社区导航
搜索
查看: 2889|回复: 6
在VS2005+PB6.0的编译环境下调试HelloCE程序出错
108
TA的帖子
Rank: 1
发表于 2010-6-22 10:29 | 显示全部楼层 |阅读模式
提示 “WM_HIBERNATE”:未声明的标识符
代码如下:
// HelloCE - A simple application for Windows CE
// Written for the book Programming Windows CE
// Copyright (C) 1998 Douglas Boling
#include                  // For all that Windows stuff
#include                 // Command bar includes
#include "helloce.h"                 // Program-specific stuff
// Global data
const TCHAR szAppName[] = TEXT ("HelloCE");
HINSTANCE hInst;                     // Program instance handle
// Message dispatch table for MainWindowProc
const struct decodeUINT MainMessages[] = {
    WM_CREATE, DoCreateMain,
    WM_PAINT, DoPaintMain,
    WM_HIBERNATE, DoHibernateMain,
    WM_ACTIVATE, DoActivateMain,
    WM_DESTROY, DoDestroyMain,
// Program entry point
int WINAPI WinMain (HINSTANCE hInstance, HINSTANCE hPrevInstance,
                    LPWSTR lpCmdLine, int nCmdShow) {
    MSG msg;
    int rc = 0;
    HWND hwndMain;
    // init application
    rc = InitApp (hInstance);
    if (rc) return rc;
    // Initialize this instance.
    hwndMain = InitInstance (hInstance, lpCmdLine, nCmdShow);
    if (hwndMain == 0)
        return 0x10;
    // Application message loop
    while (GetMessage (&msg, NULL, 0, 0)) {
        TranslateMessage (&msg);
        DispatchMessage (&msg);
    // Instance cleanup
    return TermInstance (hInstance, msg.wParam);
// InitApp - Application initialization
int InitApp (HINSTANCE hInstance) {
    // Register application main window class.
        WNDCLASS wc;
    wc.style = 0;                             // Window style
    wc.lpfnWndProc = MainWndProc;             // Callback function
    wc.cbClsExtra = 0;                        // Extra class data
    wc.cbWndExtra = 0;                        // Extra window data
    wc.hInstance = hInstance;                 // Owner handle
    wc.hIcon = NULL,                          // Application icon
    wc.hCursor = NULL;                        // Default cursor
    wc.hbrBackground = (HBRUSH) GetStockObject (WHITE_BRUSH);
    wc.lpszMenuName =  NULL;                  // Menu name
    wc.lpszClassName = szAppName;             // Window class name
    if (RegisterClass (&wc) == 0) return 1;
    return 0;
// InitInstance - Instance initialization
HWND InitInstance (HINSTANCE hInstance, LPWSTR lpCmdLine,
                   int nCmdShow) {
    HWND hWnd;
    // Save program instance handle in global variable.
    hInst = hInstance;
    // Create main window.
    hWnd = CreateWindow (szAppName,           // Window class
                         TEXT("Hello"),       // Window title
                         WS_VISIBLE,          // Style flags
                         CW_USEDEFAULT,       // x position
                         CW_USEDEFAULT,       // y position
                         CW_USEDEFAULT,       // Initial width
                         CW_USEDEFAULT,       // Initial height
                         NULL,                // Parent
                         NULL,                // Menu, must be null
                         hInstance,           // Application instance
                         NULL);               // Pointer to create parameters
    // Return fail code if window not created.
    if (!IsWindow (hWnd)) return 0;
    // Standard show and update calls
    ShowWindow (hWnd, nCmdShow);
    UpdateWindow (hWnd);
    return hWnd;
// TermInstance - Program cleanup
int TermInstance (HINSTANCE hInstance, int nDefRC) {
    return nDefRC;
// Message handling procedures for main window
// MainWndProc - Callback function for application window
LRESULT CALLBACK MainWndProc (HWND hWnd, UINT wMsg, WPARAM wParam,
                              LPARAM lParam) {
    INT i;
    // Search message list to see if we need to handle this
    // message.  If in list, call procedure.
    for (i = 0; i < dim(MainMessages); i++) {
        if (wMsg == MainMessages.Code)
            return (*MainMessages.Fxn)(hWnd, wMsg, wParam, lParam);
    return DefWindowProc (hWnd, wMsg, wParam, lParam);
// DoCreateMain - Process WM_CREATE message for window.
