597|4
605
【GD32L233C-START评测】3、pwm实现呼吸灯 [复制链接]
相关文章:
【GD32L233C-START评测】1、优点与缺点都很明显的GD32L233C-START(开箱)
【GD32L233C-START评测】2、非阻塞方式点灯,blink,blink,blink……
1、硬件连接
image.png   2、PWM通道
image.png  可以看出,PC6对应的是TIME2的CH0通道。
3、实现方法
通过调节占空比,递增占空比,led逐渐变亮,视觉上是呼吸灯的效果。
4、核心代码
(1)pwm初始化
void PwmInit(void)
    rcu_periph_clock_enable(RCU_GPIOC);
    /* TIMER1 GPIO */
    gpio_mode_set(GPIOC, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_6 );
    gpio_output_options_set(GPIOC, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_6);
    gpio_af_set(GPIOC, GPIO_AF_1, GPIO_PIN_6);
    //64000000/6400=10k
	//TIMER2CLK = SystemCoreClock/6400 = 0.01MHz, the period is 1s(100/10000).=0.01s=10ms=100hz
    timer_oc_parameter_struct timer_ocinitpara;
    timer_parameter_struct timer_initpara;
    /* enable the peripherals clock */
    rcu_periph_clock_enable(RCU_TIMER2);
    /* deinit a TIMER */
    timer_deinit(TIMER2);
    /* initialize TIMER init parameter struct */
    timer_struct_para_init(&timer_initpara);
    /* TIMER2 configuration */
    timer_initpara.prescaler        = 6399;
    timer_initpara.alignedmode      = TIMER_COUNTER_EDGE;
    timer_initpara.counterdirection = TIMER_COUNTER_UP;
    timer_initpara.period           = 99;
    timer_initpara.clockdivision    = TIMER_CKDIV_DIV1;
    timer_init(TIMER2, &timer_initpara);
    /* initialize TIMER channel output parameter struct */
    timer_channel_output_struct_para_init(&timer_ocinitpara);
    /* configure TIMER channel output function */
    timer_ocinitpara.outputstate    = TIMER_CCX_ENABLE;
    timer_ocinitpara.ocpolarity     = TIMER_OC_POLARITY_HIGH;
    timer_channel_output_config(TIMER2, TIMER_CH_0, &timer_ocinitpara);
    timer_channel_output_pulse_value_config(TIMER2, TIMER_CH_0, 99);
    /* CH0 configuration in OC timing mode */
    timer_channel_output_mode_config(TIMER2, TIMER_CH_0, TIMER_OC_MODE_PWM0);
    /* enable a TIMER */
    timer_enable(TIMER2);
(2)更改占空比
void PwmOut(void)
	static uint32_t tick=0;
	static  uint8_t out=1;
	if(SystemGetTick()-tick>200)
		tick=SystemGetTick();
		out=out+10;
		if(out>100)
			out=1;
		timer_channel_output_pulse_value_config(TIMER2, TIMER_CH_0, out-1);
5、现象
pwmled.gif   6、示波器测量波形
此帖出自GD32 MCU论坛
个人签名stm32/LoRa物联网:304350312
SystemGetTick()在哪里
可以看【GD32L233C-START评测】2、非阻塞方式点灯,blink,blink,blink……这个帖子,用一个定时器中断1ms实现的,维护一个全局tick  详情 回复 发表于 2022-1-23 08:23
605
mameng 发表于 2022-1-22 20:59 SystemGetTick()在哪里
工程文件共享性下?
605
mameng 发表于 2022-2-23 09:03 工程文件共享性下?
GD32L233_Project_pwm.rar (360.63 KB, 下载次数: 0)
