483|1
【二哈识图人工智能视觉传感器】测评之六: 与ARM单片机TFT展示人脸识别结果 [复制链接]
    二哈试图的串口通信协议;
D2.jpg 人脸识别之串口测试 。识别成功收到数据
55 AA 11 0A 29 01 00 01 00 9B 03 00 00 00 00 E3
55 AA 11 0A 2A D9 00 71 00 30 00 40 00 01 00 FF
55 AA 11 0A 29 01 00 01 00 B5 03 00 00 00 00 FD
55 AA 11 0A 2A D9 00 64 00 30 00 40 00 01 00 F2
55 AA 11 0A 29 01 00 01 00 C5 03 00 00 00 00 0D
55 AA 11 0A 2A D8 00 63 00 30 00 40 00 01 00 F0
未识别记忆人脸收到数据
55 AA 11 0A 29 00 00 01 00 29 0E 00 00 00 00 7B
55 AA 11 0A 29 00 00 01 00 38 0E 00 00 00 00 8A
55 AA 11 0A 29 00 00 01 00 44 0E 00 00 00 00 96
55 AA 11 0A 29 00 00 01 00 4F 0E 00 00 00 00 A1
可以判断55 AA 11 0A 29后面不为零即代表检测出记忆人脸、
上次申请的到复旦微32位单片机开发板,驱动中景园TFT,与二哈试图串口通讯,关于屏的驱动,可以看我之前测评。
串口初始化;.用串口中断状态机判定,判断55 AA 11 0A 29后面不为零即代表检测出记忆人脸
void DebugUartInit(void)
     FL_GPIO_InitTypeDef GPIO_InitStruct = {0};
    FL_UART_InitTypeDef UART_InitStruct = {0};
    //PA13:UART0-RX   PA14:UART0-TX
    GPIO_InitStruct.pin        = FL_GPIO_PIN_13|FL_GPIO_PIN_14;
    GPIO_InitStruct.mode       = FL_GPIO_MODE_DIGITAL;
    GPIO_InitStruct.outputType = FL_GPIO_OUTPUT_PUSHPULL;
    GPIO_InitStruct.pull       = FL_ENABLE;
    GPIO_InitStruct.remapPin = FL_DISABLE;
    FL_GPIO_Init(GPIOA, &GPIO_InitStruct);
    UART_InitStruct.clockSrc = FL_CMU_UART0_CLK_SOURCE_APBCLK;
    UART_InitStruct.baudRate            = 9600;							        //波特率
    UART_InitStruct.dataWidth           = FL_UART_DATA_WIDTH_8B;			      	//数据位数
    UART_InitStruct.stopBits            = FL_UART_STOP_BIT_WIDTH_1B;				//停止位
    UART_InitStruct.parity              = FL_UART_PARITY_EVEN;				        //奇偶校验
    UART_InitStruct.transferDirection   = FL_UART_DIRECTION_TX_RX;	                //接收-发送使能
    FL_UART_Init(UART0, &UART_InitStruct);
测试视频:
6748
识别速度还行