LRESULT DoCreateMain (HWND hWnd, UINT wMsg, WPARAM wParam,
                      LPARAM lParam) {
    HWND hwndCB;
    // Create a command bar.
    hwndCB = CommandBar_Create (hInst, hWnd, IDC_CMDBAR);
    // Add exit button to command bar.
    CommandBar_AddAdornments (hwndCB, 0, 0);
    return 0;
// DoPaintMain - Process WM_PAINT message for window.
LRESULT DoPaintMain (HWND hWnd, UINT wMsg, WPARAM wParam,
                     LPARAM lParam) {
    PAINTSTRUCT ps;
    RECT rect;
    HDC hdc;
    // Adjust the size of the client rectangle to take into account
    // the command bar height.
    GetClientRect (hWnd, &rect);
    rect.top += CommandBar_Height (GetDlgItem (hWnd, IDC_CMDBAR));
    hdc = BeginPaint (hWnd, &ps);
    DrawText (hdc, TEXT ("Hello Windows CE!"), -1, &rect,
              DT_CENTER | DT_VCENTER | DT_SINGLELINE);
    EndPaint (hWnd, &ps);
    return 0;
// DoHibernateMain - Process WM_HIBERNATE message for window.
LRESULT DoHibernateMain (HWND hWnd, UINT wMsg, WPARAM wParam,
                         LPARAM lParam) {
    // If not the active window, nuke the command bar to save memory.
    if (GetActiveWindow () != hWnd)
        CommandBar_Destroy (GetDlgItem (hWnd, IDC_CMDBAR));
    return 0;
// DoActivateMain - Process WM_ACTIVATE message for window.
LRESULT DoActivateMain (HWND hWnd, UINT wMsg, WPARAM wParam,
                        LPARAM lParam) {
    HWND hwndCB;
    // If activating and no command bar, create it.
    if ((LOWORD (wParam) != WA_INACTIVE) &&
        (GetDlgItem (hWnd, IDC_CMDBAR) == 0)) {
    return 0;
// DoDestroyMain - Process WM_DESTROY message for window.
LRESULT DoDestroyMain (HWND hWnd, UINT wMsg, WPARAM wParam,
                       LPARAM lParam) {
    PostQuitMessage (0);
    return 0;
在线等,我第一次用wince,错了都不知道什么地方有问题,请高手指点一下!
TA的帖子
Rank: 1
发表于 2010-6-22 10:42 | 显示全部楼层
怎么没人回答我的问题呀?
使用道具 举报
112
TA的帖子
Rank: 1
发表于 2010-6-22 10:52 | 显示全部楼层
错误提示已经说的很清楚了,WM_HIBERNATE 未定义
使用道具 举报
125
TA的帖子
Rank: 1
发表于 2010-6-22 11:04 | 显示全部楼层
是不是在#include 这里没有定义
使用道具 举报
103
TA的帖子
Rank: 1
发表于 2010-6-22 11:19 | 显示全部楼层
是不是因为开发环境没有搭建好?
使用道具 举报
119
TA的帖子
Rank: 1
发表于 2010-6-22 15:12 | 显示全部楼层
可能是头文件的问题。。。
使用道具 举报
98
TA的帖子
Rank: 1
发表于 2010-6-24 10:39 | 显示全部楼层
群:21665782 开源空间  大家一起交流wince开发
使用道具 举报
站长推荐上一条 /5 下一条
  • 论坛活动 E手掌握
    扫码关注
    EEWORLD 官方微信
  • EE福利  唾手可得
    扫码关注
    EE福利 唾手可得
GMT+8, 2020-2-18 00:44 , Processed in 0.225327 second(s), 17 queries , Gzip On, MemCache On.
