1.6804, 1.6405,  1.6017,   1.5640,  1.5273,  1.4915,  1.4568,  1.4230,  1.3901,
    //160℃  //161    //162    //163    //164    //165    //166    //167    //168    //169
    1.3582, 1.3270, 1.2967,  1.2672,   1.2385,  1.2106,  1.1833,  1.1568,  1.1310,  1.1059,
    //170℃
    1.0814
extern char v[6] ;
void adc_temp_sample();
#endif /* PACKAGES_ADC_NTC_H_ */
然后main.c如下:
#include <stdint.h>
#include "lcd_init.h"
#include "lcd.h"
#include "pic.h"
#include "ntc.h"
#include <time.h>
/* defined the LED1 pin: PB5 */
#define LED1_PIN    91
#define THREAD_PRIORITY         25
#define THREAD_STACK_SIZE       512
#define THREAD_TIMESLICE        5
extern char v[6] ;
static void rtc_sample(void)
    time_t now;
    char da_buf[12];
    char time_buf[12];
    struct tm *t;
    while(1)
        now = time(RT_NULL);
        t=localtime(&now);
        rt_sprintf(da_buf, "%d-%2d-%2d",(t->tm_year)+1900,(t->tm_mon)+1,t->tm_mday);
        rt_sprintf(time_buf,"%2d:%2d:%2d",t->tm_hour,t->tm_min,t->tm_sec);
        LCD_ShowString(24,110,da_buf, BLACK ,WHITE,16,0);
        LCD_ShowString(30,90,time_buf, BLACK ,WHITE,16,0);
        LCD_ShowString(10,56,v,BLACK,WHITE,32,0);
        rt_thread_mdelay(100);
int main(void)
    uint32_t Speed = 200;
    static rt_thread_t tid1 = RT_NULL;
    static rt_thread_t tid_adc = RT_NULL;
    rt_pin_mode(LED1_PIN, PIN_MODE_OUTPUT);
    int day;
    LCD_Init();//LCD初始化
    LCD_Fill(0,0,LCD_W,LCD_H,WHITE);
    LCD_ShowString(10,0,"RTTDEMO",BLUE,WHITE,32,0);
    LCD_ShowString(24,36,"N32G45XVL",RED,WHITE,16,0);
    //LCD_ShowPicture(74,110,40,40,gImage_1);
    /* 创建线程1,名称是thread1,入口是thread1_entry*/
    tid1 = rt_thread_create("thread1",
                                rtc_sample, RT_NULL,
                                THREAD_STACK_SIZE,
                                THREAD_PRIORITY, THREAD_TIMESLICE);
        /* 如果获得线程控制块,启动这个线程 */
        if (tid1 != RT_NULL)
            rt_thread_startup(tid1);
        tid_adc = rt_thread_create("thread2",
                adc_temp_sample, RT_NULL,
                                       THREAD_STACK_SIZE,
       if (tid_adc != RT_NULL)
           rt_thread_startup(tid_adc);
    while (1)
        rt_pin_write(LED1_PIN, PIN_LOW);
        rt_thread_mdelay(Speed);
        rt_pin_write(LED1_PIN, PIN_HIGH);
效里如下:
6794
看到了,效果还行
同时买的另一款,分辨率要高一些,只是没有货,3月才发货,为了测评开发板,得买好多附件。  详情 回复 发表于 2022-2-23 08:58
1422
Jacktang 发表于 2022-2-23 07:18 看到了,效果还行
nmg
赞,你一般都在哪里买附件  详情 回复 发表于 2022-2-23 09:09
5066
236
管理员
lugl4313820 发表于 2022-2-23 08:58 同时买的另一款,分辨率要高一些,只是没有货,3月才发货,为了测评开发板,得买好多附件。
赞,你一般都在哪里买附件
1422
某宝上呀,有时上闲鱼,产品上线在嘉立创!反正做单片机感就是一个穷人。
5365
不错哟,谢谢分享!
默认摸鱼
