1395|6
485发送除了数据,接收时时断时续 [复制链接]
我是通过485串口抓到的数据
下面是我的数据:
左侧的03 和 04开头的数据是发送过去的,正常应该直接被响应,可是有很多时候数据都不能被响应,或者收不到,请问各位大佬是什么原因,快被折磨疯了
[2022-01-05 12:29:02.640]# RECV HEX>
03 02 03 00 00 02 33 1A
[2022-01-05 12:29:02.925]# RECV HEX>
04 02 03 00 00 02 33 1A
[2022-01-05 12:29:04.223]# RECV HEX>
03 02 03 00 00 02 33 1A 03 03 00 01 00 11 08 11
[2022-01-05 12:29:04.494]# RECV HEX>
04 02 03 00 00 02 33 1A 04 03 00 01 00 11 08 11
[2022-01-05 12:29:05.780]# RECV HEX>
[2022-01-05 12:29:06.051]# RECV HEX>
[2022-01-05 12:29:07.304]# RECV HEX>
[2022-01-05 12:29:07.577]# RECV HEX>
[2022-01-05 12:29:08.840]# RECV HEX>
[2022-01-05 12:29:09.128]# RECV HEX>
[2022-01-05 12:29:10.385]# RECV HEX>
[2022-01-05 12:29:10.673]# RECV HEX>
[2022-01-05 12:29:11.944]# RECV HEX>
[2022-01-05 12:29:12.233]# RECV HEX>
[2022-01-05 12:29:13.498]# RECV HEX>
[2022-01-05 12:29:13.769]# RECV HEX>
[2022-01-05 12:29:15.043]# RECV HEX>
[2022-01-05 12:29:15.325]# RECV HEX>
[2022-01-05 12:29:16.605]# RECV HEX>
[2022-01-05 12:29:16.878]# RECV HEX>
[2022-01-05 12:29:18.150]# RECV HEX>
[2022-01-05 12:29:18.406]# RECV HEX>
[2022-01-05 12:29:19.690]# RECV HEX>
[2022-01-05 12:29:19.962]# RECV HEX>
[2022-01-05 12:29:21.218]# RECV HEX>
[2022-01-05 12:29:21.506]# RECV HEX>
[2022-01-05 12:29:22.770]# RECV HEX>
[2022-01-05 12:29:23.042]# RECV HEX>
[2022-01-05 12:29:24.342]# RECV HEX>
[2022-01-05 12:29:24.585]# RECV HEX>
[2022-01-05 12:29:25.885]# RECV HEX>
[2022-01-05 12:29:26.125]# RECV HEX>
[2022-01-05 12:29:27.429]# RECV HEX>
[2022-01-05 12:29:27.669]# RECV HEX>
[2022-01-05 12:29:28.954]# RECV HEX>
[2022-01-05 12:29:29.225]# RECV HEX>
[2022-01-05 12:29:30.979]# RECV HEX>
[2022-01-05 12:29:31.278]# RECV HEX>
04 02 03 00 00 02 33 1A E2 78 E0 C1 E0 F7 E7
[2022-01-05 12:29:35.949]# RECV HEX>
[2022-01-05 12:29:37.204]# RECV HEX>
[2022-01-05 12:29:37.489]# RECV HEX>
[2022-01-05 12:29:38.776]# RECV HEX>
[2022-01-05 12:29:39.032]# RECV HEX>
此帖出自stm32/stm8论坛
因为我设置了如果没有响应十秒之内就会断开所有操作,所以总收不到响应就很难受
看不懂这个,希望解释一下,
就是三台设备,一个主机发送过去数据给另外两个,间隔250ms,另外两台设备分别收到数据发送回来一个应答数据, 两个从机是20ms的定时器用来接收,结果每次发送过去之后有时候收不到,或者从机发送的应答数据主机  详情 回复 发表于 2022-1-5 13:28
yangjeff 发表于 2022-1-5 13:23 看不懂这个,希望解释一下,
两个从机是20ms的定时器用来接收,结果每次发送过去之后有时候收不到,或者从机发送的应答数据主机也有时候收不到
3983
modbus?
143
你是怎么判断收不到的?在接收侧的TTL端用个串口监视软件看看数据,如果数据有问题是发送方或传输线路的问题,如果数据没问题就是接收侧软件有误。
个人签名上传了一些书籍资料,也许有你想要的:http://download.eeworld.com.cn/user/chunyang
484
RS485信号必须加偏置电压,否则经常有头无尾,信号紊乱。
个人签名چوآن شـين
    推荐帖子
    msp430f449关于flash段擦除的疑问
    flash擦除只能一段一段擦除,我选了擦除segmentA段(0x1080),正常,然后我把地址改为0x1081,也编译通过正常运行了,那岂不是 ...
    电路识图13-三极管放大电路识图
    三极管放大电路包括三极管单级放大电路、三极管双级放大电路、负反馈型三极管放大电路。熟悉这些放大电路的构成和功能,并且掌握 ...
    CCS5.5的详细操作说明
    CCS5.5的详细操作说明 383376
    高性能的C6000 DSP 架构
    8个并行的功能单元,2组寄存器,分离的程序和数据存储;256bit取指包,能一次取指8个32bit的指令;2路64bit的数据加载/存储。这 ...
    烧录问题
    STM32F103VET6在烧录两秒后报错,错误信息如图所示,该怎么解决呢?请教一下各位大侠,谢谢回复
    mmWAVE SDK 不支持AWR2243
    mmWAVE SDK 不支持AWR2243,在mmwave_sdk_03_05_00_04\docs\test 目录下没有awr2243. 请问那如何对awr2243进行评估?
